2011 North American F18 Championships (Certification Require #235371
07/28/11 06:25 PM
07/28/11 06:25 PM
Clermont, FL, USA
David Ingram Offline OP
Clermont, FL, USA
Hello All,
I hope everyone is looking forward to sailing in Hyannis in seven weeks, it’s shaping up to be a great regatta.
As a reminder you are required to have your boat fully certified in order to participate in the 2011 North American F18 Championship. Due the problems encountered at Worlds this year we will be paying very close attention to sail materials. If your equipment is found to be out of compliance you will be subject to protest. You can find the class rules and the accepted materials list here: http://www.naf18.com/joomla/2010F18ClassRules.pdf
Class measures, please make sure you note the materials on the certification form as required.
If you have any questions please don’t hesitate to ask.
USF18 Chair
F18 USA 242
http://www.solarwind.solar
Re: 2011 North American F18 Championships (Certification Require [Re: David Ingram] #235459
07/30/11 05:53 AM
07/30/11 05:53 AM
Falmouth, MA, USA
RTodd Offline
RTodd  Offline
Falmouth, MA, USA
What about compasses and synthetic trapeze lines? Any other sticking points?
-Robert (USA 151)
Robert Todd
Capricorn F18 #151
Falmouth, MA
Re: 2011 North American F18 Championships (Certification Require [Re: RTodd] #235513
07/31/11 11:27 AM
07/31/11 11:27 AM
F18_VB Offline
F18_VB  Offline
From the NOR:
"United States Prescriptions. . .shall apply"
North American F-18 Class Prescriptions:
For use only in North America events when specifically listed in both the Notice of Race and the Sailing Instructions.
GPS Enabled Devices
Electronic devices that provide timing, heading, and heading memory are permitted. Devices that calculate VMG without the use of waypoint data are permitted. Devices that display real-time position or mapping are prohibited.
Synthetic Trapeze and Bow Sprit Bridles
Bow sprit bridles material: textile material with a minimum diameter of 3mm is allowed
Trapezes cable wires: can be cable and/or textile with a minimum diameter of 2.5mm for trapeze.
Mast Height
The upper mast height point value (8980 mm) in F.3.2 class rules is deleted. The maximum mast length remains 9100 mm from the beam
Maximum Batten Pocket Widths – Rule G.3.5
Batten Pocket width limitations for both main and jib sails are deleted
Miscellaneous
STEERING COMPASS (C.5.1.a.2) is not mandatory.
0 registered members (), 2,049 guests, and 501 spiders.
