| Mast Hook Pull-out #22144 07/14/03 02:43 PM 07/14/03 02:43 PM |
Joined: Jul 2001 Posts: 1,200 Vancouver, BC Tornado OP
Posts: 1,200 Vancouver, BC | Well, sea trials of my newly pre-bent Tornado rig with updated sails were going great...15kts, good power and sail control. Hardened up for another windward leg, loaded up downhaul to max grunt (8:1) and honked in the mainsheet...BANG! The hook at the top of the mast fails and the main drops. Limp home on jib alone.
The hook was not made for the modern prebend loads...metal is about 2.1 mm thick, other boats I compared it to in the yard were nearly double that at 3.8 mm. One 1/4" monel rivet pulled out as the hook bent.
I've sourced a Hobie 18/20 hook which mounts on the opposite side of the mast (starboard) so no worry of fatigued aluminum. Hobie hook is thicker/larger with 6 3/16" rivets. This is made not to pull out of the plastic comptip, so it otta hold real well in alu. Will drill it out to 1/4" and slap in new monel's. Might need to flatten the curve of the hook a bit prior to installing.
Mike.
| | | Re: Mast Hook Pull-out
[Re: D Wilkins]
#22146 07/14/03 04:31 PM 07/14/03 04:31 PM |
Posts: 1,200 Vancouver, BC | THanks for the response...I can see why it would fail on the CompTip plastic mast if you don't go thru the casting. The Tornado is all Aluminum with no casting at the top...just a sealed (welded) end. Those look like 1/4" rivets on that hook plate...my source told me it had 3/16".
[Re: Tornado_ALIVE]
#22149 07/15/03 01:16 PM 07/15/03 01:16 PM |
Posts: 1,200 Vancouver, BC | I had to act fast...I'm preparing for a race this Saturday. Went with a locally available Hobie 18/20 hook. I had to bend it to fit the Tornado section...but it looks way more meaty than what was on there...plus it mounts to the undamaged side of the mast.
913
guests, and 37
