| Re: Rules changes
[Re: Karl Funk]
#240957 12/08/11 10:43 AM 12/08/11 10:43 AM |
Posts: 3,906 Clermont, FL, USA | Painting should be allowed. Gel coat is expensive and unreliable. Having an epoxy paint will make repairs and upkeep much quicker, easier and cheaper. Not to mention the ability to touch up our boats on site.
Who do I draft a more detailed letter to on this issue?
Talk about a sour taste in my mouth before even sailing the new boat!
Cheers, Karl Team Kwjiboat Karl, if you'd like you can send the letter to me and I'll forward it to the WC. However, as John indicated there are issues so... Anyway, I'm not sure if or when the the topic is going to come up before the council again. The way I hope it will work the is WC will reopen the issue. At that time I will send out ballot basically saying "allow paint", "don't allow paint" and I will cast our votes based on what the USF18 class wants.
| | | Re: Rules changes
[Re: Tony_F18]
#240958 12/08/11 10:53 AM 12/08/11 10:53 AM |
Posts: 3,906 Clermont, FL, USA | What is the motivation behind this painting rule? Is there an advantage to using it over gelcoat (apart from the weight)? Playing devil’s advocate here, the issue could be one more of perception than reality. I would imagine a painted boat would be marketed to say that weight has been removed from the ends and moved to the CG making the rig more stable than conventional gel boats (my boat is better). I'm not saying this is real but I have seen fleets get hung up over less, besides someone had to be the contrarian. Okay Andrew, you're up. I don't know when the minutes will be released.
| | | Re: Rules changes
[Re: David Ingram]
#240959 12/08/11 11:31 AM 12/08/11 11:31 AM |
Posts: 1,152 tampa, fl | Wouldn't concetrating the weight lower on the platform be an advantage? Moving the lost weight from the gel coat above the hulls seems counterproductive.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: Rules changes
[Re: JACKFLASH]
#240960 12/08/11 11:36 AM 12/08/11 11:36 AM |
Posts: 71 | I would assume if two cloths are not allowed in sails than we are all rule breakers for having windows in our mains and jibs. Technically that would be a different cloth. The sad part about all of this is that there are people who are trying to find the loop holes in the rules for the sole purpose of exploiting them thus creating all of this drama. The current rules say: The body of the sail shall consist of the same woven and/or laminated ply throughout with the exception of the window which may be different. | | | Re: Rules changes
[Re: ksurfer2]
#240962 12/08/11 11:55 AM 12/08/11 11:55 AM |
Posts: 3,906 Clermont, FL, USA | Wouldn't concetrating the weight lower on the platform be an advantage? Moving the lost weight from the gel coat above the hulls seems counterproductive. The marketing would be that the weight has been reduced at the the ends (bow and stern) to reduce pitching. My assumption is the boat would be at weight or maybe a little under and the saved weight on the ends would be moved low and to the middle of the hulls during the construction process not strapped onto the crossbeam post build. The argument could also be made that the weight saved with the paint has been transfered into making the boat stiffer. So, now the boat would be marketed as, it pitches less because... and it's stiffer because...
| | | Re: Rules changes
[Re: Sloansailing]
#240965 12/08/11 12:38 PM 12/08/11 12:38 PM |
Posts: 3,293 Long Beach, California | Here's the larger issue; there are two opposing philosophies at work on the Council - either voting is weighted by the number of members in each national body (the current rule), or all national bodies are weighted equally (i.e., one vote per country). Currently, the US would need a coalition of many other countries to make a change - three or four of the EU countries carry three- to five-times as many votes each as we do. The result, as we saw with the ridiculous vote to ban any F18 that gets selected as Olympic equipment, is that a two country EU voting bloc can become insurmountable. So while I greatly respect Dave's consistent effort to determine the US position on matters like paint and sail materials, it is unlikely we can make our position matter at the Council level under the current constitution.
I don't mean to sound discouraging or quash discussion - I think Dave is doing it right and we're lucky to have someone with his conscientious approach. I just want us to debate with a clear eye toward not only establishing a reasoned position, but also how to adopt that position in a meaningful way.
| | | Re: Rules changes
[Re: John Williams]
#240969 12/08/11 01:31 PM 12/08/11 01:31 PM |
Posts: 297 | Here's the larger issue; there are... Actually, I think (my opinion) the larger issue is that most F18's don't even the slightest clue as to how the rules are made, are changed, when, where, why or how. (Not snarky, its the truth...)
Nacra F18 #856
| | | Re: Rules changes
[Re: rexdenton]
#240972 12/08/11 02:00 PM 12/08/11 02:00 PM |
Posts: 71 | Actually, I think (my opinion) the larger issue is that most F18's don't even the slightest clue as to how the rules are made, are changed, when, where, why or how. (Not snarky, its the truth...) How does the process work? Do we have a unique opportunity to fix anything in Long Beach next year? | | | Re: Rules changes
[Re: Sloansailing]
#240976 12/08/11 03:03 PM 12/08/11 03:03 PM |
Posts: 1,021 Australia | As John said, there are some balance of power concerns in the current structure and they lead to the kinds of situations we see here now. There are 4 countries (FRA, ITA, NED, GER) that control half the votes of 22 countries total. So if those 4 want a rule, then they get it...
There is no polling of their members to decide what position the general membership wants to take on issues and the information supplied to the voting members is also not complete or verified. So the decisions are compromised and influenced unduly resulting in the mess we see today.
As for the actual arguments on the rule changes, below is an extract from the analysis I did on the recent class rule changes. I have completed this for the sail cloth issues as well.
There are 2 arguments presented to the WC regarding the use of paint:- 1. “fairing and painting to an ultra-high finish it is a very labour intensive and expensive process” 2. “there are popular paints and coatings in professional sailing that have been proven to give a performance advantage”
Modern paint systems allow builders to spray into the mould in the same way as gelcoat and they can be sprayed on the hull as a combined filler/topcoat. The painting process can be quicker overall than the total time to finish a gelcoated hull, hence there is a cost saving using some of the modern paint systems. Additionally there is nothing in the rules to prevent any manufacturer or competitor from fairing and preparing their gelcoated hulls to an ultra-high finish. As an example in 2009 Herbert Dercksen and I faired and prepared our Nacra Infusion to what could only be described as an ultra-high finish. The boat was longboarded, filled and the hull surface was professionally prepared at considerable expense. My point here is that preventing painted hulls does not prevent fairing and preparing hulls to a very high standard. There is no feasible way for the class to prevent this expensive practice other than to encourage manufacturers to produce high quality finishes that do not require post delivery work to rectify manufacturing blemishes.
The second point (claiming that Epoxy is advantaged over other paints) is not backed up by any facts or references, There are 3 main suppliers of paints in the yachting industry, Resene, Alexseal and Awlgrip. Each has various products including epoxy, polyurethane and mixes of epoxy and urethane. No one product that has proven to have any performance advantage. This is evidenced by the spread of different products in the worlds top yacht fleets. For example the 10 existing AC45’s are painted in products supplied by all three suppliers, the same spread of products is apparent in the TP52 class. There is not one product that is dominant and as such the overwhelming evidence is contrary to those claims. To put it simply: Just because somebody heard that product X was better than product Y is not justifiable grounds for the class to ban something that is standard practice in the boat building industry.
The new rule has effectively prevented the construction of boats in wood-epoxy and there is no provision in the rule for existing boats that are painted. Just how older boats are refurbished now is also a mystery, spraying gelcoat onto a 5 year old F18 is not feasible as any industry professional will attest.
| | | Re: Rules changes
[Re: macca]
#240980 12/08/11 04:35 PM 12/08/11 04:35 PM |
Posts: 297 | There are 4 countries (FRA, ITA, NED, GER) that control half the votes of 22 countries total. So if those 4 want a rule, then they get it...
Then our council is ruling by fiat. If that's true, the council may be doomed by a thousand internal cuts, and defined by growing apathy and disaffection with the ruling process. The description sounds like a recipe for systemic governance failure, and not in the long-term interests of a fast growing class interests worldwide. In my opinion, by-laws need to be connected with the world-wide interests, including minority representation, in order for the body sustain relevance and act on behalf of both the shared goals and differences of the constuency. This should change, if nothing more, than for the good and sustainability of the council.
Nacra F18 #856
| | | Re: Rules changes
[Re: David Ingram]
#240991 12/08/11 06:31 PM 12/08/11 06:31 PM |
Posts: 108 | Painting should be allowed. Gel coat is expensive and unreliable. Having an epoxy paint will make repairs and upkeep much quicker, easier and cheaper. Not to mention the ability to touch up our boats on site.
Cheers, Karl Team Kwjiboat How paint on the hull can kill F18 ? According to builder (we've some in France) only the material; gel coat cost 35€ for a F18, high tech paint, is more than 10 times more expensive : 400€. Also the construction process is better adapted to the use of gel coat. (direct in the mould) leading to simpler manufacturing and with lower cost. . Painting needs to prepare the surface (as a car with mastic) and heavy equipment to finish. You can use gel coat with painting pistol just diluted to repair as well as paint. More important to me is that we all know that chemical industry has no limit. If we accept paint on the hull the certitude is that tomorrow morning appears « magic paint » and also « magic price ». And then last but not least how make difference between paints? Destructive test? | | | Re: Rules changes
[Re: franck]
#240993 12/08/11 06:55 PM 12/08/11 06:55 PM |
Posts: 1,021 Australia | Painting should be allowed. Gel coat is expensive and unreliable. Having an epoxy paint will make repairs and upkeep much quicker, easier and cheaper. Not to mention the ability to touch up our boats on site.
Cheers, Karl Team Kwjiboat How paint on the hull can kill F18 ? According to builder (we've some in France) only the material; gel coat cost 35€ for a F18, high tech paint, is more than 10 times more expensive : 400€. Also the construction process is better adapted to the use of gel coat. (direct in the mould) leading to simpler manufacturing and with lower cost. . Painting needs to prepare the surface (as a car with mastic) and heavy equipment to finish. You can use gel coat with painting pistol just diluted to repair as well as paint. More important to me is that we all know that chemical industry has no limit. If we accept paint on the hull the certitude is that tomorrow morning appears « magic paint » and also « magic price ». And then last but not least how make difference between paints? Destructive test? Franck, A little knowledge is very dangerous.... I note on your own news website that you have the following news on the Cirrus F18:- "Le Cirrus R est un F18 conforme aux évolutions récentes de la jauge. Les coques ont une finition gel coat. Pour l’anecdote le rapport entre le coût de la matière gel coat et une peinture high-tech est de 1 à 10. Les contraintes de fabrication avec la peinture sont aussi plus importantes que le gel coat: mastiquage et cabine de peinture comme une carrosserie de voiture." Translated:- "The Cirrus is an R F18 in line with recent developments in the class. The shells have a gel coat finish. For the record the relationship between the cost of the raw gel coat and a high-tech paint is 1 to 10. Manufacturing constraints with the painting are more than the gel coat: glazers paint booth and a car body." Yet Mischa's brand new boat is painted.... So you should be very careful what you write. As for your claims about costs to produce in paint they are equally misguided:- It is possible to spray newer style paints directly into moulds in the same way as gelcoat, and then the finishing time to produce a hull is actually reduced compared to gelcoat hand finishing which is very labour intensive and slow. I am not sure what paint you have been quoted, but at 400 Euro material costs it would be 3-4 times more expensive than the very best paints used on Americas cup boats!! An actual material cost to paint an F18 in top of the line paint is 118 Euro. So perhaps you should review your position... | | | Re: Rules changes
[Re: macca]
#240994 12/08/11 06:57 PM 12/08/11 06:57 PM |
Posts: 108 | There is no polling of their members to decide what position the general membership wants to take on issues and the information supplied to the voting members is also not complete or verified. So the decisions are compromised and influenced unduly resulting in the mess we see today.
Have a look on our site www.f18.fr (sorry it's in french), you can check, with all due respect, you're wrong . You can also find our 2011 members list about 280 sailors, they all pay that explain europe financial crisis, (for 423 F18 sailors noticed by the french MNA) and the open database of F18 certificate. No arrogance, but please consider we are also democratic than you are, and with the same spirit. We are also huge fan of F18, with the same difficulties, perhaps more experience, because we faced questions since 1994. Also (european song): 200 members in Netherland (country just a little more bigger than brooklyn), 150 members in Germany (90% of the coast frozen 10 month on 12) and so on to Hungarian (last world), Estonian etc..., they are all F18 sailors, like Australian, American, Argentinian etc.. not more and not less than you are. Franck the frog Capricorn C1,5 (all C2 parts except hull) | | | Re: Rules changes
[Re: macca]
#240995 12/08/11 07:20 PM 12/08/11 07:20 PM |
Posts: 108 | How paint on the hull can kill F18 ?
Macca, A you noticed It was not a post upon Mischa's specific boat but about BCM production boats, which are finished with gel coat. You can believe or not that opening the door of painting now, is as dangerous as allowed carbon in daggerboard. Except that we can decide to put a limit (1,40 meters under the hull ) to daggerboard and check it quite easily. How make difference between paints ? No arm, no chocolate means here: no paint, no problem. The main question is not today's technology or price, it's to prevent chemical research and runaway with no limit. Franck | | |
2,260
guests, and 630
