I tightened my tramp today #237122
09/02/11 09:59 PM
09/02/11 09:59 PM
Karl_Brogger Offline OP
Throwing boats on the trailer earlier today and stumbled across something. I was kneeling on the tramp while cranking down the straps and noticed the tramp got noticeably less tight, so I tightened it while it was strapped down, popped the straps loose, and holy hell is it tight now.
Re: I tightened my tramp today [Re: Karl_Brogger] #237123
09/02/11 10:11 PM
09/02/11 10:11 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Hey there Karl,
Are you referring to the boat flexing when you were strapping it down, and the tramp looseing slightly?
Were you putting the starps accross the beams, hulls, each seperate?
Tell us how we too can 'tighten out tramps', I think she'd like that!
F-18 Infusion
#626- SOLD it!
Re: I tightened my tramp today [Re: Todd_Sails] #237124
09/02/11 10:27 PM
09/02/11 10:27 PM
Across the beams.
Re: I tightened my tramp today [Re: Karl_Brogger] #237128
09/02/11 11:58 PM
09/02/11 11:58 PM
How much pressure is on those straps!!?
Re: I tightened my tramp today [Re: Jake] #237139
09/03/11 09:57 AM
09/03/11 09:57 AM
california
F-18 5150 Offline
F-18 5150  Offline
california
So you thought it was tight but it was only tight for you?
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: I tightened my tramp today [Re: Jake] #237140
09/03/11 10:31 AM
09/03/11 10:31 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
grin tight, tighter, loose
no seriously, are the beams loose? If yes check the bolts?
Re: I tightened my tramp today [Re: Smiths_Cat] #237141
09/03/11 11:47 AM
09/03/11 11:47 AM
Beam bolts are all tight, I check them on a fairly regular basis.
Apparently the straps are pretty damn tight, and my tramp wasn't loose before, but its definitely tighter now.
Makes me wonder about wrapping a strap around the beams and pulling it in as a method. It would also be interesting to measure how deflection is in the beams with and without tension.
Re: I tightened my tramp today [Re: Karl_Brogger] #237177
09/05/11 04:08 PM
09/05/11 04:08 PM
M
MN3
MN3
M
interesting. would like to see the results too.
i believe that normal strap tension is enough to cause some beam flex.
PS I stap each bow independent
Re: I tightened my tramp today [Re: ] #237193
09/06/11 08:15 AM
09/06/11 08:15 AM
I'm attempting to visualize what's going on there.
By ratcheting down on the straps, you're squeezing the boat together (against the force of the beams)? Are the beams bowing up or down slightly while strapping? Perhaps the rear beam moreso since you've got a striker on the main beam...?
Re: I tightened my tramp today [Re: waterbug_wpb] #237201
09/06/11 09:56 AM
09/06/11 09:56 AM
The straps go front to back over the top of both beams. So its flexing the beams down, and toward the center of the boat. I think my straps are 44" apart, but is have to measure it again.
I kinda wish I would've thrown a straight edge on either of the beams. I haven't seated these beams, but you can see the gaps in the seats that they are being pulled in.
0 registered members (), 515 guests, and 45 spiders.
