| Re: Can this board be fixed??
[Re: Bob Klein]
#22672 07/28/03 09:53 PM 07/28/03 09:53 PM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | Bob,
First of all -- "I feel your pain". I assume that the I18's boards are carbon fiber. Cha-ching! I had to have a board repaired on my ARC22 in May. It was cracked almost in half. Bottom line, $500 for a new one, $325 for the repair. -- Had it repaired. Yes, it as good as new. I know you'd hate to throw it away, and anything can be repaired. I guess you'll just have to see what it costs for the two alternatives. If you need the name of a couple of good carbon fiber guys, e-mail me.
Don Cook
ARC22 #2226
ADRENALIN
[Re: Bob Klein]
#22676 07/29/03 10:46 AM 07/29/03 10:46 AM |
Posts: 833 St. Louis, MO, | That board is very repairable. I would cut away the top part of the material where it is all dinged up on the end. If you can press it back together with your fingers to shape then you are ready to put it back together. If it resists pressing together start digging out stuff until it will go back together cleanly.
Get yourself some good epoxy.
You can vacume bag it back together or use a bunch of clamps. I recommend the vacume bag technique. Seperate the board as much as possible without breaking it anymore and squirt the epoxy up as far as you can using a siringe(sp?). Then squeeze it back together so that it comes back to shape with the vacume bag. Let it set for 24 hours.
Take the bag off and then it is just surface repair. Buy some fibreglass matt and use the epoxy again to wrap the end in a couple layers. You might need to grind out a little to get a good layup. Use 100 grit paper to rough up anything before you do a layup. Sand smooth and fill. Then gelcoat.
It's a bunch of work but very rewarding and you will have a stronger board than what you started with.
Mike Hill H20 #907
Mike Hill N20 #1005
[Re: Bob Klein]
#22677 07/30/03 07:54 AM 07/30/03 07:54 AM |
Joined: Jun 2001 Posts: 90 Québec, Canada CharlesLeblanc
Posts: 90 Québec, Canada | I just repaired one of my daggerboard from a Nacra 5.2. The top of the board was opened like yours and the foam was visible but the skin showed less damage
The previous owner tried to patch it with MarineTex or something like it but it failed.
I choosed polyester resin to repair mine because I think that my board was built with polyester. Epoxy boards should be repaired with epoxy.
I started by drying the board in the oven at 140F overnight.
I poured some acetone in the foam to wash away any grease. I dried it with compress air
I poured slightly thicken epoxy resin between the foam and the fibergrass to build back the foam. My fiberglass skin was not as badly damaged as yours so I simply clamped it back in place to let the epoxy cure.
After that I sanded the fiberglass skin away with a buffer and I left a taper edge (approx 10:1 angle) I washed it again with acetone and I build back the fibergrass with fiberglass and polyester. Finally I taped the repair with masking take to push the fibergrass cloth on the board and draoin the excess resin. I am pretty sure that I have a 50% fibergrass content or better. Once fully cured and sanded, I put some gel coat on it.
Charles Leblanc
Nacra 5.2 #26
2,705
guests, and 415
