| Re: Chicken lines...how to use them?
[Re: Just Sail]
#234804 07/13/11 12:31 PM 07/13/11 12:31 PM |
Posts: 129 Austin, TX | You put jam cleats on your harness spreader bar.
Bo Kersey Corsair 31-1D 276 | | | Re: Chicken lines...how to use them?
[Re: Just Sail]
#234810 07/13/11 02:18 PM 07/13/11 02:18 PM |
Posts: 1,152 tampa, fl | I have searched endlessly for a jam cleat screws from the side. To date, I have yet to find one. I took my spreader bar to a machine shop and had them weld a stainless steel plate to the bar that the cleat could mount to. That works just fine. Another option is to tie S hooks on the chicken line. With some fancy rigging you can make them easily adjustable. Just be sure the S hook is hooked to the dogbone, not any part of the crew so in event of a capsize, the crew won't be left hanging (literally)
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Chicken lines...how to use them?
[Re: BoK]
#234847 07/14/11 07:43 AM 07/14/11 07:43 AM |
Posts: 1,152 tampa, fl | Thanks man.....I have been looking all over for those!
[Re: spfechner]
#234853 07/14/11 08:21 AM 07/14/11 08:21 AM |
Posts: 129 Austin, TX | What happens when you are cleated in and you pitchpole? You are much less likely to pitchpole if the crew is locked in on the chicken line. You'll find that the boat will stuff and recover in all but the worst situations.
[Re: Dan_Delave]
#234876 07/14/11 09:49 PM 07/14/11 09:49 PM |
Posts: 337 Arizona | I use hooks, tied to the transom and bungeed into the crossbar, which only attach to the trapeze handle.
Dan What kind of hooks do you use Dan?
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: Chicken lines...how to use them?
[Re: Tornado_ALIVE]
#234934 07/18/11 11:33 AM 07/18/11 11:33 AM |
Joined: Mar 2002 Posts: 984 2017 F18 Americas Site Dan_Delave
Posts: 984 2017 F18 Americas Site | I used to use that hook but now use this one: ![[Linked Image]](http://www.catsailor.com/gallery/albums/userpics/10093/ChickenHook.jpg) WICHARD Stainless-Steel Snap Hooks Tornado Alive has a picture that is close to how I set mine up. I do not use a block to pull it into the crossbar. I splice the bungee into the chicken line at the point that I want to be furthest inside. If you have a large enough hole in the end of the crossbar you can tie it so that the hook will lay right inside the hole. I use a small line that will hang out to retrieve when needed. This is the way to keep it from hooking a line inadvertently. Dan DeLave | | | Re: Chicken lines...how to use them?
[Re: Dan_Delave]
#234943 07/18/11 11:23 PM 07/18/11 11:23 PM |
Posts: 337 Arizona | how do you splice it into the line? You wouldnt have a pic would you. I should be at Wine and Roses in a few weeks. Will be racing Sunday. I could peek at it then I guess. I dont know if you F18 guys will be able to convince us that its a good idea to race against you this time though. We looked pretty silly last year. But we had a great time! I would like to talk to you guys more this year and get a closer look at your boat setup. You going to W&R
[Re: AzCat]
#234946 07/19/11 09:27 AM 07/19/11 09:27 AM |
Posts: 32 | I touched on this in the original post of this thread but had no response to it. Does anyone use foot straps to achieve the same result as the chicken lines. Here is a video that looks like they use foot straps instead. Is anyone doing this? http://www.youtube.com/watch?v=O_U9cjQRoso
[Re: Just Sail]
#234948 07/19/11 12:56 PM 07/19/11 12:56 PM |
Posts: 291 | My experience is that in a hard stuff the foot strap is hard to hold onto with your foot. You also run the risk of a twisted/broken ankle or a hyperextended leg. The foot strap is nice in a bouy race where you are running a mile or so downwind and the waves are only a foot or so. Generally in that type of situation there will probably be a gybe or two in there as well in which case the chicken line becomes more cumbersom than it is worth for such a short run. In the big waves or when running for a long time such as in a distance race there is no substitute for a chicken line. During the GT we used both as waves tend to try and knock your feet out from under you.
540
guests, and 32
