Re: Nacra Infusion Mk2; where Art Thou? [Re: JFR] #228552
02/14/11 09:30 AM
02/14/11 09:30 AM
JACKFLASH Offline
JACKFLASH  Offline
I recently looked into after market boards for my Infusion from a UK composite company. I don't remember the name of them but they had a listing for boards for Infusion, Tiger, and Wildcat. The price was twice that of what I payed for the Nacra boards which appear to be pretty darn good quality. I just wish Nacra would have drilled the upf*cker hole because I don't want to take the drill bit to my pretty new boards.
Collin Casey
Re: Nacra Infusion Mk2; where Art Thou? [Re: JACKFLASH] #228557
02/14/11 11:25 AM
02/14/11 11:25 AM
mikekrantz Offline
mikekrantz  Offline
Drill the hole oversized. Fill with chopped glass/epoxy. Then re-drill the smaller hole for the upf*cker line.
Re: Nacra Infusion Mk2; where Art Thou? [Re: mikekrantz] #228586
02/14/11 11:46 PM
02/14/11 11:46 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Mike,
I've tried that technique on my hollow HT rudders with only modest success. The mixture seems to sag away some. Just not thickened enough? Other tricks?
Dave
Re: Nacra Infusion Mk2; where Art Thou? [Re: davefarmer] #228590
02/15/11 07:48 AM
02/15/11 07:48 AM
mikekrantz Offline
mikekrantz  Offline
Not thick enough. Tape one side and lay it horizontal ro set.
Re: Nacra Infusion Mk2; where Art Thou? [Re: mikekrantz] #228609
02/15/11 11:34 AM
02/15/11 11:34 AM
Anacortes
Sloansailing Offline
Anacortes
You can glue G10 rod in as well and then drill that. No sagging schmoo.
Anacortes Rigging.com
Rigging and Yacht Services
Re: Nacra Infusion Mk2; where Art Thou? [Re: Sloansailing] #228625
02/15/11 02:53 PM
02/15/11 02:53 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I put a 3mm dyneema into my starboard board. I just drilled a 3mm hole all the way through, then drilled it out a bit bigger on the far side for the knot to fit. put the line through the hole, tied a knot, covered it with epoxy stick, then gelcoat, can't even tell where it was and I've had no issues. I guess you could use regular epoxy but all your trying to do is seal the hole and I wanted to be able to remove it relatively easy incase I ever needed to access it.
0 registered members (), 21,587 guests, and 553 spiders.
1 hour ago
