| New to the Fold #242167 01/08/12 08:45 PM 01/08/12 08:45 PM |
Joined: Oct 2011 Posts: 217 Palm Harbor, FL daniel_t OP
Posts: 217 Palm Harbor, FL | I bought an F16! I now am the proud owner of a Taipan 4.9.
The previous owner spent a good two hours showing me how to rig the boat. Most of it made sense, it seemed to be a lot like an F18 but a little smaller. :-) However, I would still love to hear about any tips or tricks you can think of that might help me out.
One other thing, I'm on the lookout for a couple of used harnesses. I'm 150 lbs and my wife is 115 lbs. If you have a harness or two gathering dust and would like to help a newbie out, that would be great.
I'm excited to get to know the boat, and hope to be comfortable enough with the boat to compete in Hiram's Haul this year.
Yea!
Daniel T. Taipan F16 - USA 213 | | | Re: New to the Fold
[Re: daniel_t]
#242185 01/09/12 01:55 PM 01/09/12 01:55 PM |
Posts: 217 Palm Harbor, FL | Okay, sure... My sails are brand new, but the spinnaker is getting little holes in the foot. It seems that the retrieval line is making the holes whenever the sail is snuffed. The previous owner suggested I remove the casing from the line, but that doesn't feel right. Would coating the retrieval line with McLube help or something else other than mangling my line?
I can't say I'm used to *sailing* an F18, but I have rigged one a few times. I've only sailed an F18 once, and because of our weight, it was all my wife and I could do to keep the boat upright. I'm assuming that we will have an easier time of it with the F16, but I guess I wont know for sure until this weekend.
[Re: daniel_t]
#242207 01/09/12 04:44 PM 01/09/12 04:44 PM |
Posts: 1,382 Essex, UK | Yes, strip the cover from the retrieval line for just the section outside the front of the chute. The small holes you are getting are friction burns in the cloth.
John Alani ___________ Stealth F16s GBR527 and GBR538 | | | Re: New to the Fold
[Re: daniel_t]
#242221 01/10/12 09:21 AM 01/10/12 09:21 AM |
Posts: 217 Palm Harbor, FL | I don't understand how removing the core, or the casing, would help stop the friction burns. If it is merely the fact that it makes the line thinner, couldn't I just use a thinner line?
Maybe this is just one of those mysteries and I need to bite the bullet and do it...
[Re: daniel_t]
#242223 01/10/12 09:33 AM 01/10/12 09:33 AM |
Posts: 6,049 Sebring, Florida. | The core is of a more slick material, and more flexible alone, so if you use that, it won't rub through the spin as easily.
OR...if instead you remove the core and use the cover, now the cover is much more flexible, and can flatten out going over the hoop, so then it won't rub through as much either.
And yes, you want as thin a line as will work, remember, you have still to clete it.
Blade F16 #777
| | | Re: New to the Fold
[Re: daniel_t]
#242247 01/10/12 02:03 PM 01/10/12 02:03 PM |
Posts: 1,382 Essex, UK | Taper the transition from core to core & cover and also stitch through both at the transition before whipping it to ensure a good connection that will not catch or creep.
If you decice to remove the core and keep the cover you only need to stitch through to stop creep.
As I said above, I prefer the slightly more complex removal of the cover.
[Re: Gilo]
#242265 01/10/12 05:31 PM 01/10/12 05:31 PM |
Posts: 217 Palm Harbor, FL | Did you sail other cats before? I had a Laser II with a comparable snuffer system (continuous line to both raise and snuff the spinnaker,) but I never had a problem like this with it. Its been years, but I think the fabric of the spinnaker was thicker on my Laser II. Maybe that's why I didn't have this problem, or maybe my halyard was thinner... I've sailed Hobies (from Wave up to Tiger,) but I never used a spinnaker on a cat.
282
guests, and 50
