Re: F20 Freestyle [Re: BLR_0719] #221400
10/11/10 01:09 AM
10/11/10 01:09 AM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
It's a copyright problem. I'll PM you how you can watch it.
Re: F20 Freestyle [Re: BLR_0719] #221401
10/11/10 01:13 AM
10/11/10 01:13 AM
where the wind never blows
Lockenfisch Offline
Lockenfisch  Offline
Okay I found the answer. Its a legal dispute between youtube and our organization GEMA that works for artists and their copyrights, earnings when their music is played in public.
Re: F20 Freestyle [Re: Lockenfisch] #221402
10/11/10 01:28 AM
10/11/10 01:28 AM
For our german friends: http://db.tt/C1FQr6r
Let me know it that works.
Re: F20 Freestyle [Re: Lockenfisch] #221403
10/11/10 01:40 AM
10/11/10 01:40 AM
Atlanta, Ga
BLR_0719 Offline
BLR_0719  Offline
Atlanta, Ga
Blame Google.
Re: F20 Freestyle [Re: BLR_0719] #221405
10/11/10 02:41 AM
10/11/10 02:41 AM
Lockenfisch Offline
Lockenfisch  Offline
Thank you guys. BLR I can't try your proposal cause I have no account there. Tony your link works fine smile
Really interesting movie. It looks like when the boat is coming out of the water it loses speed for some reason and falls down, again takes up speed and falls again ... did somebody ever try the F20 with straight boards? Do the curved ones really make a big difference?
Re: F20 Freestyle [Re: Lockenfisch] #221408
10/11/10 04:35 AM
10/11/10 04:35 AM
Australia
macca Offline OP
macca  Offline OP
Australia
Sorry about the video not being available in GER...
but its good to see you have worked around it.
We tested two platforms over more than 12 months, comparing the straight and curved boards. There was never any situation where the curved boards were slower. So it was an easy choice!
When you are full foiling the boat slows down, its just for fun that we are flying so high with it.
The quickest mode is in the middle part of the video, where we are twin trapezing downwind, the leeward board is up a little bit and the windward board is up a lot more.
________________________
http://aus300.blogspot.com
Re: F20 Freestyle [Re: macca] #221418
10/11/10 05:55 AM
10/11/10 05:55 AM
japan
erice Offline
erice  Offline
japan
any ideas of the speeds at that sweet spot?
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: F20 Freestyle [Re: macca] #221419
10/11/10 06:04 AM
10/11/10 06:04 AM
waynemarlow Offline
waynemarlow  Offline
Why bother then to put curved boards on then if the quickest part is when the boards are raised somewhat, you would be better off with inclined boards in that case.
The A camp has the curved boards in the not sure camp still and many are complaining of the number of broken boards + the time needed to raise one board to get best effect, Me thinks the jury maybe still under deliberation.
As to the minscule little bit of " jump " mode followed by immediate slow down of the boat ( induced drag of the foil breaking back into the water is more than if the foil was in the water ), nah find a boat wake and then you would see some real air time .
Re: F20 Freestyle [Re: macca] #221423
10/11/10 06:51 AM
10/11/10 06:51 AM
I noticed they where sailing with the windward board fully raised going upwind yesterday as well, even though the wind was quite light.
Re: F20 Freestyle [Re: waynemarlow] #221424
10/11/10 07:08 AM
10/11/10 07:08 AM
Australia
macca Offline OP
macca  Offline OP
Australia
We raise the boards a little bit depending on the wind strength, we start off with the board down and then once you are trapping fully downwind, then we raise it a little and then we go back down fully in really windy stuff. Also wave state plays a part in the balance too, so its a lot more complex to get the most out of the boat compared to a F18 but the reward is a very quick machine.
The reason the A class guys are not fully converted to the curved foils is for a number of factors:-
1. The limited amount of foil curve/length allowed under the rule
2. The A cat is narrow anyhow and the curved foils reduce the righting moment even further
3. The A cat is not adding any sail area downwind and as such the foil effect is not as apparent.
We had 2 M20's which were identically rigged and both had interchangeable daggerboard slots, we did many, many hours testing and the result was very clear: The Curved board boat was always quicker.
And Inclined boards are not even close to as good as the curved boards in that application. We have some pretty good designers... and from their assessment it wasn't even worth exploring.
In the video we are just playing around with the boat, jumping it a bit and having a bit of a laugh. When you have the boat in full speed mode, it looks pretty boring.. just hammering along faster than you think is decent for any sailboat!
Re: F20 Freestyle [Re: macca] #221426
10/11/10 07:13 AM
10/11/10 07:13 AM
waynemarlow Offline
waynemarlow  Offline
Are the boards assymetric or symetric ?
Re: F20 Freestyle [Re: waynemarlow] #221427
10/11/10 07:18 AM
10/11/10 07:18 AM
Australia
macca Offline OP
macca  Offline OP
Australia
Symmetric in cross section, and a twist in the lower half..
Re: F20 Freestyle [Re: erice] #221428
10/11/10 07:34 AM
10/11/10 07:34 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
Mike and I found out that the boat will foil out of the water at 16knts down wind.
Re: F20 Freestyle [Re: Lockenfisch] #221432
10/11/10 08:04 AM
10/11/10 08:04 AM
It is an unstable system with a positive feedback loop where the foils eventually stall en the whole thing starts all over again. The same thing was happening with the ORMA tris as far back as 5 years ago. That is why foiling moths have a control rod that adjusts the angel of attack of the foil to smaller values when the boat rises too high. The Nacra Freestyle as no such thing and this is the result.
Re: F20 Freestyle [Re: Wouter] #221433
10/11/10 08:20 AM
10/11/10 08:20 AM
It's actually stable when you have your weight placed properly because these are not foils designed to lift the boat clear of the water. As Macca mentioned, in this video they were purposely putting their weight to the rear of the boat to make it leap out of the water when that critical speed (16knots) was obtained.
Re: F20 Freestyle [Re: Jake] #221434
10/11/10 08:24 AM
10/11/10 08:24 AM
Australia
macca Offline OP
macca  Offline OP
Australia
Yep, the boat is very well behaved when you have your crew weight in the correct location.
Same as any other boat really, you just see a bigger difference on the F20 when you are in the wrong spot. but its not dangerous, just a lot of fun.
Oh, and it still happens on the Orma tri's and another 90ft long tri.... its just how it is!
Re: F20 Freestyle [Re: Lockenfisch] #221438
10/11/10 09:43 AM
10/11/10 09:43 AM
M
MN3
MN3
M
Have you tried it while wearing a cape? it seemed to work for Jake, but perhaps you need to also carry a plunger at the same time? smile
Re: F20 Freestyle [Re: ] #221469
10/11/10 07:50 PM
10/11/10 07:50 PM
taipanfc Offline
taipanfc  Offline
Must be a way to control the height rather than crudely pulling boards up and down. As Wouter said above, the moths have this semi-automated with the wand allowing you to control your height. The manual part is setting what level of ride height you want, and you regularly change this based on your speed and wave/wind conditions. Moving weight back/forward was what the mothies did initially when foiling started, but now don't move at all as the systems work.
And this new 20 better be quicker than the old 20! In 15 knots of breeze and flat water on the weekend, it didn't stand a chance against the moth downhill. Motored past it when they thought they were doing full noise...
Re: F20 Freestyle [Re: taipanfc] #221472
10/11/10 08:04 PM
10/11/10 08:04 PM
It's definitely faster than the N20 and by a fairly substantial margin.
Re: F20 Freestyle [Re: Jake] #221478
10/11/10 10:09 PM
10/11/10 10:09 PM
taipanfc Offline
taipanfc  Offline
Good, will have something to chase when they arrive in Singapore.
1 registered members (FredL), 343 guests, and 59 spiders.
