| How many Blades out there? #241078 12/12/11 05:56 AM 12/12/11 05:56 AM |
Posts: 4 NSW, Australia | I have just acquired Blade 005 - and i noticed boats in the 700's.. Is the sequence broken up at all or are there that many produced? I know of a few here on east coast Oz, but there must be a lot more..
Chris Blade 005 Newcastle Australia
F16 Blade 005
| | | Re: How many Blades out there?
[Re: Remo]
#241093 12/12/11 01:25 PM 12/12/11 01:25 PM |
Posts: 6,049 Sebring, Florida. | How do you define "Blade"? Are we talking about some of the boats built from plans, out of wood, or just out of glass, and if glass, from which manufacturers? I'm pretty sure there is (or was) a "Blade" builder in Australia, and there's Vectorworks in the USA...so...? Which Blades are we talking about?
Blade F16 #777
[Re: Remo]
#241587 12/19/11 06:36 AM 12/19/11 06:36 AM |
Posts: 4 NSW, Australia | They are all based on the same original design from Australia - Phil Brander. I know that much. That makes sense that the sequence started again at 700 when they shifted a production base overseas later on. I think mine was one of the very first built and is now going through a rebuild. Anyone got any shots of their blade mainsail clew attatchment. My boom looks a little short for the outhaul to work correctly.. Any help be great cheers, Chris
F16 Blade 005
[Re: Remo]
#241595 12/19/11 10:03 AM 12/19/11 10:03 AM |
Posts: 1,246 Orlando, FL | Most US F16's have gone to a direct attachment to the boom. Notch a groove in the end of the boom use line tied to the clew with a couple of knots in it for tension in various wind conditions. Secure knot in groove.
USA 777
[Re: Remo]
#241663 12/19/11 05:47 PM 12/19/11 05:47 PM |
Posts: 4 NSW, Australia | Not a bad idea. Simple. So does the mainsheet attach to the boom directly or the clew also? Soft shackle? Cheers
F16 Blade 005
[Re: tback]
#241706 12/20/11 09:50 AM 12/20/11 09:50 AM |
Posts: 2,921 Michigan | good idea, I keep getting my outhaul line caught on my head. I guess i do like the option of adjusting it though.
My main is attached to the mainsheet via a loop of spectra that stays attached to the main clew all the time. When the main is put on the boat, the loop is put around the boom by lifting up the boom a bit. the mainsheet is then clipped to that loop
[Re: Gilo]
#241723 12/20/11 03:03 PM 12/20/11 03:03 PM |
Posts: 2,921 Michigan | I guess my concern is in really light air when you should let out the draft on the main some when heading downwind. Not sure it makes a huge difference, but it likely helps some. I agree though, that 90% of the time it is a "set and forget" control
[Re: PTP]
#241733 12/20/11 05:19 PM 12/20/11 05:19 PM |
Posts: 606 Maryland | I guess my concern is in really light air when you should let out the draft on the main some when heading downwind. Not sure it makes a huge difference, but it likely helps some. I agree though, that 90% of the time it is a "set and forget" control With the newer "set and forget" outhaul designed mains, you are releasing the downhaul going downwind anyway which also automatically eases the foot tension.
Kris Hathaway | | |
569
guests, and 241
