| Spinnaker sheets' ratchet blocks #233589 06/16/11 06:16 AM 06/16/11 06:16 AM |
Posts: 92 South Oz | Seems the Ronstan RF42100 is difficult to source. What is the fleet using? Any comments regarding the Orbit series 40, RF46101 as a suitable replacement.
Tortured ply is clearly beautiful. Mozzie Aldebaran VI 1827
| | | Re: Spinnaker sheets' ratchet blocks
[Re: Phillip]
#233624 06/16/11 04:57 PM 06/16/11 04:57 PM |
Joined: Jan 2007 Posts: 81 To windward of you! Sixth Element
Posts: 81 To windward of you! | hi Phillip,
our 3 LBYC spinnaker boats are using the 40 series orbits, i have found them to be good. just have to keep the sand out of them. Im running the orbits all over my boat and havent had any issues.
"Sixth Element" 1782 MK2 w/spinnaker. Lake Bonney Y.C. National Sec. / S.A President / S.A Measurer / Commodore LBYC
[Re: Sixth Element]
#233627 06/16/11 06:17 PM 06/16/11 06:17 PM |
Joined: Mar 2010 Posts: 77 Gippsland Lakes mitchellsailor
Posts: 77 Gippsland Lakes | Would you be interested in buying an "as new" set of the original ronstan adjustable ratchets? I think I paid $50 for them delivered when they were in the ronstan clearance store, Gary will probably jump in here but the orbit blocks were too sensitive in engaging the ratchet making jibes harder, where as the original ones are adjustable. cheers
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
[Re: mitchellsailor]
#233750 06/20/11 04:56 AM 06/20/11 04:56 AM |
Posts: 92 South Oz | Thanks for the offer mitchellsailor but as I am still researching, seeking further responses, will hesitate for the moment. Please ellaborate on 'as new'. If they are available, does it mean you no longer run a spinnaker?
[Re: Peter_Lyons]
#233759 06/20/11 06:35 AM 06/20/11 06:35 AM |
Posts: 92 South Oz | Thanks guys, Orbit blocks, rf46101, Automatic or rf46102 Man/Auto. What is the better option guys? Same price!
[Re: Tornado_ALIVE]
#233832 06/20/11 06:09 PM 06/20/11 06:09 PM |
Posts: 242 Brisveagas | I'm going to give these a go. Selden Blocks Have the ronstan ones on my viper at the moment and my crew hates them. I expect the selden stuff to be just as good as harken. Already changed some of the other blocks to this stuff and they are just awesome. I'll let you know. Damn link doesnt work. Just cut and paste this in. http://www.seldenmast.com/products/?itemID=36&modelID=71
Aido Viper 288
[Re: Phillip]
#233835 06/20/11 09:12 PM 06/20/11 09:12 PM |
Joined: Aug 2007 Posts: 142 3 weeks Newman WA 1 week Robe ... Brian P
Posts: 142 3 weeks Newman WA 1 week Robe ... | hi phillip, i run the ronstan 46101, auto. on my stingray with 21 sq.m. kite. and my crew swears by them. really good grip, very lttle pressure even in 20 knots they grip really well. never a problem thru gybes. my crew sam has the same on his elliot 7.8 sportsboat, mind you he runs the 57mm size but he also has a 56 sq.m kite!!! if you can get them cheap they definately the best to go for.
Brian Partridge STINGRAY 580 "Fantasia" A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD BUT YOU CAN ROLL IT IN GLITTER!!!!!
[Re: Matt_Stone]
#233839 06/21/11 04:28 AM 06/21/11 04:28 AM |
Posts: 1,669 Melbourne, Australia | hey guys
Stev - does the freight come to your door?
Sure do Matt..... or as I do, get them sent to your work. It is funny, when purchasing through the Mauripro site, the Ronstan units get sent all the way to the US from AUS, then they ship them to you in the AUS and you still get them for more than 1/2 the price you see in shops! Personally I have found the failure rate of the Harken ones a lot less than the Ronstan units. As mentioned above, you can adjust the Harken units but not the Ronstan. Harken are slightly bigger and a tiny big heavier and are secured with a shackle as you have mentioned. Ronstan are of course cheaper, even through the Mauripro site, so weigh up what is important for yourself....... I have used both and they both worked. | | | Re: Spinnaker sheets' ratchet blocks
[Re: Tornado_ALIVE]
#233841 06/21/11 04:57 AM 06/21/11 04:57 AM |
Posts: 416 | its disappointing to see that site now, that i cant get them in cheaper than that. best i can do is $75 each
[Re: Matt_Stone]
#233844 06/21/11 06:06 AM 06/21/11 06:06 AM |
Posts: 242 Brisveagas | Ronstan need a kick in the butt over that one.
Just fecked IMO.
Aido Viper 288
#234053 06/26/11 02:21 AM 06/26/11 02:21 AM | thricebitten
| thricebitten
Unregistered | Would you be interested in buying an "as new" set of the original ronstan adjustable ratchets? I think I paid $50 for them delivered when they were in the ronstan clearance store, Gary will probably jump in here but the orbit blocks were too sensitive in engaging the ratchet making jibes harder, where as the original ones are adjustable. cheers I know I am a bit late replying to this topic, but I don't switch the home computer on that much any more, spend to much time on the computer at work these days  , just want to get away from it week nights  . Yes I think the old Ronstan Auto Ratchets where better as you could adjust them to come on at a high sheet pressure, I am currently using the smallest size of the new Ronstan Orbit Auto Ratchet, I believe they are too sensitive and tend to stay on when you are gybing so the old sheet doesn't run out as easy  . They do have advantages though, they are lighter and they attach easily as Matt said with the rope base, no need for more shackles  . But I must say wherever possible I do shop locally  , if we don't support our local chandlery's, they will dissapear  and how then will we be able to touch and feel different fittings and make comparisons  , compare the advantages of different brands, work out which one does the best job that sort of thing, does the rope run freely? Of course it still comes back to availabilty and price as well, but they are not the only motivators, if the shop is doing a good job and offering a service, by offering a good range of product, in stock ready to sell that you can pick from straight away, that is something I am willing to pay a little more for. Lastly time to address the Elephant in the room  . Mitch M why are you offering to sell your spinnaker blocks? | | |
2,591
guests, and 408
