| Re: Why Nacra can and should compete
[Re: Karl_Brogger]
#221470 10/11/10 08:01 PM 10/11/10 08:01 PM |
Posts: 7 Hawaii, USA | [quote=PTP]it puts used boats on the market, making them more affordable to people. Yes, I have been looking for an affordable used boat and can't find one, especially considering the extra shipping here to Hawaii. | | | Re: Why Nacra can and should compete
[Re: smv]
#221474 10/11/10 08:30 PM 10/11/10 08:30 PM |
Posts: 4,119 Northfield Mn | Ann Arbor, MI. Not ready yet, just spent a huge chunk of my F16 fund on a surgery for my dog... but, I've got the winter to build that fund back up! Who are you? I was in Ann Arbor a couple of weekends ago with a Viper. (edit)- Also currently in CRAW we have a used Blade, Falcon, and Viper available. I'm not sure the age of the Blade, but the Falcon was new last spring, and the Viper hasn't even hit the US yet, and I can get you a new Viper as well.
[Re: waynemarlow]
#221833 10/18/10 04:33 AM 10/18/10 04:33 AM |
Posts: 1,021 Australia |
No thats not quite the case, all the development cost has now been spent on the F20, to integrate that knowledge now into a slightly smaller boat is very minimal and it would spread the cost over more boats. Wayne, If you seriously think that the development done on the F20 foils will negate any development costs for a curved foil for an F16 then i'm sorry to tell you this: You have no idea what you are on about! With modern CNC mills cutting out the moulds, its almost irrelavent whether the board is curved or straight and equally the cost is not significantly higher to produce, a mould is a mould. I can tell you from experience that the cost to build a mold for a curved board is a much more complex process and the costs are a lot higher in all steps, design, billet, cutting time, finishing, and even foil production. If you have a cheaper way then please let me know.. One thing for sure the performance of the F16's is only going to be marginally better with curved boards and greater gains could be found in other functions of design. And you base this assumption on your extensive experience with both straight and curved foils?? I can tell you from my time with both foils that there is nothing in current technology that makes as much difference to the performance of a boat that the change from straight to curved foils. If all else is equal (ie sail area and dimensions of the boat etc) then the curved foils make a bigger gain in performance than any other feature. | | | Re: Why Nacra can and should compete
[Re: macca]
#221838 10/18/10 06:24 AM 10/18/10 06:24 AM |
Posts: 221 Netherlands | And you base this assumption on your extensive experience with both straight and curved foils?? I can tell you from my time with both foils that there is nothing in current technology that makes as much difference to the performance of a boat that the change from straight to curved foils. If all else is equal (ie sail area and dimensions of the boat etc) then the curved foils make a bigger gain in performance than any other feature. Well this is not completly thru. We are experimenting a lot with both configurations ( straight and curved ) and to be honest which type will be really quicker we still do not now. It depends a lot on the conditions ( wind , wave ). We do know for sure that in light wind the curved boards are definitly slower then straight boards. Hans | | | Re: Why Nacra can and should compete
[Re: pepin]
#221935 10/18/10 04:15 PM 10/18/10 04:15 PM |
Posts: 893 | No matter what foils you put on, straight put on at an angle or curved with or without twist the thing I don't get is how do you control the foiling (even if it is only partial foiling).
The F20 never foils as such, its not designed to do that, the C boards are there to give a minimum lift to slightly reduce wetted surface area of the hull, that minimum lift clearly can be seen when in the video with the rear down to give max angle of attack, the boat raises only a few centimetres and then when the angle of attack becomes too much, the boat settles down in the water. Note how much speed was lost from the very draggy foil at max angle of attack. There has been some discussion within the A's as to its merits and failures and in what conditions they do work. As much as Macca states the A is not comparable, sorry but the boat speeds are not unsimilar and that is what produces the lift regardless of how much horsepower you throw at getting that speed. This boats speed is probably as much from modern hull design learnt from the Americas cup as from its C boards, the boards are simply not big enough to foil and the boat too heavy to allow true foiling. As with all things though there is a down side to foils ( as per the foiling C Cat experiment ), the C boards will magnify and slow the boat through additional drag as soon as they are not in optimum AOA and my guess it will be slower in the lessor sailors hands than one with simple straight boards as they will not have the experiance to know how to balance the boat as well as the pros can. | | | Re: Why Nacra can and should compete
[Re: Seeker]
#221955 10/18/10 07:15 PM 10/18/10 07:15 PM |
Posts: 2,921 Michigan | Macca it is too bad you have "pissed in the sandbox" so many times... Yeah, he certainly will be in any discussion I have about Nacra with someone who doesn't know any better. especially when it comes to someone ever wanting to buy a supposed nacra f16 if one ever comes. Nothing like a company crapping on a class that they want to sell boats to. Seems odd that people are getting on the F16's sailor's cases for chiming in on the main forum. A factory rep from a company that doesn't make an F16 repeatedly crapping on the F16 class. Not one of the guys on the main forum would put up with that either. BTW macca, can I quote you that the boards for the F20C will be 120% of an infusion board? so, Murray's price is 450$ which would make the F20C board 540$. I think that is actually reasonable, though I doubt this will be the case.
[Re: PTP]
#221957 10/18/10 07:40 PM 10/18/10 07:40 PM |
Posts: 4,119 Northfield Mn | I think that is actually reasonable, though I doubt this will be the case. Me too, not much more than an AHPC board.
[Re: Seeker]
#221967 10/18/10 08:46 PM 10/18/10 08:46 PM |
Posts: 4,119 Northfield Mn | How many people go to their job expecting to break even at the end of the day? own your own company? I'm happy if I break even at the end of the day. Ecstatic if I make money.
[Re: Seeker]
#221970 10/18/10 09:30 PM 10/18/10 09:30 PM |
Posts: 2,921 Michigan | I certainly don't expect people to work for free, although I have to about 20% of the time. and this is likely to go up. I don't expect nacra to work for free... just "truth in advertising" is necessary. besides, it is macca representing nacra. He needs to realize who is the customer. It is us, so why would he always piss us off? because he doesn't know what the hell he is doing. Yes, a good sailor, but not a good salesman.
1 registered members (JesperS),
234
guests, and 47
