Re: Righting technique [Re: sail7seas] #239249
10/24/11 03:16 AM
10/24/11 03:16 AM
We have a 5mm 'V' shaped righting line permanently fixed underneath the boat.
The line is fixed inside the trampoline groove at either ends of the frontbeam.
Biggest advantage of this instead of using the over the hull method is that the line just snaps back into place after righting and you can continue sailing and dont have to worry about hauling in the righting line which at that point will be stuck behind a daggerboard or even a rudder. smile
The righting moment is the same for sure, only downside is that there's more tension on the line which can be annoying when you have a 2nd person leaning against you to get more weight out.
Re: Righting technique [Re: ] #241838
12/24/11 12:58 PM
12/24/11 12:58 PM
Italy
L
Luca ITA24 Offline
Luca ITA24  Offline
L
Italy
I copied this system and installed to F18 Tiger on my girl, with her syster weighed 107 Kgs, no problem for righting
http://www.murrays.com/archive/36-37.pdf
Ciao
Re: Righting technique [Re: ] #241957
12/31/11 07:01 AM
12/31/11 07:01 AM
JohannesK Offline
JohannesK  Offline
I made this system:
Cheap, light, easy to use!
http://fx-one.de/index.php?id=200
Johannes
Re: Righting technique [Re: ] #241976
01/02/12 11:33 AM
01/02/12 11:33 AM
JJ_ Offline
JJ_  Offline
Johannes,
How are the lines to the righting pole attached to the front crossbeam? Wish there was a pic of that... (Maybe I don't see it.) My German isn't too good at the moment.
1 registered members (vasil), 386 guests, and 25 spiders.
