| Re: Upwind - Fast -- Rudder "slip"
[Re: Matt M]
#222187 10/20/10 01:15 PM 10/20/10 01:15 PM |
Posts: 2,921 Michigan | so the falcon rudders are thicker and longer than my rudders? are they a one-to-one replacement? would I need to modify my castings? My boat has always felt a little squirelly (sp) when driving downwind. never been sure whether that was a function of light boat/overly sensitive rudders/piss poor driving Unfortunately they are not interchangeable. In the generational changes we modified more than just the foil section. Squirrely down wind and having cavitations or your rudders stall are 2 different things. 1 of the design compromises on the F16 is transom length behind the rear beam. There needs to be some minimum foot length on the main sail, so unless you are willing to place a stiff beam for the boom section, most sheet systems opt to directly attach to the clew of the main. There is also a desire to keep the maximum tramp size to allow for easy handling of 2 crew. The tiller length then on the Blade is then pretty short. The same arm travel in your steering can result in almost twice the angel change in the rudders relative to some of the 18 and 20 foot boats. Of course a lighter weight powered up platform will be significantly more sensitive to the conditions than the heavy weight, or even the longer light HTs. what, you mean these things aren't just thrown together from parts that are sitting around?  | | | Re: Upwind - Fast -- Rudder "slip"
[Re: Seeker]
#222205 10/20/10 02:50 PM 10/20/10 02:50 PM |
Posts: 1,382 Essex, UK | My PERSONAL understanding of the rules is that rudder gantries are legal provided that they do not add bouyancy or waterline length. Therefore they must be solid, heavier than water or open vented tubing that cannot float. The overall length of an F16 hull excludes rudder fittings.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Upwind - Fast -- Rudder "slip"
[Re: Seeker]
#222243 10/21/10 04:16 AM 10/21/10 04:16 AM |
Posts: 893 | Wayne, couple of questions... 1) Did you ever sail that boat with the rudder attached directly to the transom without the stand off pintels? If so what percentage improvement did you feel it achieved by moving the rudders back?
2) What's the motivation for mounting the rear beam so close to the transom? Thanks for sharing your insight...
Regards, Bob It was to overcome a problem the F16's had started to get into design wise. We all have started moving the front beam back further in the boat like the A's basically to get the upwind Uni sail working better ( the uni sailor is not allowed to have a jib ) and bringing the Spinnaker COE back further into the boat to prevent pitch poling ( it does seem to do that ). Bitsa has got to the point in that despite quite fine bows, it will side slip rather than dig the nose in even when provoced to try and make it so. A part of that also is my belief that as an Uni sailor we are over square at 2.5m beam so reduced it to more the A's of 2.3m The problem lies with the box rules in that we have only a 8.5 m mast height allowed which then makes the sail much lower aspect than the A's and creates a much longer foot. That means then that the rear travellor has to be much further back than an A, so the beam has to go back further in the boat which then immediately flags up the short fulcrum arms. The 150mm gantry is a waste of time as far as leverage goes, it was just a method of getting the arms longer. There is an alternative to the arms we use and I wish I had used that method, Have a look at the C class boats, they use a much better, far less vulnerable to accident damage ( crew falling into the cross arm )and probably a lot lighter system. Knowing now the problems caused by the extra leverage of the gantry, I wouldn't do the same again particularly as we cannot fair the lower gantry in to make it more streamlined as per the box rules. Bitsa as we speak is in the workshop getting this mod done ready for next season, it has a load of benefits, moving the tiller mount point 400mm inside the rear beam and giving central sheeting. The downside is I will have two short tiller sticks rather than the more traditional long stick. | | | Re: Upwind - Fast -- Rudder "slip"
[Re: waynemarlow]
#222249 10/21/10 04:56 AM 10/21/10 04:56 AM |
Posts: 1,021 Australia | A part of that also is my belief that as an Uni sailor we are over square at 2.5m beam so reduced it to more the A's of 2.3m
I know I will regret asking this, but here goes anyhow: Why did you reduce the beam by 20cm? | | | Re: Upwind - Fast -- Rudder "slip"
[Re: macca]
#222250 10/21/10 05:10 AM 10/21/10 05:10 AM |
Posts: 893 | The hull bouyancy is marginal for the 15m main, yes I can get my lardy 95 kilos out on the wire to compensate but all that will do is sink the hull further creating wetted area and drag which means slow. So much better to reduce sail area and let the hull ride in its optimum level. Certainly proven with my current boat, having gone from 13.5m sail to 15m sail and then from 2.3m wide to 2.5m wide, I think the smaller sailed narrower boat was faster other than in light conditions. But Mecca I'm sure you will tell me that I am so wrong | | | Re: Upwind - Fast -- Rudder "slip"
[Re: macca]
#222263 10/21/10 08:11 AM 10/21/10 08:11 AM |
Posts: 5,525 | Slightly narrower beam seems to work for A cats.
Pete Pollard Blade 702
[Re: macca]
#222270 10/21/10 08:29 AM 10/21/10 08:29 AM |
Posts: 6,049 Sebring, Florida. | I think it depends on the wind. We all want to sail on one hull as much as possible, for reduced drag. A narrower boat will fly a hull sooner, with less righting moment, so in light air, that's what you want. But when the wind comes up, now you need more righting moment, so the same hulls, crew, etc. should go faster with a wider platform (more righting moment), right?
Blade F16 #777
[Re: macca]
#222271 10/21/10 08:30 AM 10/21/10 08:30 AM |
Posts: 5,525 | I don't know. Why don't you ask Pete Melvin?
I'm guessing you'd have to beef up the beams to make it wider. The wider platform would be less stiff and I've no idea how to correct that. The narrower beam would be easier to sail, "things" would be an inch or two closer and easier to reach.
So, I'd conclude the narrower beam would be one of many compromises.
If you can get Melvin to address the issue, I'd be greatful.
[Re: macca]
#222275 10/21/10 09:14 AM 10/21/10 09:14 AM |
Posts: 5,525 | Macca,you make no sense. The analogy between horsepower and beam is dubious at best. In cars the problem has always been getting power to the road. That requires matching engine and chassis. As power increases, chassis are redesigned to accommodate the increase.
The assumption here is that Pete Melvin is at the top of his field and his designs are among the best.
IF: wider beam are always better
Then: Pete Melvin desgins should always have wide beams.
Since the conclusion is demonstrably false, so is the premise.
FWIW, Ferrari doesn't know everything. Their cars don't win all races or sell to all upscale buyers. Iirc, Ferrari was one of the last builders to switch from drum to disc brakes.
[Re: pgp]
#222276 10/21/10 09:27 AM 10/21/10 09:27 AM |
Posts: 893 | OK then, which is fastest upwind a DNA A class or the latest all singing and dancing 10ft wide Melvin designed F20C. My money would have to say more times than not the A class. Ah now I quote from the DNA's own website "This weekend PJ sailed in Hellevoetsluis in force 5-6 in such a set-up (increased mastrake, striff battens) and he could easily beat a Nacra 20 carbon and the F18's upwind by saling both higher and faster (downwind the Nacra was a rocket). Now if everything can be believed from the internet | | | Re: Upwind - Fast -- Rudder "slip"
[Re: macca]
#222288 10/21/10 09:55 AM 10/21/10 09:55 AM |
Posts: 5,525 | You think Ashby would show?
2,772
guests, and 540
