jib set up #222859
10/28/10 09:43 AM
10/28/10 09:43 AM
pgp Offline OP
pgp  Offline OP
Does anyone have a picture? I seem to have lost some bits and can't quite remember how it goes. I'm referring specifically to those bits between clew and the traveler.
Thanks
Pete Pollard
Blade 702
Re: jib set up [Re: pgp] #222885
10/28/10 02:21 PM
10/28/10 02:21 PM
Pensacola, FL
C
Cab Offline
Cab  Offline
C
Pensacola, FL
Pete,
Here is a picture of mine. The sheet goes through the block at the end of the single line and then runs to two blocks at the base of the pelican striker, then back to the jib cleats. The 2 to 1 block with the twisted shackle goes to the clew.
Chris
Trident F16
Re: jib set up [Re: Cab] #222886
10/28/10 02:28 PM
10/28/10 02:28 PM
pgp Offline OP
pgp  Offline OP
Thanks Chris. Any complaints with this system? Is the twist shackle okay or does it need to be a swivel?
Pete Pollard
Blade 702
Re: jib set up [Re: pgp] #222899
10/28/10 07:07 PM
10/28/10 07:07 PM
twist shackle is fine
0 registered members (), 427 guests, and 27 spiders.
