Where can I get some boom section?? #237186
09/05/11 09:34 PM
09/05/11 09:34 PM
Kyabram
M
MickM Offline OP
MickM  Offline OP
M
Kyabram
Hi all,
I'm intending to build a new boom. Can anyone give me some advice on where to purchase the "boom section", what is best practice (which section) and what the price might be. I have all the other bits so just need the "boom section"
thanks
MickM Mossi 1811
Re: Where can I get some boom section?? [Re: MickM] #237187
09/05/11 10:32 PM
09/05/11 10:32 PM
G
Got Wood Offline
Got Wood  Offline
G
Give Goodalls at Bendigo a ring. 54436910 I think is the number. They answer all those questions and send it to you.
Taipan AUS329 'Got Wood'
Mosquito 752 'Sticky Finger'
HARDWOOD RACING TEAM
Re: Where can I get some boom section?? [Re: Got Wood] #237189
09/06/11 02:37 AM
09/06/11 02:37 AM
Matt_Stone Offline
Matt_Stone  Offline
mick
i can get boom section for u, its about $150 for a 3 meter leanth
Also think about how is your boom attached to the mast because you may need a boom end plug which is about $35
Matt
Re: Where can I get some boom section?? [Re: MickM] #237285
09/08/11 07:33 AM
09/08/11 07:33 AM
South Oz
Phillip Offline
Phillip  Offline
South Oz
A common section is from a (broken) paper tiger mast section. Even better when the sail track flanges are removed. Might even be anodised! Are you sheeting to mid-boom? Consider the extra flex this will cause. How will you control the clew adjustment? Some excellent latest ideas with images on the web.
Mozzie Aldebaran VI
1827
Re: Where can I get some boom section?? [Re: Phillip] #237329
09/08/11 07:05 PM
09/08/11 07:05 PM
Rosebud
wdt Offline
wdt  Offline
Rosebud
I think that I might have enough of a blank section that is a few years old, is new and never used. Wouldn`t want much for it. Is the length required exactly 3m?
Wayne
Re: Where can I get some boom section?? [Re: wdt] #237330
09/08/11 07:50 PM
09/08/11 07:50 PM
Port Hedland
Beckit 1824 Offline
Beckit 1824  Offline
Port Hedland
Before you start drilling holes and putting on hangers, I found if you make a loop of kevlar rope inside some fuel hose, and have that around the mast like the A class, you can adjust its position by clamping it in the end of outhaul car slot. Means no corrosion, or pull outs, and less stress on the boom.
I also used 3 x layers of chopping board bolted together for my boom plug, and hollowed an inside cavity and put a key (a piece of rivet nail) athwart the gooseneck rod. The boom will only come off if I turn it 90 degrees so won't shake loose going downwind when tension is off everything.
1 registered members (Talus1), 492 guests, and 525 spiders.
