| Saving $$$ with Generics? #23965 09/07/03 04:42 PM 09/07/03 04:42 PM |
Joined: Aug 2002 Posts: 215 Durham, North Carolina jwrobie OP
Posts: 215 Durham, North Carolina | I assume that if sailing is like most other things, you can save money by buying things that don't say 'Marine' on them, but perform the same function. But most of them do say they have special properties you need on a sailboat. When can you get away with non-marine generics, and when can't you?
For instance, the first thing I did when I bought our used boat was replace all that old line with cheap new rope from Wal-Mart. Bad, bad move. It all stretched, hung up in blocks, and misbehaved in general.
What about Sailkote - it claims "Sailkote is typically five times as effective, and lasts much longer than, wax, oil or TeflonĀ® based lubricants." Are there other dry lubricants that I can substitute that work as well? Particularly for lubricating the sail?
In general, where can I afford to skimp by buying generics, and where can't I?
Jonathan | | | Re: Saving $$$ with Generics?
[Re: jwrobie]
#23968 09/07/03 10:13 PM 09/07/03 10:13 PM |
Posts: 217 | I love your story about trying to buy line @ Walmart - that's a classic!
As for saving money, here are some ideas.
Motorboat market is much larger than the sailboat market. So, anything that's on your sailboat that may also be on a motorboat is usually cheaper at a motorboat place, or at a place that sells stuff to motorboaters, many of whom are fishermen. Example - trailer parts & hitches, outdoor apparel, etc.
Some examples : Walmart sells trailer balls, hitches (for some common models, & trailer wiring).
Academy Outdoor - local TX outdoor & sports type store - no sailboat stuff, but has a motorboat & fishing section. I bought a stainless steel needle nose pliers in the fishing dept for $7.99. I can't even buy a pair of regular steel pliers @ Sears for that - and the stainlesss pliers in West Marine are $18.00 or more.
Home Depot - obviously, for some Stainless hardware, but how about this - I bought a swaging tool @ Home Depot for less than $20. It's not stainless, but that's no problem for me. In sailboat catalog it's almost $75 for the same thing.
JC Whitney - auto parts catalog - has trailer tires in wide range of sizes, pre-mounted or tires only, in several load ranges.
Happy hunting, and don't forget to support your dealer!!!!11
[Re: jcasto1]
#23969 09/08/03 08:21 AM 09/08/03 08:21 AM |
Posts: 545 Brighton, UK | Its sometimes quite hard to support your dealer with the prices they charge, I needed to get new shrouds for my H16 , Hobie charge me ~$50 wheras a local industrial wire company charge $8 for exactly the same bit. (My £ to $ conversions my not be spot on but they are in the right ball park) An Aluminium casting for a H16 corner peice costs ~$300 an equivalent peice (simialr size and weight) for a car would cost $20. OK so you can't get a generic casting but it it shows what a rip off the hobie part is.  Gareth | | | Re: Saving $$$ with Generics?
[Re: grob]
#23970 09/08/03 09:14 AM 09/08/03 09:14 AM |
Posts: 12,310 South Carolina | You gotta remember that quantity has a lot to do with it too. The Car industry builds a LOT more of the same thing over and over again and even when they do modify things a bit the process and tooling is still very similar. This quickly leads to a significant cost reduction.
That said, if you buy a part at an automotive supply house versus going to the automotive dealer, you'll find increases that are similar with going from Hobie to the industrial wire company.
There is also a factor that most manufacturers (car makers included) plan on making a significant margin on spare parts. When you buy a car, boat, or piece of machinery, how many times do you ask to see a price list for common wear items and consider that with the overall price? Not very often. When manufacturers start trying to be more competative with their up front pricing the spare parts become a more important money maker.
Jake Kohl | | | Re: Saving $$$ with Generics?
[Re: grob]
#23972 09/08/03 03:14 PM 09/08/03 03:14 PM |
Posts: 12,310 South Carolina | I agree that it sucks! However, I used to have business and personal connections with one dealer for the Mazda Motor Corp (USA)spare parts business - and their pricing matrix reached 400% markup in some areas. I now work for a custom machine manufacturer where we build $80k to $200k machines customized to run different products and it is a standard practice for us to mark up components that we buy off the shelf to help cover the costs associated with the storage space, design/integration time, heating, shipping personnel and equipment, etc. etc - and to make a little money in the process. This is not to mention parts that we design and manufacture ourselves. Basically it costs money to do business/move and store parts regardless of where it originated. We also guarantee a degree of quality and knowledge about how that part should be used that you may not get if you buy, or have manufactured, something somewhere else - and that's probably a fair statement of Hobie, Nacra, etc. 300% markup? Maybe that's not reasonable considering an off the rack 8 foot piece of 1 inch extruded aluminum tiller connector but as the rules of supply and demand apply, someone will most certainly take advantage of the disparagy and profit somewhere in the middle. However, that's not to say anything about 'class' rules apply.
#23973 09/08/03 03:51 PM 09/08/03 03:51 PM |
Posts: 545 Brighton, UK | OK, jake you make a good argument, I too work in the auto indsutry but for an OEM, The margins on a car are very small, but the volumes are very high and the competitiion is tough.
Your example reminds me of an engineering joke
There was an engineer who had an exceptional gift for fixing all things mechanical. After serving his company loyally for over 30 years, he happily retired. Several years later the company contacted him regarding a seemingly impossible problem they were having with one of their multi-million dollar machines.
They had tried everything and everyone else to get the machine to work but to no avail. In desperation, they called on the retired engineer who has solved so many of their problems in the past.
The engineer reluctantly took the challenge. He spent a day studying the huge machine. At the end of the day, he marked a small "x" in chalk on a particular component of the machine and stated, "This is where your problem is". The part was replaced and the machine worked perfectly again. The company received a bill for $50,000 from the engineer for this service. They demanded an itemized accounting of his charges.
The engineer responded briefly:
One chalk mark $1 Knowing where to put it $49,999
It was paid in full and the engineer retired again in peace."
I guess you could rewrite it as 8ft of 1" OD 6082-T6 anodised aluminium tube $2, knowing to use that spec of alu tube $18. | | | Re: Saving $$$ with Generics?
[Re: grob]
#23974 09/08/03 04:09 PM 09/08/03 04:09 PM |
Posts: 12,310 South Carolina | I get a lot of practice - I have to defend that policy a lot (I'm a Customer Service Manager). That's a good one!
Jake Kohl | | |
2,779
guests, and 313
