re-gelcoating something entirely #240653
11/30/11 09:35 PM
11/30/11 09:35 PM
Karl_Brogger Offline OP
The bottom of my jet-ski is an awesome shade of purple. [sarcasm] It needs a bunch of repair anyway, (along with wanting to cut and mud in a bigger pump) and I'd like to change the color.
Should I sand everything down to the glass then re-spray it? Or just rough up, repair and spray it. I was thinking that every time there's a scratch that sweet shade of purple would shine through if I do it this way though.
If this goes well I might try a pair of boat hulls.
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240664
11/30/11 11:40 PM
11/30/11 11:40 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
If you're not worried about weight(the jetski) just scuff and re-gelcoat ,or better yet good marine paint. For your boat hulls I'd try to remove as much or more than you add back, if it's a race boat. And do yourself a favor and use that Duratec (sic?) stuff if you gelcoat.
Isak Dinesen
E. B. White
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240665
11/30/11 11:40 PM
11/30/11 11:40 PM
Santa Cruz, CA
SurfCityRacing Offline
Santa Cruz, CA
If the weight of the old gel isn't an issue, I'd just fair it and put some tooth in the existing gel. Spray, wet sand, buff, done. Use Duratec clear additive.
(edit: Obviously Cat Fever has no idea what he's talking about. You beat me by 20 seconds. grin)
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240667
11/30/11 11:58 PM
11/30/11 11:58 PM
Tooth? Is that a typo Jeremy?
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240669
12/01/11 12:21 AM
12/01/11 12:21 AM
Nope - he means give the new gelcoat something to bite, i.e., rough up the surface before application... sometimes the interface where the old gel has been taken off and the competent existing gel can have a "toothed" or zig-zag appearance, too. This gives a better surface that yields less apparent repairs. Think of the black zig-zag on Charlie Brown's yellow shirt...
Re: re-gelcoating something entirely [Re: John Williams] #240672
12/01/11 06:57 AM
12/01/11 06:57 AM
Maryland
Kris Hathaway Offline
Maryland
You are trying for a "mechanical" bond. If you shoot multiple layers of gel coat, you want to do it before the first layer flashes off so that a chemical bond is achieved for the those layers.
Kris Hathaway
Re: re-gelcoating something entirely [Re: Kris Hathaway] #240673
12/01/11 07:46 AM
12/01/11 07:46 AM
And since the gelcoat that is already there is chemically cured, there's nothing left for the new gelcoat to bond with on the molecular level. So, you give it tooth...rough sand it. This gives the new gelcoat something to mechanically bind to.
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240675
12/01/11 09:43 AM
12/01/11 09:43 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
How rough, 80 grit?
Re: re-gelcoating something entirely [Re: davefarmer] #240678
12/01/11 09:52 AM
12/01/11 09:52 AM
Originally Posted by davefarmer
How rough, 80 grit?
Personally, I start lower to get the high spots out but finish up with 220 grit before gelcoat.
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240682
12/01/11 10:14 AM
12/01/11 10:14 AM
pgp Offline
pgp  Offline
I went to 320 and I'm having some adhesion problems.
Pete Pollard
Blade 702
Re: re-gelcoating something entirely [Re: Jake] #240689
12/01/11 12:55 PM
12/01/11 12:55 PM
Maryland
Maryland
I started at 60 and gel prepped at 150 with good success. Gel coat is so thick and if you get a nice flow, the final will been very rewarding especially when you get to the rough cut compounding phase.
Kris Hathaway
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240690
12/01/11 12:59 PM
12/01/11 12:59 PM
pgp Offline
pgp  Offline
"Thickness". I don't have enough which is part of the adhesion problem but too much will lead to crazing.
Pete Pollard
Blade 702
Re: re-gelcoating something entirely [Re: Kris Hathaway] #240695
12/01/11 01:45 PM
12/01/11 01:45 PM
catman Offline
catman  Offline
This is true if your using Duratec. Treat it like paint. However, If your shooting gel coat without wax or Duratec you can let each coat kick before the next coat and still have a chemical bond. Gel coat without the additives stays sticky after curing. Then mix the Duratec or wax in the last coat.
I've quit using Duratec. The cost isn't worth the slightly less orange peel ( still have to sand and polish )
Block sand with 80 to start. Fill any bad spots. Sand those areas till smooth. One more time with 180 all over. Spray two to three coats w/out additives. One last coat with additives. Then I would block with 180 until the peel is almost gone then wet sand 220, 400, 600, 800 and buff. Hopefully you don't go through.
It's the bottom of a ski so I wouldn't put too much into it.
When your spraying make sure your careful when feathering and don't stop in the same place as you put coats on. You can wind up with a few very high spots.
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240696
12/01/11 01:58 PM
12/01/11 01:58 PM
pgp Offline
pgp  Offline
Is there a difference in gel coat brands? What's a good source?
Pete Pollard
Blade 702
Re: re-gelcoating something entirely [Re: catman] #240738
12/02/11 01:02 AM
12/02/11 01:02 AM
Santa Cruz, CA
Santa Cruz, CA
Yeah, man. Hotcoat! Spray a good heavy coat of gel, don't make it sag though. Walk away for a bit to let it go off a little, and toss the gun in a cool place... we use a small fridge... then come back and spray a little more. Repeat several times. You've got to watch the thickness though to avoid runs.
I know a guy that walks away from the first coat and takes the opportunity to leisurely grind up his weed. Then he goes back to spray. The second break he rolls a spliff, and goes back to spray a little more. The third break he smokes it, and goes in for his final application. Says it helps him avoid the peel, which lessens his finish time.
I usually take old gel down to 120 before spraying. Fix any and all pinholes ahead of time to avoid pin air. Don't use any epoxy fillers. Marinetex should be banished from the cat sailor's lexicon...hate that shite. It's ruined more gel repairs than any other substance known to man. Formula 27 works well.
Re: re-gelcoating something entirely [Re: SurfCityRacing] #240742
12/02/11 09:29 AM
12/02/11 09:29 AM
you make it look so easy. Must be the spliff!
Thanks for that cool vid
Re: re-gelcoating something entirely [Re: waterbug_wpb] #240747
12/02/11 10:34 AM
12/02/11 10:34 AM
Santa Cruz, CA
Santa Cruz, CA
I learned form the best in both realms. grin
I tried to make that vid using what a typical garage repair guy could get, or would have laying around. I shot it in my driveway, after work, the sun was going down, it was too cold, my wife kept knocking on the window to tell me it was dinnertime, you know, the typical hardships of repairing boats in an uncontrolled environment.
Re: re-gelcoating something entirely [Re: SurfCityRacing] #240774
12/02/11 07:02 PM
12/02/11 07:02 PM
Kaneohe Bay
Dray Offline
Dray  Offline
Kaneohe Bay
Old glass man here,
Never need anything but resin vapors to spin my ceiling. It's needed after grinding out the soft stuff for a repair and itching for a week.
The word "tooth" was used earlier. In the coating world it would be referred to as "profile". Yes 150 grit would be best to start with for either spraying or putting on thickened with a squeegee.
I think that's my 2 cents after sniffing resin for a few years.
NACRA Dealer
NACRA Infusion "sailing"
Hobie Tiger "sold"
Hobie 20 "sold"
Re: re-gelcoating something entirely [Re: Karl_Brogger] #240775
12/02/11 07:05 PM
12/02/11 07:05 PM
pgp Offline
pgp  Offline
What would you thicken with to squeegee?
Pete Pollard
Blade 702
Re: re-gelcoating something entirely [Re: pgp] #240777
12/02/11 07:15 PM
12/02/11 07:15 PM
Kaneohe Bay
Dray Offline
Dray  Offline
Kaneohe Bay
What ever is in my bag of tricks but mostly thicksil (a fine powder)
NACRA Dealer
Hobie Tiger "sold"
Hobie 20 "sold"
0 registered members (), 19,942 guests, and 908 spiders.
Most Online21,917
3 hours ago
