Rudder Hum/board Hum #224566
11/23/10 10:34 AM
11/23/10 10:34 AM
PTP Offline OP
PTP  Offline OP
I know this has been discussed, but I thought I remember seeing a diagram of what the trailing edge should look like to eliminate hum. Anyone have a quick reference to it?
thanks
pp
Re: Rudder Hum/board Hum [Re: PTP] #224567
11/23/10 10:43 AM
11/23/10 10:43 AM
I don't know about a discussion thread but essentially all you do is bevel the inside trailing edge of each blade at 45 degrees...
Re: Rudder Hum/board Hum [Re: Jalani] #224570
11/23/10 11:33 AM
11/23/10 11:33 AM
I believe the current thought is to make the trailing edge asymmetric to reduce the hum. So angle one side of the trailing edge at a slightly different angle than the other and you should be okay...
Re: Rudder Hum/board Hum [Re: waterbug_wpb] #224575
11/23/10 12:41 PM
11/23/10 12:41 PM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
I find my random sawtooth pattern on the back of all my boards eliminates all humming very effectively.
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: Rudder Hum/board Hum [Re: Capt_Cardiac] #224580
11/23/10 03:49 PM
11/23/10 03:49 PM
Scarecrow
Scarecrow
AHPC has the diagram you're looking for in the Viper tuning guide. The point behind the procedure is to make your rudders very slightly asymmetric.
0 registered members (), 258 guests, and 37 spiders.
