Re: Accessing backing plates in Infusion [Re: Team_Cat_Fever] #228626
02/15/11 02:55 PM
02/15/11 02:55 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
My upper adjusting eye screw is seized in the rudder casting. Any remedies on how to get that bugger to break free??
Philip
USA #1006
Re: Accessing backing plates in Infusion [Re: P.M.] #228627
02/15/11 03:09 PM
02/15/11 03:09 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Philip: I had the same problem. Hitting the casting with a heat gun and soaking it in PB Blast helped, but the eyebolt was not reusable.
Re: Accessing backing plates in Infusion [Re: ThunderMuffin] #228628
02/15/11 03:15 PM
02/15/11 03:15 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
That's fine, I just don't want to break the head off trying to get it out.
Philip
USA #1006
Re: Accessing backing plates in Infusion [Re: P.M.] #228629
02/15/11 03:19 PM
02/15/11 03:19 PM
Portland, Maine
Portland, Maine
I also clamped the eyebolt in a bench vice to get enough torque on it. Your mileage may vary.
Re: Accessing backing plates in Infusion [Re: P.M.] #228631
02/15/11 04:17 PM
02/15/11 04:17 PM
catman Offline
catman  Offline
Snobol is very good at removing the corrosion. The thick stuff stays where you put it. Put some on and let it sit over night, rinse and repeat. Use patience, it didn't get corroded over night and you won't clean it out overnight.
Re: Accessing backing plates in Infusion [Re: ] #228694
02/16/11 04:18 PM
02/16/11 04:18 PM
if you've laminiated in a stainless steel backing plate, would it not suffer from that anaerobic corrosion that I've seen some shroud plates erode from on leaners?
Re: Accessing backing plates in Infusion [Re: waterbug_wpb] #228702
02/16/11 07:24 PM
02/16/11 07:24 PM
catman Offline
catman  Offline
I think the type of stainless matters and whether or not it's been electro plated.
Re: Accessing backing plates in Infusion [Re: catman] #229132
02/28/11 11:58 AM
02/28/11 11:58 AM
On the Water
P.M. Offline
P.M.  Offline
On the Water
Snobol?. . . as in the toilet bowl cleaner?
Philip
USA #1006
Re: Accessing backing plates in Infusion [Re: P.M.] #229139
02/28/11 03:24 PM
02/28/11 03:24 PM
catman Offline
catman  Offline
Yes.
0 registered members (), 389 guests, and 1,275 spiders.
