| Re: Boat Design: Boat Width, Sail Area vs. Pitch Pole
[Re: Wouter]
#23512 08/26/03 09:27 AM 08/26/03 09:27 AM |
Joined: Nov 2002 Posts: 612 Cape Town, South Africa Steve_Kwiksilver
Posts: 612 Cape Town, South Africa | Hmm. Wouter, what I THINK you`re saying is that if you widen a boat`s beam you put more load on the leeward hull in strong breeze, perhaps so much that the bouyancy of the leeward hull is not enough to support the additional load, so the whole hull starts to submerge, never mind the bow ? So in order to take an existing design & widen the platform, first you would need to re-design the hulls to have more bouyancy in general, preferably with a healthy percentage of it up front, unless the hulls are very bouyant to start with. So in effect you start again, and design a complete new boat. There has to be a limit as to how much width you can put on an existing hull design. Making a Hobie 16 wider will only increase the distance you fly after that inevitable pitch-pole !
Steve | | | Foils
[Re: alphaomega44]
#23515 08/26/03 12:39 PM 08/26/03 12:39 PM |
Posts: 1,307 Asuncion, Paraguay | Simon,
Bill answered in previous posts that he did some experimenting using two different hulls in a cat: a normal one and a planing one. He tacked to compare the relative performance in identical conditions.
Apparently there was about 5% gain downwind but the slaming and pounding upwind was terrible.
One solution seems to be a variable geometry hull, with flaps or something alike extending from a normal hull to provide a greater planing area.
Foils are another approach. The inclined foils in open 60s provide only limited lift, but the figures seem to be increasing lately. The Catri 27 foils lift up to 90% of its displacement to assist it in planing. The downside of foils is the poor light wind performance.
Cheers,
Luiz
[Re: Steve_Kwiksilver]
#23517 08/26/03 08:59 PM 08/26/03 08:59 PM |
Joined: Jun 2001 Posts: 12,310 South Carolina Jake OP
Posts: 12,310 South Carolina | Wait a minute...I gotta admit, I got lost in all that parent child relationship stuff  . It's an easy misconception that making the boat wider loads the leeward hull equally more but it just 'aint so. For the most part (there is a small exception when considering the foward drive of the sails on the bow) I believe the leeward hull's buoyancy is only supporting the weight of the boat and the sailors. The additional righting moment only induces less rotational moment around the leeward hull. The mast, rigging, beams, boards, rudders, etc....just about everything else on the boat DOES carry more loading as the stresses go up but this stress exists between the sail and it's contact points to the windward hull where all the extra righting moment is. The leeward hull is supporting the same weight - it just has more advantage because it's farther out.
Jake Kohl | | | Re: Boat Design: Boat Width, Sail Area vs. Pitch Pole
[Re: davidtilley]
#23519 08/26/03 11:30 PM 08/26/03 11:30 PM |
Posts: 12,310 South Carolina | yeak, I stand corrected...but you lost me when you started talking about RTI results???
[Re: Seeker]
#23520 08/27/03 03:01 AM 08/27/03 03:01 AM |
AHHH, but reread the following phrase again.
“PS. I put a SC20 together once that was 20ft wide and it sailed fine. To windward it was a rocket. Reaching don't trapeze. Downwind same as a normal SC20, watch the bows.”
Don't you notice that little "Reaching don't trapeze" thingy ?
Why is that bit included ? Why can't you trapeze on this course ?
And Steve; I wasn't saying that the total volume of the leeward hulls needs to increase; just that the longitudal pitching restance needs to be increased in order to make effective use of the extra width.
What have you won when you've replaced capsizing with pitchpoling ? Either way you can't transform the sailpower that you have into speed.
But by all means guys, if you believe that you can make boats indefinately faster by making them wider and that no other design aspect will limit you gains to something far less than expected then widen your boats.
[Re: Seeker]
#23525 08/28/03 09:17 AM 08/28/03 09:17 AM |
>>Wouter...the boat was 20'wide X 20' long...what in the world do you need to trap on a reach for? You already have plenty of righting moment...
So you are actually saying here that a narrow craft with trapezes could be just as fast on this course as their is more righting force available than is needed ? Doesn't this in a way underline the notion that going wider beyond a certain width is useless ?
Now answer the following question ; what will happen if you did trapeze off that 20 ft wide beam in 20 knots of wind and a sailarea to match your width ?
(I see only two possible outcomes ; you dive - pitchpole and get beaten by a Hobie 14 as no sailboats sails as slow as an upside down sail boat. OR you let out your traveller and mainsheet to depower you rig which means that you do not make full used of both the available sailarea and width. At 8 knots of wind the extra width is useless as every design is stabil enough.)
Think about it.
I think I have found a better analogy :
Picture two guys facing eachother pulling on a long piece of line. Put a load on the middle of the line pulling down. If the load is small enough than the two guys are both strong enough to lift the load by pulling on the line. Than there is a load where both guys can just pull hard enough to lift it. Lets now put an even heavier load on the line. Both can not pull hard enough. Can we lift the heavier load by replacing just one of the guys by a much stronger one ?
No substitude one guy for "maximum sailforce at which the boat capsizes" ; the other for "Maximum sailforce at which the boat dives" and the load for sailarea. See the system ?
Or here another one ; some people think you can drive harder through a bend when you increase the friction tires have an the road. Others know that at some point you will just flip the car or hit the ground with you foot rest. Either way your not making the bend anymore.
| | | Re: Foils
[Re: BRoberts]
#23526 08/28/03 03:02 PM 08/28/03 03:02 PM |
Posts: 1,307 Asuncion, Paraguay | Hello Bill, I simply can't resist comparing your simple statement: The planing hull bottom that I tried was one design, one effort. I do not think it was optimized. with that of another famous designer when he justifies the absence of foils in his (excelent) designs with one single bad experience a long time ago. It simply fails to recognize that one try is not enough - especially when you do not have access to the best research available. In my opinion this says a lot about your own idoniety and credibility (but I don't mean he isn't - just that he adopted a more sales-oriented position in this case) Today many multihulls are experimenting with flat bottoms, steps, foils, etc. The only place I saw a "V" bottom was in the preliminary drawings of a 60 ft cat for a French skipper (Kersauson?). It looked like the float of a hidroplane, exactly as you say. I guess by now they should already be testing the concept in smaller scale. We will soon find out if it worked. Thanks for your time,
Luiz
| | | Re: Foils
[Re: Luiz]
#23528 08/28/03 04:35 PM 08/28/03 04:35 PM |
Posts: 284 S. Florida | Hello Luiz, I don't follow what what you are saying in your comments. The thing that stopped me from further testing/developing of the planing beach cat was that I could see it was going to be a long road, possibly without success, and I have other interests to follow. The real world situation is, at least where I sail, when there is enough wind to plane, the surface of the water has waves on it 2 to 3ft high. Go for a ride in a flat bottom power boat and drive it into these waves even on a slow plane and the ride is very jerky and unpleasant and would probably damage the rigging of a beach cat. Drive a Vee bottom power boat into these same waves and the ride is more tolerable but the vee bottom power boat requires more horsepower to go the same speed as the flat bottom boat on flat water. Here in South Florida when the water is flat, there is no wind. The flat water situation is useless to consider because there is not enough wind to get a boat up on a plane. I'm sure the reason the seaplane has a Vee bottom is because frequently they land and take off on choppy water, real water, and they don't want to pound the bottom out of the airplane. There are many many variables to optimize on a planing beach cat hull shape by itself and I don't have a few years to devote to that. With my brief experience with planing beach cat hull shapes, I now think the answer is a long slender planing hull shape that does not even attempt to plane to windward but runs displacement mode. Then when the boat speed doubles while reaching and going downwind with a spinnaker, the hull will climb out on a plane and really go fast when it is going along the waves or downwind with the waves and crossing them slowly. I think a narrow Vee hull shape with hard chines and lifting strakes is the way to go. Bill | | |
1 registered members (basket.case),
483
guests, and 25
