| Re: Interchanging old rudder castings with EZ Loc
[Re: mmiller]
#228605 02/15/11 11:16 AM 02/15/11 11:16 AM | xanderwess
| xanderwess
Unregistered | I am of the impression that the old style are more desirable for racing, and it is common practice to upgrade the rudders themselves to the newer EPO2. | | | Re: Interchanging old rudder castings with EZ Loc
[Re: mmiller]
#228612 02/15/11 11:44 AM 02/15/11 11:44 AM |
Posts: 921 Alachua, FL | 1) Yes 2) See #1 3) Good question... Never tried that one. The older rudders, in my case, H20 housings fit fine on the newer pintels. You just need the proper bushing inserts. I also have made spacers to fit above the housing at the lower position to keep the rudder from bouncing up and down. Dave, you must be very careful in removing the old pintel screws. If they break, you will have a real issue. Trust me...I know. There is an aluminum dogbone moulded inside the hull that the SS screws go into. Perhaps Matt Miller can offer tips on removing the old screws.
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Interchanging old rudder castings with EZ Loc
[Re: mmiller]
#228614 02/15/11 12:23 PM 02/15/11 12:23 PM |
Joined: Jun 2001 Posts: 890 Dunedin Causeway, FL David Parker OP
Posts: 890 Dunedin Causeway, FL | 1) Yes 2) See #1 3) Good question... Never tried that one. . Thanks. So the pintle replacement is not a problem, except for the cost, that's great to know. If someone has access to 2 boats where one has the old metal castings and the other has the new EZ Loc, would you please try to hang the old castings on a boat which uses the new EZ Loc system? See if it fits OK and if it does, see whether the keeper pin or clip would function to hold the old castings on in case of a capsize. Doesn't SOMEONE out there swap between the two systems? | | | Re: Interchanging old rudder castings with EZ Loc
[Re: Mugrace72]
#228680 02/16/11 09:20 AM 02/16/11 09:20 AM |
Posts: 890 Dunedin Causeway, FL | Dave, you must be very careful in removing the old pintel screws. If they break, you will have a real issue. Trust me...I know. You are so right! I pounded with a hand impact driver til my hands hurt and succeeded in loosening only one of eight of the screws of the lower pintles. How can you get those things out? Is this hopeless? I don't want to drill all 12 screws (upper and lower, larboard and starboard). | | | Re: Interchanging old rudder castings with EZ Loc
[Re: David Parker]
#228688 02/16/11 12:58 PM 02/16/11 12:58 PM |
Posts: 921 Alachua, FL | How can you get those things out? Is this hopeless? I don't want to drill all 12 screws (upper and lower, larboard and starboard). The only way I know is to have the right tools and hope for the best. Once the screw head breaks off, you have one opportunity to try and dill through the screw shank without the drill wandering to the side. You need to use a brand new bit about half the diameter of the srew. Once you have that hole drilled, you can progressively enlarge it so as to take the correct size tap. Here is where it really gets tough. If you break the tap, you are dead in the water. If things realy go south, you will have to fit hatch covers and use through bolts. That isn't entirely bad, just not as neat. BTW, you asked about swapping back and forth...once you have the new pintles, it will work fine. You saw my old style rudders mounted on the new style pintles. Good luck Dave.
[Re: Mike Fahle]
#228830 02/18/11 10:42 PM 02/18/11 10:42 PM |
Posts: 921 Alachua, FL | Right Dave. Left hand drill bits are a good idea, but usually these screws are so corrodeded in that they still won't back out. Still, I agree with Mike and Rick. Well worth a try.
428
guests, and 413
