| Re: Input; Developing Hi Wind,1 person,Uni spin system
[Re: john p]
#23106 08/16/03 07:59 AM 08/16/03 07:59 AM |
Posts: 552 | John, 1. Inside my front cross beam,..other than the beam-to-hull support bolts and the mast bar,....is nothing. 2. For the interested parties John,..using the diagram attached to Jakes posting,...walk us through this one more time......thanks  regards, Bruce | | | M20 Snail?
[Re: brobru]
#23108 09/12/03 07:31 PM 09/12/03 07:31 PM |
Posts: 1,200 Vancouver, BC | Have you seen the spinnaker fulrer setup on the Marstorm M20? It's a snail-shaped shell with a roller drum inside, all mounts just in front of the mast. The roller is parallel to the front beam and the snail opening faces towards the front. Though I've not seen it up close, it must have a line to roll the roller and spool in the spinny. Has the advantage of being extremely compact, low windage and fast (perhaps faster than a snuffer). Looks real Wiz-Bang with the fancy snail shape made from Carbon. From thinking more about how it works, one could likely be fashioned out of an old plastic bucket. Heck, you could even do away with whole shell completely and just run a snuffer-style hoop (mouth) at the front to feed the sail onto a horizontal roller drum.
Mike.
| | | Re: M20 Snail?
[Re: Tornado]
#23109 09/12/03 11:32 PM 09/12/03 11:32 PM |
Posts: 552 | mike, Sounds interesting,.........anyone have a pic or a link?........i went to the Marstrom site,........did not see this.. regards, Bruce St. Croix | | |
2,965
guests, and 281
