| Re: Storing boat on water...How long is OK??
[Re: duganderson]
#22052 07/10/03 10:06 PM 07/10/03 10:06 PM |
Posts: 14 Seabrook, Tx | Should be no problem. Just as long as you anchor it well. The worst thing that could happen to the hulls is that you might have a little bit of algea growing, but it usually takes a couple of weeks before the green stuff starts to take hold. No way to pull it on land and let it sit in the grass or sand??
PrindleFish }=)))*>
[Re: PrindleFish]
#22053 07/10/03 11:16 PM 07/10/03 11:16 PM |
Posts: 20 | A week "should be" fine.
I have had my brothers Hobie 16 on a moring for a few days here and there. Tied off at the mast base and with a relatively taught line between the shrouds to take up slack so the waves dont bang the rig around. Tied rudders off, too. My Nacra sits in the drink for a week during the family vacation and it stays dry. If the boat is solid, short term shouldnt be a problem.
Nacra 6.0NA to kill myself quickly and a Johnson 18 to do it a little slower.
[Re: duganderson]
#22054 07/10/03 11:23 PM 07/10/03 11:23 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Doug, You'll have no problem anchoring for a week. Just make sure the hulls don't leak. Anchor using enough scope. I use a bridle attached to the bridle tangs. I think the 21SC bridle tangs have a extra set of holes that you could put shackles in and then use those to tie the anchor bridle to. If not replace the clevis pins at the bridle tangs with shackles that have the same pin dia. as the clevis pins. Look at the triangle the wire bridles make. Make the anchoring bridle a little a little larger.
You can do a search. This topic was talked about a while back.
Have Fun Mike
2,412
guests, and 191
Mod | | Forums35 Topics22,989 Posts268,931 Members8,150 | Most Online23,979 Sep 24th, 2025 | | | |
