Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249811
06/19/12 09:50 PM
06/19/12 09:50 PM
Ocean Springs, MS
Capt_Cardiac Offline OP
Ocean Springs, MS
It's rating at 59.3(provisional) and as we get data we will continue to update. The sails are 50sqm you can divide them up per the rules but the latest sails are following the development lines of the F18s since that is where the biggest changes have been in the last 10 years. I'm aware of 3 sailmakers building newer design sails. Schurr, Glaser and Performance.
The F20na fits in the class. Hopefully we'll get a chance to see how she performs.
There have been a few mods to existing N20s, different mast/booms/spin poles and most notably the sails.
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249823
06/19/12 11:34 PM
06/19/12 11:34 PM
V
Ventucky Red Offline
V
So what I am reading and using the Inter/NACRA 20 as an example is that you can go from 45.15 meters square to 50 meters square of sail area; about a 10% increase, and still maintain the orginal N20 59.3 DP-N rating, albeit it being provisional?
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249855
06/20/12 11:37 AM
06/20/12 11:37 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Most of the specs I look at online show the N20 sail area to be 527sq ft or 48.9 sq meters.
Re: Open 20 rule set: 1 October 2011 [Re: bacho] #249856
06/20/12 11:59 AM
06/20/12 11:59 AM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
What is an F20na?
Re: Open 20 rule set: 1 October 2011 [Re: ksurfer2] #249861
06/20/12 01:06 PM
06/20/12 01:06 PM
G
GLS Offline
GLS  Offline
G
F20na
Beam 8' 6"
carbon mast 31'
Hulls F20C
F20na pictures
Re: Open 20 rule set: 1 October 2011 [Re: bacho] #249868
06/20/12 01:39 PM
06/20/12 01:39 PM
V
V
Thanks for the correction have to stop referring to it as an Inter 20
Inter 20 Specs
Specifications
Length: 6.10 m 20 ft.
Beam: 2.59 m 8′ 6″
Weight: 177 kg 474 lbs.
Sail Area: 45.15 sq m 486 sq. ft
Re: Open 20 rule set: 1 October 2011 [Re: GLS] #249869
06/20/12 01:40 PM
06/20/12 01:40 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
A F20c narrowed to 8'6"?
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249873
06/20/12 03:38 PM
06/20/12 03:38 PM
Ocean Springs, MS
Ocean Springs, MS
we used the F16 measurement convention.
The EP sails measured in at 49.06 sq. meters
the new Performance sails measured 46.489
The F20na also reduced the overall sail area compared to the F20c.
Capt Cardiac
Sailor
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249943
06/23/12 12:58 PM
06/23/12 12:58 PM
V
V
Did you get a confirmation from Skip Elliott the M-sq of his sails or this something you came up with?
If you don't mind me asking, if you're going to allow for a modified Inter/NACRA 20 to sail in the Open 20 class with a 59.3 DP-N, do you guys plan to run two classes; that is a Inter/NACRA 20 class for the stock boat and an Open 20 Class for the boats that are carrying the modifications?
For the Open 20 Class you may want to reconsider your "provisional" rating.. Seems a little unfair to those that don't want to have to spend beaucoup duckets to keep up with the Joneses
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #249946
06/23/12 10:26 PM
06/23/12 10:26 PM
Ocean Springs, MS
Ocean Springs, MS
We measured the sails.
If there are enough stock I20s they can always have there own class.
The provisional rating is just that. We will continue to compile data.
Capt Cardiac
Sailor
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #256769
01/31/13 04:34 AM
01/31/13 04:34 AM
Western Europe
ClaytonF16 Offline
ClaytonF16  Offline
Western Europe
Howdy guys
I am going to modify my f18 into a f20 but notice your rule set is not quite the same as the schrs rating measurements found here
http://www.schrs.com/ratings.php
Is your open 20 class going to based in the US only.?
Clayton
Re: Open 20 rule set: 1 October 2011 [Re: Capt_Cardiac] #256874
02/02/13 08:24 AM
02/02/13 08:24 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I believe it's currently limited to the southeast.
0 registered members (), 6,511 guests, and 241 spiders.
