Page 3 of 3 1 2 3
Re: TMS-20 update 6/17 [Re: waterbug_wpb] #234178
06/28/11 05:25 PM
06/28/11 05:25 PM
the different colors can actually work to your advantage in they help you see how the fairing is going. I would suggest a light color rather than a vivid one so it won't show through on the final product.
Maybe a light grey under a white topcoat?
I don't rely on different colored material. I close my eyes while rubbing my hands over the faired spot while muttering "na na na na na na na".
Re: TMS-20 update 6/17 [Re: Jake] #234203
06/29/11 09:58 AM
06/29/11 09:58 AM
be the boat.... beeee the boat....
Re: TMS-20 update 6/17 [Re: waterbug_wpb] #234233
06/30/11 04:48 PM
06/30/11 04:48 PM
Palm Beach County
TheManShed Offline OP
Palm Beach County
Funny but on small spots I use the eyes closed method first. Some people have a good touch, I happen to blessed with a good touch. Sometimes I'll shoot just a dusting of light gray lacquer primer because it gets sanded off. Then I use lacquer thinner to remove the left over paint on the low spots once they are identified.
I used bondo in the past but not any more since I've switched to epoxy. Bondo will still absorb water and gel coat is porous no matter what anybody says. But for cats that live most of their life on a trailer it is negligible. I use West System with the light filler I think it is 410 that is cream colored.
Mike Shappell
www.themanshed.com
TMS-20 Builder
G-Cat 5.7 - Current Boat
NACRA 5.2 - early 70's
Re: TMS-20 update 6/17 [Re: TheManShed] #234234
06/30/11 04:52 PM
06/30/11 04:52 PM
pgp Offline
pgp  Offline
That's why I like to wet sand, it enhances touch, imo.
I'm back to bondo, there just isn't a good source of material here.
As for gelcoat being waterproof, if it is how come leaners have such a terrible time with blisters?
Pete Pollard
Blade 702
Re: TMS-20 update 6/17 [Re: pgp] #234237
06/30/11 06:40 PM
06/30/11 06:40 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
They sit in the water all of the time.
Re: TMS-20 update 6/17 [Re: TheManShed] #234242
06/30/11 09:43 PM
06/30/11 09:43 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
I use the 410 for most final fairing, but I often get pinholes from tiny bubbles. I now use Dolping Glaze, an automotive glaze specifically for such minor imperfections. It goes on real smooth, and sands effortlessly. It's a 2 part polyester, not epoxy, but I've not had any problems with it. And I'm getting great life and gloss out of high quality auto paints. Flight Risk's paint is now 7 years old, and it's still glossy everywhere I haven't scraped it off.
Dave
FR eee.jpg (130 downloads)
Re: TMS-20 update 6/17 [Re: davefarmer] #234262
07/01/11 11:52 AM
07/01/11 11:52 AM
Dave,
Great picture, but is there a reason that boom gooseneck is so low on the mast, and the foot of the main so high? Seems that you could either squeeze in a little more sail area, or raise the boom up a bit.. But I'm sure there's a good reason it's set up that way....
Re: TMS-20 update 6/17 [Re: waterbug_wpb] #234275
07/01/11 02:21 PM
07/01/11 02:21 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Shortly after I bought the boat the wingmast mysteriously broke 6' above the deck. Malcom, the builder, suggested moving the gooseneck to the main beam(like ORMA 60s) to eliminate boom induced forces on the mast. It's worked just fine, and it's easy to get across the tramp, either fore or aft, and mast rotation is induced otherwise. After the modification, the general consensus came to be that the mast was probably damaged in transit at some point. So I could move it back up to the mast, but I'm generally lazy. So sloth is the real reason the boom is rigged that way.
Dave
Re: TMS-20 update 6/17 [Re: davefarmer] #234325
07/04/11 01:41 PM
07/04/11 01:41 PM
Palm Beach County
Palm Beach County
I like that term "Leaners" HA!
Mike Shappell
www.themanshed.com
TMS-20 Builder
Re: TMS-20 update 6/17 [Re: TheManShed] #234549
07/08/11 08:33 AM
07/08/11 08:33 AM
pgp Offline
pgp  Offline
Has anyone used xynole-polyester fabric?
Pete Pollard
Blade 702
Page 3 of 3 1 2 3
0 registered members (), 413 guests, and 45 spiders.
