| Re: F16 and Curved Boards
[Re: scooby_simon]
#232962 05/30/11 10:18 AM 05/30/11 10:18 AM |
Posts: 1,021 Australia | Ahh, Hans thinks he is agreeing with me but infact...
I believe that the curved boards will be easy to get an increase in performance with for even your average sailor.
On the a class you are constantly trying to reduce drag, downwind you dont have the option of doubling your sail area and as such you need to sail the boat very differently.
The F16 will be markedly quicker and easier to sail downwind with curved boards, dont gat caught up with all the discussion on shorter WL making it harder to sail with, the curved boards are never at an AOA that is having a negative effect of performance, unless you really screw up, but even then they are helping with your recovery from a nosedive etc.
The downsides are this:-
Added tooling costs added production costs you have to raise the windward board each tack/gybe to get best performance there is a slight loss of righting moment, but the reduction in drag is compensation for this in the overall picture.
As to wayne's comment that the tooling cost is irrelevant... depends on the barrier to entry point, if the tooling is going to cost 15k (more than the hull tools) then its a big issue to factor in to the build costs. and I dont see anyone with F16 numbers in the 300's Hell even the Viper numbers are inflated and they are claiming 160 after 4 years production... makes the ROI seem pretty bad for a board tool. every now and then someone claims that their sisters uncle's neighbour can make a curved board tool for 20 bucks... but in reality its just an expensive thing to make a production quality tool for these things,
[Re: Seeker]
#232968 05/30/11 11:14 AM 05/30/11 11:14 AM |
Posts: 1,021 Australia | With all the variations of A cat curved boards being experimented with are there any "existing" A cat curved boards that could be fitted for use in an F16 effectively? $20 for tooling?...no but the $15,000.00 estimate is just as absurd on the other end of the scale. A CNC machine doen't care if its a curved board or a straight one.
Things get so ridiculously overstated on these forums...speeds, weights, costs...very rarely are things kept in the world of reality...and they think fishermen overestimate...obviously they never met a cat sailor. Try actually building the tools for a production run of curved foils, then after you have successfully built foils that are of the correct shape, twist and bend all the while not breaking in the kind of use that they need to withstand and then you can tell us all how much it really costs. I bet you end up a lot closer to my estimate that you thought... | | | Re: F16 and Curved Boards
[Re: macca]
#232969 05/30/11 11:41 AM 05/30/11 11:41 AM |
Posts: 5,525 | Sounds like a very nice cottage industry for a skilled craftsman.
Pete Pollard Blade 702
[Re: pgp]
#232970 05/30/11 12:01 PM 05/30/11 12:01 PM |
Posts: 932 Solomon's Island, MD | Clearly Macca is including R&D costs in his $15,000 budget, which I can see as being reasonable.
However, my estimate puts mold costs at <$5000, and it doesn't matter really if its curved or straight, twisted etc., just means you need to find a 5 axis CNC vs. a 3 axis CNC. How many out there have designed something and then built it? Namely how many have designed and built molds? I have and its not a trivial process. You need an aero engineer that knows what he is doing for the foil design, you need a solidworks or other CAD package guru to model the foil properly, and you need a mold guru to aide the CAD guy in tooling design. Then you need a structures expert to design a layup schedule that won't explode under sailing loads, which are hard to predict making his job difficult. Where you spend the money is important, you can reduce the production costs with good design work but often it is easier and safer with composites to build the piece, load test it and make changes to the layup from there. Of course this all has to be repeated to some extent if the foils are asymmetrical.
Scorpion F18
[Re: samc99us]
#232976 05/30/11 01:41 PM 05/30/11 01:41 PM |
Posts: 893 | Clearly Macca is including R&D costs in his $15,000 budget, which I can see as being reasonable.
So take the real world example of the Viper, $ 15000 / 160 boats = 94 bucks a boat for development and moulds to have the latest all singing and dancing board design intergrated into the latest design and to be one step ahead of your competitiors, seems a no brainer to me. Nacra with their design knowledge should be first out of the start blocks. Bimare are already in a position to give an option with their design of case, DNA with their skills and design should be looking to expand their production in a Uni only boat, it is going to happen guys and sooner than what we think. | | | Re: F16 and Curved Boards
[Re: waynemarlow]
#232978 05/30/11 04:17 PM 05/30/11 04:17 PM |
Posts: 4,119 Northfield Mn | People who are worried about their boats being suddenly obsolete, it will be eventually anyway. Curved boards or not.
[Re: taipanfc]
#232988 05/30/11 08:36 PM 05/30/11 08:36 PM |
Posts: 932 Solomon's Island, MD | I don't think this moves the boat out of reach for the homebuilder. Here's my reasoning:
1) I'm an engineer and can design a working curved foil solution if I feel like dropping the money to make it happen. I'd likely blow up a lot of boards and the performance may be sub par but it can be done. 2) I can just as easily buy a set of curved foils from a major manufacturer and fit them to my boat. Once again this may be sub par as board location and trim are critical. Granted several people in the A-Cat's are doing this with success.
As far as manufacturer support, I think it will happen. Enough big players have experience with the technology that the costs should remain reasonable and even if R&D is pegged at $30K and production of the boat is say 100, $300 per boat is still pretty reasonable for the chance to literally fly around the course.
Scorpion F18
[Re: Seeker]
#234994 07/20/11 10:57 AM 07/20/11 10:57 AM |
Posts: 465 FL | Quote from SA: http://forums.sailinganarchy.com/index.php?showtopic=105814&st=50>Then we set the kite and left the boards fully down and Adam jumped on the wire, you feel instantly that the boat is lifting on the foils. Its very easy to get the whole boat out! We did this a few times and couldn't stop laughing! It's seriously the most fun you will ever have on a beach cat. For sure the full boards down option is not the fastest in the conditions we had (25kts by this stage) but it's a crazy amount of fun and very addictive.. Anyhow, sanity prevailed and we lifted the boards 30cm and tried again: This is the quickest I have ever been on a beach cat downwind. Pete was only just keeping up in the coach boat at full throttle. The slightly higher board setting still gives lift and the boat is semi foiling the whole time. You can feel that the steering becomes super sensitive and your speed increases as you keep the boat in the groove. It was around this time that I said to Adam: "this is the future of catsailing" It's a whole new dimension to the sport, The added speed and feeling the boat gives you is something I want to do again and again. I would have stayed out all day if it was possible!< | | | Re: F16 and Curved Boards
[Re: sail7seas]
#235485 07/30/11 12:20 PM 07/30/11 12:20 PM |
Joined: Jan 2011 Posts: 14 Lincoln, Nebraska FRENZIED
Posts: 14 Lincoln, Nebraska | I want straight boards. Don't wanna mess with hydrofoiling curved boards. Don't want to pay for the extra hoo-hah either. Simpler is better, IMHO.
LANDLOCKED
1 registered members (JesperS),
234
guests, and 47
