Page 1 of 3 1 2 3
Lace up your Tramps? #239684
11/03/11 10:34 AM
11/03/11 10:34 AM
Timbo Offline OP
Timbo  Offline OP
No, I'm not talking about your Wife's undergarments, I'm wondering if there is any upwind, less drag, aerodynamic advantage to using a "lace up" the side type tramp, vs. the slide it into the hulls type.
The thought occured to me as I was going upwind on my old Prindle one day, in big wind. Now, my old Prindle tramp relly needs to be replaced, the side tabs that you tie into the hull slots are mostly pulled out, so about 6" of the sides of the tramp flap up in the air when I fly a hull and the wind gets under there...but it seemed as though it was much easier to control the boat's heal, as it did.
I started to wonder if maybe that's why the A cats (mostly) are using side lace ups? It allows the 'trapped' air pressure under the tramp a place to vent, which helps when the wind is up and you need to keep the hull only about 1' up? Or are they using them strictly to save a few oz. weight? Or something else?
OR...should we be designing our tramps to look like a wing laid on it's side, ie. fatter and round at the front beam (leading edge), with camber over the top, but flat on the bottom, tapered off to a thin trailing edge? Kind of like the Aka's on that 'flying' trimaran, Hydroptere? Do we want our tramps to help lift the boat, or no?
Seems the Curved Daggerboard school of thought says, lift the hull for less drag.
A tramp shaped like a wing would add lift too, right?
So, should we lace up, leaving an open slot on each side to allow the trapped pressure to escape, or use the lift to help get the hull up?
From my college Aero Engineering days, I remember that for any lift, there is also drag.
Without a wing shaped tramp, I think it's more drag than lift. But I'm going to have to get a new tramp for that old Prindle, I was thinking about a custom lace up vs. the same old thing.
I remember back when the I20 changed from the side slide to the lace up, but I thought that was due to isses of the slides pulling out of the hulls, more than any speed advantage. Did any of you who made the switch notice any improvements with the lace up?
Re: Lace up your Tramps? [Re: Timbo] #239688
11/03/11 11:20 AM
11/03/11 11:20 AM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Do you want lift from the tramp? Won't that force additional weight to counterbalance it (hiking)?
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: Lace up your Tramps? [Re: Timbo] #239689
11/03/11 11:22 AM
11/03/11 11:22 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
The side lace up tramps probably offer less wind resistance, due to an open space that allows the wind that gets under the tramp to pass through the boat when healing. I dont think that is the intent, I think the side lace up tramps were done more as a better way of attaching the tramp to the hulls.
Personally I've had lace up tramps on my first Acat and my HT. Both allow for me to really get the tramp tight, which stiffens up the boat and keeps your butt from dragging in the water.
A side benefit is that its a really nice place to put your heel and push yourself off the hull when you are trapping out. Thats the reason I like them laced up vs solid.
Re: Lace up your Tramps? [Re: Timbo] #239690
11/03/11 11:32 AM
11/03/11 11:32 AM
Timbo Offline OP
Timbo  Offline OP
OK, here's another thought, take a look at the tramps on the AC or VX 40 cats. They use what looks like a big fishing net, about 3" square, open weave type tramp, vs. what we use on our beach cats, a much tighter weave.
Why? Does nobody make a huge roll of our tight weave? Or, is there 'less drag' with the open weave, where the wind can blow right through the entire tramp?
And why are no beach cats using it? I was seriously thinking about trying to buy a square of that 3" open weave stuff for my Prindle replacement, or something like they use for bow nets on a Corsair, or what they use on the bows of the big cruising cats, it would be very cool for my kids to just look straight down on the water rushing by. Like this: http://multihullnets.com/product/opendk.htm
Yeah, it might hurt your butt more to sit on it, but hey, just sit on the hull and there won't be a problem.
Re: Lace up your Tramps? [Re: Timbo] #239691
11/03/11 11:48 AM
11/03/11 11:48 AM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
Try this link. Dad used to buy from them.
http://www.memphisnet.net/category/netting
Re: Lace up your Tramps? [Re: Timbo] #239692
11/03/11 12:00 PM
11/03/11 12:00 PM
Timbo Offline OP
Timbo  Offline OP
Thanks Jack, did he use it for tramps or for fishing? The reason I ask is, the other place puts some UV protection on them, as they build them for cats in the sun.
Re: Lace up your Tramps? [Re: Timbo] #239693
11/03/11 12:11 PM
11/03/11 12:11 PM
Dunedin, FL
H
Headhunter Offline
Headhunter  Offline
H
Dunedin, FL
I usually sail in shorts and that crap tears your knees to hell when tacking/gybing. One of our local sailing crew has it for a tramp on his Super 17 and he hates it.
Re: Lace up your Tramps? [Re: Timbo] #239694
11/03/11 12:12 PM
11/03/11 12:12 PM
Timbo Offline OP
Timbo  Offline OP
Yeah, I was wondering about that part!
This stuff looks like it's a little smoother, with smaller openings, might not hurt so much.
http://multihullnets.com/product/openok.htm
Thanks!
Re: Lace up your Tramps? [Re: Headhunter] #239695
11/03/11 12:34 PM
11/03/11 12:34 PM
Lake Norman. NC
M
Matt_Z Offline
Matt_Z  Offline
M
Lake Norman. NC
I have the usual tramp in back and 2" net in the front. The front's not bad since I'm not usually up there when sailing. But when I'm working on something and have to kneel on the net for any period of time... wow is that stuff miserable. Also, there's no getting the net as tight as a regular tramp and keeping it there. You sink a lot deeper into it, which probably contributes to tearing up your knees.
I believe the reason for using the net tamps is that light boats with large tramps that extend beyond the main cross beam can flip over backwards when tacking in high winds if they use the standard weave tramps.
Re: Lace up your Tramps? [Re: hobie1616] #239696
11/03/11 12:36 PM
11/03/11 12:36 PM
Timbo Offline OP
Timbo  Offline OP
Yeah, that's another issue, and that's why I've been wondering if we want vents or no vents, ie. lift or no lift.
And at first sight I thought the 'wings' on Hydroptere were wing shaped, but on closer examination, I guess they are not, and it flys anyway, on just the blades. Imagine if they built the aka's with a naca wing profile and could keep the top clean enough to generate even more lift!
http://www.youtube.com/watch?v=2boayPZ3GbE&feature=player
Re: Lace up your Tramps? [Re: Timbo] #239697
11/03/11 01:08 PM
11/03/11 01:08 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
His were for fishing. They make them out of various materials. I would guess that soccer nets are UV protected.
Re: Lace up your Tramps? [Re: Timbo] #239698
11/03/11 01:28 PM
11/03/11 01:28 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Based on my aerodynamic expirience, I would think that closed edges are far less dragy than laces. Also I think that the extra lift is something good, as it reduces the needed displacement. Finally it makes your main more efficient, not much, but a bit. All effects are certainly small, and if there are any benefits for a laced layout as better control in strong wind or faster trapezing, than go for it.
Cheers,
Klaus
Re: Lace up your Tramps? [Re: Smiths_Cat] #239699
11/03/11 01:42 PM
11/03/11 01:42 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
some class rules also restrict size of openings in tramp.
Re: Lace up your Tramps? [Re: Timbo] #239700
11/03/11 01:45 PM
11/03/11 01:45 PM
pgp Offline
pgp  Offline
Is this the beginning of an ekranoplan project?
Pete Pollard
Blade 702
Re: Lace up your Tramps? [Re: orphan] #239705
11/03/11 01:57 PM
11/03/11 01:57 PM
Timbo Offline OP
Timbo  Offline OP
Really? Which ones, and why? Is it seen as some type of speed advantage?
Re: Lace up your Tramps? [Re: Timbo] #239711
11/03/11 02:50 PM
11/03/11 02:50 PM
Maryland
Kris Hathaway Offline
Maryland
F16 & F18 prohibit netting. I sure it is a combination of safety and minimizing cost escalation.
Kris Hathaway
Re: Lace up your Tramps? [Re: Timbo] #239716
11/03/11 03:10 PM
11/03/11 03:10 PM
O
orphan Offline
orphan  Offline
O
Tornado. 2mm. netting not allowed.
Re: Lace up your Tramps? [Re: Timbo] #239718
11/03/11 03:12 PM
11/03/11 03:12 PM
Timbo Offline OP
Timbo  Offline OP
I guess your trap hook could get caught on it much easier than the standard tramp. I'm wondering if there is any cost difference though. I've got an estimate request in to that tramp co. I linked above, I'll see if it does cost any more than standard.
Re: Lace up your Tramps? [Re: Timbo] #239721
11/03/11 03:48 PM
11/03/11 03:48 PM
cyberspeed Offline
cyberspeed  Offline
The ARC line uses netting. The ARC 21 uses a tighter weave than the ARC 30. Lighter weight and less windage.
FYI: a tramp is full of holes and does not need to bleed off pressure.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Lace up your Tramps? [Re: Smiths_Cat] #239722
11/03/11 04:34 PM
11/03/11 04:34 PM
That's my vote. I've been told by a few over the road truckers the absolute worst thing to haul is the corrugated pipe. Not a lot of weight, but a ton of drag.
Even towing a beach cat, there's a whole mess of drag there, and not much weight. I've put 7 catamarans in a 4500# enclosed trailer and got 12.7mpg over the course of a 2500 mile road trip, I get only slightly better pulling a triple stack.
Page 1 of 3 1 2 3
0 registered members (), 2,529 guests, and 549 spiders.
Yesterday at 10:10 AM
