| Help with 5.5 UNI and hooter, how to make it go well. #234625 07/10/11 05:00 PM 07/10/11 05:00 PM |
Posts: 15 | I have been sailing a Hobie 18 for about 20 years, for fun and competetitively. In an effort to be more equal with a local buddy on an Inter 17 I bought a used Nacra 5.5 UNI (1997 model in really nice shape). He an I have traveled together and raced with and against each other for almost that whole 20 year stretch. I figured out how to put the boat together and mostly what goes where and how stuff works, resewed the tramp, replaced some lines, the boat is very light and fast, but I need some help with sailing it well or at least better than I am now.
First, where should the traveler on the main sail go? This boomless thing is very different to me. Minor changes in the position change the shape of the sail a lot, I need some advice. Rotator, on the 18 we can limit it on this I can over and under rotate it, do the lines cross under the mast or is it something I change on every tack? How critical is it?
The boat came with a roller furling Hooter from Calvert sails on a technofiber pole is great but I appear not to be able to go anywhere near deep enough to keep pace with the I 17 off the wind, he has the I 17 spinaker. How far do I travel the main out? How much do I treat it like a jib or is it a down wind or reaching sail only?
I can go to weather and tack just fine, or at least I can keep up with my buddy, the boat feels OK but not it also feels like I am leaving something on the water.
It feel like I am on the very steep part of the learning curve and could use a little help.
Last, the rudder system SUCKS, is there any kind of retro fit set up for this thing. The rope down and bungee up (some of the time) is just plain awful. Has anyone put the newer rudder system on the older boat?
Been a cat sailor magazine subscriber for a long time but this is my first post on the forum. Thanks in advance, Ricardo. | | | Re: Help with 5.5 UNI and hooter, how to make it go well.
[Re: Ricardo]
#234627 07/10/11 05:43 PM 07/10/11 05:43 PM |
Posts: 12,310 South Carolina | I have been sailing a Hobie 18 for about 20 years, for fun and competetitively. In an effort to be more equal with a local buddy on an Inter 17 I bought a used Nacra 5.5 UNI (1997 model in really nice shape). He an I have traveled together and raced with and against each other for almost that whole 20 year stretch. I figured out how to put the boat together and mostly what goes where and how stuff works, resewed the tramp, replaced some lines, the boat is very light and fast, but I need some help with sailing it well or at least better than I am now.
Been a cat sailor magazine subscriber for a long time but this is my first post on the forum. Thanks in advance, Ricardo. Ricardo, I can possibly provide some insight for some of your questions. The mainsail traveler should normally be run forward almost all the way for upwind sailing. Sheet VERY HARD to get the boat to sail well to weather. The boomless rig is tricky to sail well. You need the positive rotator on this boat because you don't have a boom. Most boats with booms have the sheet blocks at a slight reward angle so that when they sheet in, the boom pushes forward on the mast - causing it to rotate. Without the boom, you really need to positively rotate the mast to get it in proper position. The rotation isn't super critical but it is important for performance. Upwind, have the mast pointing at the middle of the daggerboard in moderate conditions. In very windy conditions, have the mast pointing at the end of the rear beam. And remember - sheet HARD. The hooter should be for downwind and deep reaching only unless the wind is exceptionally light. If the wind is very light, you may be able to sail the hooter upwind. It's going to be a little tough to sail the Hooter as fast and deep as a soft spinnaker unless the wind is up. Make sure you have tale tales on the hooter and keep it trimmed to the apparent wind. Your mainsail should be sheeted almost in the upwind condition with the hooter - but sheeted a little more softly and with the sheet traveler moved to the middle or back 1/3rd of the traveler distance. Work the apparent wind - get the boat accelerated and then slightly bare away as the boat powers up - try to balance speed and depth with the angle you steer the boat. "leaving something in the water"...is probably because you are not sheeted hard enough. Sheet hard (I think I mentioned this). Rudder system. I'm rare in this opinion - but that is one of my favorite rudder systems. A couple of things - make sure the up-bunjies are tight. Use clear vinyl tubing to protect them and keep them from chaffing. For the down-lines, use the cheap polyester line you can get at Lowe's or Home depot (1/4" white with a red tracer). That cheap line is very knobby and grips very well in the v-jam cleats. If all else fails, take some electrical tape with you and tape the line, cleat, and the fiberglass clamp around the rudder arm after you put the rudders down...and be conscious about the time it will require to undo them when coming to the beach.
Jake Kohl | | | Re: Help with 5.5 UNI and hooter, how to make it go well.
[Re: Ricardo]
#234646 07/11/11 12:42 AM 07/11/11 12:42 AM |
Posts: 713 WA, ID, MT | I have a hooter/screecher on Flight Risk, and when all three sails are drawing, my main is travelled out less than a quarter of the distance between centered and fully out. The jib is trimmed last, to get it's telltales flowing, and it's travelled out fully and sheeted fairly flat(Oh, I missed that you're uni, disregard). I use the screecher from about 90 degrees to 120 true wind direction, it's not very efficient deeper, and it's not sheeted inboard enough to go to weather with(It's a very wide boat). Snuffable soft spins run much deeper. On my boat it's got a very narrow power window between collapsing and stalling, so I'm intensely focussing on reading the lower telltales on the screecher to keep it powered up. I tend to set the sails and drive to them, which is a gas! When I drive well, it's an awesome ride! Furl early when wind strength rises. If furled while flogging it can roll up ugly(hard on the sail fabric), or too tightly, and you run out of furling line(at least on mine). I love this sail, but I rarely have a destination, so I can reach about looking for max boatspeed. If you need to go downwind a lot, a spin is faster. Dave
[Re: Ricardo]
#234710 07/12/11 09:37 AM 07/12/11 09:37 AM |
Posts: 1,203 uk | Boomless sails are great, but you need to put some thought into settings [which is what you ARE doing]
Once you find an 'average' position for the traveller, you will move it forward a tad as you get over powered to let the leech twist off a bit and increase tension on the foot which will,in turn, derotate the mast a bit. When you are looking for more power, let the traveller back a bit to make the leech more 'hooky' and take tension off of the foot to let the mast over-rotate. As jake says - sheet like hell. When I sailed boomless [6.0] and before crews union allowed them to sheet, I jammed the tiller between my aft foot and back beam so that I had both hand on the sheet for a moment.
[Re: Ricardo]
#234738 07/12/11 01:15 PM 07/12/11 01:15 PM |
Joined: Apr 2002 Posts: 195 White Bear Lake, MN h17racer
Posts: 195 White Bear Lake, MN | Ricardo, lot's of questions, I'll see what I can help you with. I've sailing a 5.5 Uni for 7 years now after spending many earlier years on a variety of Hobie Cats. The Uni is a great boat once you get it dialed in and then learn all the quirks of sailing with a single sail. Rick White's book on Cat sailing has an entire chapter dedicated to Uni's.
1. Mast...mine is carbon and very tunable with a combo of mast rake, spreader rake and wire tension. I prebend my mast to fit the luff curve of the sail and then leave it.
2. Rotator...I only force rotation downwind, approx. 90-100 degrees. Upwind, I only pull rotation in/out via the mainsail traveler. In extremely light air I will sometimes set the rotator upwind to force the sail shape I want.
3. Mainsail traveler....I started at the centerpoint of the traveler and then move in/out based upon wind conditions. Heavier winds further forward, lighter winds back from centerpoint. I indexed 1" increments on either side of the centerpoint and adjust from there.
4. Downhaul....add the incremented Hobie downhaul stickers on either side of your mast and index to a point on your sail for quick reference. I indexed mine to the downhaul grommet on the sail. Downhaul does have a big effect on a Uni's sail performance as you have no jib to help you along. Then, work on recording each of your optimum wind condition settings. Upwind, the Uni enjoys downhaul with the EP sails.
4. Rudder system....is just fine and yours probably needs to be rehabbed. I use 3mm nostretch yacht line with aluminum cleats. They never move under load. If your bungee is old/stretched, replace it. I threw away the silly clear tube and instead triple-loop and tie a 3mm yacht line around the bungee at the rudder and it works fine. If you do not have an adjustable crossbar, invest in one.
5. The Uni likes to be sailed on its toes...weight forward. Upwind, I am mostly at or ahead of the front crossbar. Downwind, pretty much the same until it starts blowing, then I start moving back. At 10mph and above a Uni can perform very well downwind.
6. You didn't mention sailshape and battens. I tossed the wimpy sandwich battens and replaced with tubular. Gives me much better sail shape performance and control.
7. Hobie's seem to like tons of mainsheet tension upwind. Break that habit as Uni's do not. Oversheet the main at any time and you will go slow.
8. Finally, the Uni is not a jib boat so there is a definite learning curve if you came off of TheMightyHobie18's.
Anyway, hope the above helps.
Sail fast, Tom G Uni 5.5 | | | Re: Help with 5.5 UNI and hooter, how to make it go well.
[Re: Ricardo]
#234826 07/13/11 08:17 PM 07/13/11 08:17 PM |
Posts: 163 Atlanta | ...but I appear not to be able to go anywhere near deep enough to keep pace with the I 17 off the wind, he has the I 17 spinaker... I used to have an I-17R/F-17. That boat is really easy to sail fast downwind. Your buddy is going to be a tough nut to crack downwind. | | | Re: Help with 5.5 UNI and hooter, how to make it go well.
[Re: GeoffS]
#234866 07/14/11 02:15 PM 07/14/11 02:15 PM |
Posts: 15 | The fact that it is a fas boat AND he is on his 6th year with it. And works 3 days a week (12 hour shifts) so he has a lot more tiller time than I do. Tough nut for sure. Thanks to all for the info. Ricardo.
[Re: Ricardo]
#235436 07/29/11 04:06 PM 07/29/11 04:06 PM |
Posts: 757 japan | hooters have to be really flat to furl
that means they are a reaching sail more than a downwind sail
in light winds, <5knots, you can often creep a few degrees up wind with them, angles about 85 - 120 degrees off the wind
in medium winds, 5-10knots, they run best about 100-120 degrees off the wind
in strong winds, 10?-15knots, about 120-160degrees off the wind
if soloing with 3 sails you generally cleat off the main and jib in pretty much their reaching positions and then play the hooter and steering with each hand
be ready to steer down hard and release the hooter sheet once the leeward bow looks to bury
[Re: Ricardo]
#235522 07/31/11 06:59 PM 07/31/11 06:59 PM |
Posts: 757 japan | because the spinnaker on the I-17 comes out of a bag, it doesn't have to be cut very flat
it will have much more curvature and so always be able to sail deeper than a roller furling sail
you just don't have the right sail to sail as deep as the other boat
however in light winds and highish angles you should be able to outsail the I-17 on tight reaches
the last tornado sailing olympics had this contrast when the usa team, expecting very light winds, used a very flat reacher hoping to outpace the other boats with deeper cut spins
in the event the wind blew hard and the usa team could not compete downwind with any of the other teams and ended up doing very poorly
2,376
guests, and 222
