| Re: Accessing backing plates in Infusion
[Re: Team_Cat_Fever]
#228626 02/15/11 02:55 PM 02/15/11 02:55 PM |
Posts: 2,490 On the Water | My upper adjusting eye screw is seized in the rudder casting. Any remedies on how to get that bugger to break free??
Philip USA #1006 | | | Re: Accessing backing plates in Infusion
[Re: ThunderMuffin]
#228628 02/15/11 03:15 PM 02/15/11 03:15 PM |
Posts: 2,490 On the Water | That's fine, I just don't want to break the head off trying to get it out.
[Re: P.M.]
#228631 02/15/11 04:17 PM 02/15/11 04:17 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Snobol is very good at removing the corrosion. The thick stuff stays where you put it. Put some on and let it sit over night, rinse and repeat. Use patience, it didn't get corroded over night and you won't clean it out overnight.
[Re: ]
#228694 02/16/11 04:18 PM 02/16/11 04:18 PM |
Posts: 5,590 Naples, FL | if you've laminiated in a stainless steel backing plate, would it not suffer from that anaerobic corrosion that I've seen some shroud plates erode from on leaners?
[Re: catman]
#229132 02/28/11 11:58 AM 02/28/11 11:58 AM |
Posts: 2,490 On the Water | Snobol is very good at removing the corrosion. The thick stuff stays where you put it. Put some on and let it sit over night, rinse and repeat. Use patience, it didn't get corroded over night and you won't clean it out overnight. Snobol?. . . as in the toilet bowl cleaner?
20,780
guests, and 1,475
