| Hard to steer - balance? #22645 07/28/03 12:52 PM 07/28/03 12:52 PM |
Posts: 43 Austin, TX | Howdy-
Whenever I am out on the boat and the wind picks up I find it really hard to steer. I seem to remember reading something about rudder adjustments that would help put things into balance? Any suggestions? Thanks
-Brandon
N5.5u #424
Austin, TX
| | | Re: Hard to steer - balance?
[Re: MauganN20]
#22647 07/28/03 01:01 PM 07/28/03 01:01 PM |
Posts: 43 Austin, TX | As in it takes quite a bit of strength to hold the course.
-Brandon
N5.5u #424
Austin, TX
[Re: MauganN20]
#22649 07/28/03 01:38 PM 07/28/03 01:38 PM |
Posts: 43 Austin, TX | That makes two of us. Should not be too terribly difficult to figure out.
-Brandon
N5.5u #424
Austin, TX
[Re: Aggie97]
#22650 07/28/03 01:46 PM 07/28/03 01:46 PM |
Posts: 12,310 South Carolina | a) check that there are no weeds built up on the rudders.
b) check rudder alignment (this can certainly cause difficulty steering)
c) rake mast forward to get the center of effort closer to the balance point of the boat - near the daggerboards.
d) rake rudders forward (this doesn't actually eliminate the helm but it reduces the amount of it you feel by placing the center of lift of the rudders closer to the pivot point).
Jake Kohl | | | Re: Hard to steer - balance?
[Re: Rolf_Nilsen]
#22654 07/28/03 03:28 PM 07/28/03 03:28 PM |
Posts: 43 Austin, TX | Thanks folks, I'll give some of those suggestions a try, starting with the basics.
-Brandon
N5.5u #424
Austin, TX
[Re: Mary]
#22655 07/28/03 03:31 PM 07/28/03 03:31 PM |
Posts: 12,310 South Carolina | I did that on my TheMightyHobie18 once too - I had to tack the rudders so I could get back - it wouldn't even tack.
I am pretty sure that is much harder to do on a nacra since the union is bolted to the rudder arm - it won't hook to the tiller cross bar if it's on the other side because the union will be facing outboard.
Jake Kohl | | |
2,376
guests, and 222
