| Minute drag reduction #227746 01/29/11 04:57 AM 01/29/11 04:57 AM |
Joined: May 2003 Posts: 4,451 West coast of Norway Rolf_Nilsen OP
Posts: 4,451 West coast of Norway | Following yesterdays excellent ideas thrown around on how to simplify setting/dousing spis. Here is another topic thrown around. Drag reduction from cables. The drag from the cables in the rigging is not large, so this is a minor component on speed compared to the loose nut on the tiller. Still, here is a small discussion on drag reduction in rigging as posted by Tom Speer on the landyacht forum. Freely rotating cable fairings have been tried many times in the past, without much success. There are several physical constraints on the problem that make it very difficult.
The aerodynamic center must be behind the axis of rotation for the fairing to be statically stable. The distance between the axis of rotation and the aerodynamic center must be great enough to overcome friction and to provide a natural frequency high enough to track wind gusts. The center mass of the fairing must be ahead of the axis of rotation to be dynamically stable against flutter. One would like the cable to be located near the thickest part of the section, or else the fairing will have excessively large frontal area. Different parts of the fairing must be able to rotate independently because of the change in apparent wind angle with height.
I suspect the fairings need to have tails attached in order to meet all these requirements. This makes the fairings heavier and more fragile. Not to mention adding additional wetted area.
A simple flat plate with its leading edge against the cable, possibly with ballast extending ahead of the cable, may prove to be the best design. Simply preventing the formation of the Karman vortex street using the splitter plate can result in a significant reduction in drag. Landyachts operate at far higher speeds than F16s so drag is much more critical. But I thought I would throw this idea out here and see what happened. | | | Re: Minute drag reduction
[Re: Rolf_Nilsen]
#227748 01/29/11 06:03 AM 01/29/11 06:03 AM |
Posts: 1,382 Essex, UK | I've wondered about a thin, flat' stiffener' inside of the weave of dyneema several times in order to keep it flat. If such a line were then used for rigging, would it automatically orient itself for least drag?
It'd not be perfect, but it might be less drag than 'round' rigging?
As I said, I've wondered - but I've not explored it at all......
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: Minute drag reduction
[Re: Rolf_Nilsen]
#227756 01/29/11 10:44 AM 01/29/11 10:44 AM |
Posts: 5,525 | Attach rigid sails directly to the rigging?
Pete Pollard Blade 702
[Re: pgp]
#227774 01/29/11 07:31 PM 01/29/11 07:31 PM |
Posts: 1,382 Essex, UK | You can already (for quite some time now) get aerofoil cross-section rod rigging and, naturally, it's expensive. The area is no greater than round s/s rigging - I'd always assumed that it must reduce drag and must also self-orient (twist) to some extent. I havn't seen it in use for ages now though so it may have been discontinued. Looking around though, I cme across this: Hall SCR
[Re: waynemarlow]
#227807 01/31/11 03:14 AM 01/31/11 03:14 AM |
Posts: 221 Netherlands | Hey Wayne, I use from the beginning 3 mm as main stay and 2,5 mm as front stays and this is more than enough to absorbe the load ( also in 2 up ) on the A-class i do use 2,5 mm mainstays and 2 mm front stays for about 8 years already and also this is more then enough to have no trouble. You are right that the spinaker kit in front is the biggest problem of drag on the F16, it is enormous and i do try to make a workable solution to get it reduced but not really found a good solution for it yet. In long distance races like Texel it would be better to have the spin in a bag on the trampoline because this saves a lot of drag and you never use the spin as much as in course racing where time of hoisting in more an issue. Regards, Hans http://www.catamaranparts.nlhttp://catamaranparts.blogspot.com | | | Re: Minute drag reduction
[Re: Hans_Ned_111]
#227808 01/31/11 04:55 AM 01/31/11 04:55 AM |
Posts: 893 | You are right that the spinaker kit in front is the biggest problem of drag on the F16, it is enormous and i do try to make a workable solution to get it reduced but not really found a good solution for it yet.
I think the integrated front beam and centre snuffer goes a long way toward solving this problem, it seems to work better than expected. With a bit more thought such as making the snuffer also the front stay mount, we get other benefits such as tight jibs and less weight in the hulls ( less reinforcing to take the inward stay loads needed )Bitsa is in the process folks to um shall we say take a further step in this direction, this summer. | | | Re: Minute drag reduction
[Re: waynemarlow]
#227809 01/31/11 06:39 AM 01/31/11 06:39 AM |
Posts: 3,528 Looking for a Job, I got credi... | You are right that the spinaker kit in front is the biggest problem of drag on the F16, it is enormous and i do try to make a workable solution to get it reduced but not really found a good solution for it yet.
I think the integrated front beam and centre snuffer goes a long way toward solving this problem, it seems to work better than expected. With a bit more thought such as making the snuffer also the front stay mount, we get other benefits such as tight jibs and less weight in the hulls ( less reinforcing to take the inward stay loads needed )Bitsa is in the process folks to um shall we say take a further step in this direction, this summer. Wayne, Does your under tramp box have the dolphin striker post thru the middle ?
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Minute drag reduction
[Re: scooby_simon]
#227811 01/31/11 07:27 AM 01/31/11 07:27 AM |
Posts: 893 | No, the sides of the snuffer box are beefed up just at the point of the dolphin striker intersection and take the loads of what would have been the post at the central point. The location ball for the mast simply is bolted through the upper part of the box and the loading is taken by a nut on the top surface. To tighten the dolphin striker all I did was put a couple of " shimms " between the striker bar and the snuffer box. As much as I used to hate the central beam, on going down that route a whole load of possibilities arise if we rethink things to make the central beam the main load bearing / snuffer structure and the hulls are just the floatation devices. Little things like the front beam could be moved way foward to strengthen and stiffen the hulls and yet the mast base could be moved about at will. Perhaps the front beam could be radiused as per the front jib traveller, the mast base reset according to single or double handed, the front of the hulls lightened as they no longer take any loading other than from the bouyancy aspect, the cross beams lightened as the load from the mast is now spread fore and aft by the central beam, lots of possibilities here guys but it need to be rethought completely. Weight would be probably be lighter overall and hull shapes would be better with less reinforcing ( weight ) and thus less hull volume needed in the front end. mmmmm would love to make a complete design change here. | | | Re: Minute drag reduction
[Re: Jalani]
#227827 01/31/11 10:38 AM 01/31/11 10:38 AM |
Posts: 571 Hamburg | I've wondered about a thin, flat' stiffener' inside of the weave of dyneema several times in order to keep it flat. If such a line were then used for rigging, would it automatically orient itself for least drag?
As I said, I've wondered - but I've not explored it at all...... No, it would put it squre to flow. That's because the aerodynamic forces act at about 25% chord from the leading edge, while the mass would be around 50% chord and the turning point (where the line is under highest tension) would be at 50% as well. Cheers, Klaus | | | Re: Minute drag reduction
[Re: Seeker]
#227828 01/31/11 10:41 AM 01/31/11 10:41 AM |
Posts: 571 Hamburg | Am I the only one that sees the Pink Elephant in the room? Did I miss something? I thought the whole idea of this thread was drag reduction...how in the world does putting a huge square box under the tramp reduce drag? What happens when that thing chokes on a big piece of chop? All this tweaking and redesigning of hull shape to make for the least resistance forward...then put something under the tramp that looks like it would stop the boat dead when sailing into steep chop/waves. Maybe the picture makes it look bigger than it actually is ...but at first glance this system looks like it would create more problems than it solves. True. And I may add that I still think that my furled hooter produce only insignificantly more or less drag than a conventional mid pole snuffer and all its wiring. Still the spi has more area than a hooter of same stay length though... | | | Re: Minute drag reduction
[Re: Seeker]
#227839 01/31/11 12:45 PM 01/31/11 12:45 PM |
Posts: 893 | Am I the only one that sees the Pink Elephant in the room? Did I miss something? I thought the whole idea of this thread was drag reduction...how in the world does putting a huge square box under the tramp reduce drag? What happens when that thing chokes on a big piece of chop? All this tweaking and redesigning of hull shape to make for the least resistance forward...then put something under the tramp that looks like it would stop the boat dead when sailing into steep chop/waves. Maybe the picture makes it look bigger than it actually is ...but at first glance this system looks like it would create more problems than it solves. Mmm a naysayer, can I ask a question, how much of the time does your front beam and striker hit the water at the moment. I tend to fly a hull all of the time I can including downwind for the very purpose of making sure the front beam doesn't hit the water, about the only time I see water any where near the striker is when tacking or gybing and thats when the boat is almost stopped anyway. Anyway fully accept your comments and acknowledge that there could be a possibility of being hit by the waves. This was just a quick knock up to prove a concept ( will the spinny fold in through the twin forestays ) but would comment that the Mk2 version has a fully enclosed underneath and there is no real opening beneath the beam as per the current setup for the water to get in. | | | Re: Minute drag reduction
[Re: taipanfc]
#227912 02/01/11 05:34 AM 02/01/11 05:34 AM |
Posts: 2,584 +31NL | Having a big steel box underneath your boat is a very bad idea for several reasons. -It basically is just a giant scoop and that will completely stop you when the frontbeam hits a wave. If the sail flushes out while a wave hits you have no wat to retrieve the sail without destroying it. But what are the odds? One in a million?  -In a normal pole-mounted snuffer the sail has an opportunity to dry whilst sailing upwind. | | |
10,481
guests, and 324
