Page 2 of 3 1 2 3
Re: Upwind - Fast -- Rudder "slip" [Re: Matt M] #222186
10/20/10 01:01 PM
10/20/10 01:01 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Matt, am I reading that right? 75mm for the cord on a rudder?
2 15/16"? With your example of 10% that would make the rudder 5/16" at its thickest point...That seems insane...how do you make anything with those dimensions stiff/strong enough to function at all irregardless of keeping laminar flow?
Re: Upwind - Fast -- Rudder "slip" [Re: Matt M] #222187
10/20/10 01:15 PM
10/20/10 01:15 PM
Originally Posted by Matt M
Originally Posted by PTP
so the falcon rudders are thicker and longer than my rudders? are they a one-to-one replacement? would I need to modify my castings?
My boat has always felt a little squirelly (sp) when driving downwind. never been sure whether that was a function of light boat/overly sensitive rudders/piss poor driving smile
Unfortunately they are not interchangeable. In the generational changes we modified more than just the foil section.
Squirrely down wind and having cavitations or your rudders stall are 2 different things. 1 of the design compromises on the F16 is transom length behind the rear beam. There needs to be some minimum foot length on the main sail, so unless you are willing to place a stiff beam for the boom section, most sheet systems opt to directly attach to the clew of the main. There is also a desire to keep the maximum tramp size to allow for easy handling of 2 crew. The tiller length then on the Blade is then pretty short. The same arm travel in your steering can result in almost twice the angel change in the rudders relative to some of the 18 and 20 foot boats. Of course a lighter weight powered up platform will be significantly more sensitive to the conditions than the heavy weight, or even the longer light HTs.
what, you mean these things aren't just thrown together from parts that are sitting around? smile
Re: Upwind - Fast -- Rudder "slip" [Re: PTP] #222189
10/20/10 01:29 PM
10/20/10 01:29 PM
waynemarlow Offline
waynemarlow  Offline
Pete same problem. The f18 Shockwave uses extended pintles maybe cheaper than new rudders, you would only need the arms to be lengthened then
Re: Upwind - Fast -- Rudder "slip" [Re: waynemarlow] #222194
10/20/10 02:12 PM
10/20/10 02:12 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Looks like one way to solve a little of the "over steer" problem....especially on an existing boat...but how does that sit with the rules? And if what you have pictured is class legal...how much farther can you carry the pintles aft before the rules have been broken?
Curious to how much smoother the steering can be enhanced before it is considered an extension of the hull, and is included in the overall length.
Re: Upwind - Fast -- Rudder "slip" [Re: Seeker] #222205
10/20/10 02:50 PM
10/20/10 02:50 PM
My PERSONAL understanding of the rules is that rudder gantries are legal provided that they do not add bouyancy or waterline length. Therefore they must be solid, heavier than water or open vented tubing that cannot float.
The overall length of an F16 hull excludes rudder fittings.
Re: Upwind - Fast -- Rudder "slip" [Re: Jalani] #222213
10/20/10 03:17 PM
10/20/10 03:17 PM
Ft. Pierce, Fl. USA
Seeker Offline
Seeker  Offline
Ft. Pierce, Fl. USA
Wayne, couple of questions...
1) Did you ever sail that boat with the rudder attached directly to the transom without the stand off pintels? If so what percentage improvement did you feel it achieved by moving the rudders back?
2) What's the motivation for mounting the rear beam so close to the transom?
Thanks for sharing your insight...
Bob
Re: Upwind - Fast -- Rudder "slip" [Re: Seeker] #222243
10/21/10 04:16 AM
10/21/10 04:16 AM
waynemarlow Offline
waynemarlow  Offline
Bob
It was to overcome a problem the F16's had started to get into design wise. We all have started moving the front beam back further in the boat like the A's basically to get the upwind Uni sail working better ( the uni sailor is not allowed to have a jib ) and bringing the Spinnaker COE back further into the boat to prevent pitch poling ( it does seem to do that ). Bitsa has got to the point in that despite quite fine bows, it will side slip rather than dig the nose in even when provoced to try and make it so. A part of that also is my belief that as an Uni sailor we are over square at 2.5m beam so reduced it to more the A's of 2.3m
The problem lies with the box rules in that we have only a 8.5 m mast height allowed which then makes the sail much lower aspect than the A's and creates a much longer foot. That means then that the rear travellor has to be much further back than an A, so the beam has to go back further in the boat which then immediately flags up the short fulcrum arms. The 150mm gantry is a waste of time as far as leverage goes, it was just a method of getting the arms longer.
There is an alternative to the arms we use and I wish I had used that method, Have a look at the C class boats, they use a much better, far less vulnerable to accident damage ( crew falling into the cross arm )and probably a lot lighter system. Knowing now the problems caused by the extra leverage of the gantry, I wouldn't do the same again particularly as we cannot fair the lower gantry in to make it more streamlined as per the box rules.
Bitsa as we speak is in the workshop getting this mod done ready for next season, it has a load of benefits, moving the tiller mount point 400mm inside the rear beam and giving central sheeting. The downside is I will have two short tiller sticks rather than the more traditional long stick.
Re: Upwind - Fast -- Rudder "slip" [Re: waynemarlow] #222249
10/21/10 04:56 AM
10/21/10 04:56 AM
Australia
macca Offline
macca  Offline
Australia
I know I will regret asking this, but here goes anyhow: Why did you reduce the beam by 20cm?
________________________
http://aus300.blogspot.com
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222250
10/21/10 05:10 AM
10/21/10 05:10 AM
waynemarlow Offline
waynemarlow  Offline
The hull bouyancy is marginal for the 15m main, yes I can get my lardy 95 kilos out on the wire to compensate but all that will do is sink the hull further creating wetted area and drag which means slow. So much better to reduce sail area and let the hull ride in its optimum level.
Certainly proven with my current boat, having gone from 13.5m sail to 15m sail and then from 2.3m wide to 2.5m wide, I think the smaller sailed narrower boat was faster other than in light conditions.
But Mecca I'm sure you will tell me that I am so wrong smile
Re: Upwind - Fast -- Rudder "slip" [Re: waynemarlow] #222254
10/21/10 05:55 AM
10/21/10 05:55 AM
Australia
macca Offline
macca  Offline
Australia
I won't tell you that you are wrong, but I'm sure plenty of people who design multihulls for a living will...
But hey, if it's working for you... Keep on trucking!
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222262
10/21/10 08:10 AM
10/21/10 08:10 AM
waynemarlow Offline
waynemarlow  Offline
Originally Posted by macca
I won't tell you that you are wrong....
Corrr that has to be a first grin
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222263
10/21/10 08:11 AM
10/21/10 08:11 AM
pgp Offline
pgp  Offline
Slightly narrower beam seems to work for A cats.
Pete Pollard
Blade 702
Re: Upwind - Fast -- Rudder "slip" [Re: pgp] #222268
10/21/10 08:26 AM
10/21/10 08:26 AM
Australia
macca Offline
macca  Offline
Australia
And do you think the A cat would be faster or slower if it was wider??
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222270
10/21/10 08:29 AM
10/21/10 08:29 AM
I think it depends on the wind. We all want to sail on one hull as much as possible, for reduced drag. A narrower boat will fly a hull sooner, with less righting moment, so in light air, that's what you want. But when the wind comes up, now you need more righting moment, so the same hulls, crew, etc. should go faster with a wider platform (more righting moment), right?
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222271
10/21/10 08:30 AM
10/21/10 08:30 AM
pgp Offline
pgp  Offline
I don't know. Why don't you ask Pete Melvin?
I'm guessing you'd have to beef up the beams to make it wider. The wider platform would be less stiff and I've no idea how to correct that. The narrower beam would be easier to sail, "things" would be an inch or two closer and easier to reach.
So, I'd conclude the narrower beam would be one of many compromises.
If you can get Melvin to address the issue, I'd be greatful.
Pete Pollard
Blade 702
Re: Upwind - Fast -- Rudder "slip" [Re: pgp] #222274
10/21/10 08:53 AM
10/21/10 08:53 AM
Australia
macca Offline
macca  Offline
Australia
Pete and Gino have a bit on at the moment, and to ask them that question would be like asking Enzo Ferrari if he thinks more horsepower is a good thing...
I'll leave you guys to this little discussion, you seem to have entered the 4th dimension...
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222275
10/21/10 09:14 AM
10/21/10 09:14 AM
pgp Offline
pgp  Offline
Macca,you make no sense. The analogy between horsepower and beam is dubious at best. In cars the problem has always been getting power to the road. That requires matching engine and chassis. As power increases, chassis are redesigned to accommodate the increase.
The assumption here is that Pete Melvin is at the top of his field and his designs are among the best.
IF: wider beam are always better
Then: Pete Melvin desgins should always have wide beams.
Since the conclusion is demonstrably false, so is the premise.
FWIW, Ferrari doesn't know everything. Their cars don't win all races or sell to all upscale buyers. Iirc, Ferrari was one of the last builders to switch from drum to disc brakes.
Pete Pollard
Blade 702
Re: Upwind - Fast -- Rudder "slip" [Re: pgp] #222276
10/21/10 09:27 AM
10/21/10 09:27 AM
waynemarlow Offline
waynemarlow  Offline
OK then, which is fastest upwind a DNA A class or the latest all singing and dancing 10ft wide Melvin designed F20C. My money would have to say more times than not the A class.
Ah now I quote from the DNA's own website "This weekend PJ sailed in Hellevoetsluis in force 5-6 in such a set-up (increased mastrake, striff battens) and he could easily beat a Nacra 20 carbon and the F18's upwind by saling both higher and faster (downwind the Nacra was a rocket).
Now if everything can be believed from the internet grin
Re: Upwind - Fast -- Rudder "slip" [Re: waynemarlow] #222281
10/21/10 09:37 AM
10/21/10 09:37 AM
Australia
macca Offline
macca  Offline
Australia
Ok, how about we do a lineup? You guys bring an A class and I bring the F20.....
You shouldn't believe everything you read on the web...
Re: Upwind - Fast -- Rudder "slip" [Re: macca] #222288
10/21/10 09:55 AM
10/21/10 09:55 AM
pgp Offline
pgp  Offline
You think Ashby would show?
Pete Pollard
Blade 702
Page 2 of 3 1 2 3
0 registered members (), 2,652 guests, and 511 spiders.
Yesterday at 10:10 AM
