Rudder castings #23061
08/08/03 07:32 PM
08/08/03 07:32 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
I'm in the process of cleaning up my rudder systems (i.e. slop, hum, rake...) but the bolts going through the upper castings are frozen.
Does anybody know if the castings are threaded or if my bolts are truley frozen and can safely be knocked through???
TSU
Tim S. Urfer 1984 Nacra 5.2
Re: Rudder castings [Re: TSurfer] #23062
08/08/03 09:08 PM
08/08/03 09:08 PM
PSAILOR Offline
PSAILOR  Offline
They are not threaded, prob. stuck with salt and corrosion. Try turning them back and forth with the nuts off and then carefully tap them through over a vise or something to support the casting.
Re: Rudder castings [Re: TSurfer] #23063
08/09/03 08:35 AM
08/09/03 08:35 AM
Ontario, Canada
av8or Offline
av8or  Offline
Ontario, Canada
I have used a propane tourch to heat the bolt then turned the head back and forth till it was free. Careful not to apply heat to the casting though.
Re: Rudder castings [Re: PSAILOR] #23064
08/10/03 10:41 PM
08/10/03 10:41 PM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
Thanks for the tips folks.
I'll give 'em try and let you know the results on this post.
TSU
Re: Rudder castings [Re: TSurfer] #23065
08/11/03 11:18 AM
08/11/03 11:18 AM
San Francisco
TSurfer Offline OP
TSurfer  Offline OP
San Francisco
A little twisting and tapping was all they needed.
Thanks again.
TSU
0 registered members (), 2,049 guests, and 501 spiders.
