Rating: 5
Re: best way to bed your beams ? [Re: downsouth] #243377
02/01/12 03:33 PM
02/01/12 03:33 PM
catman Offline
catman  Offline
Beam me up Scotty... There is no intelligent life on this planet.
Re: best way to bed your beams ? [Re: rehmbo] #243385
02/01/12 06:38 PM
02/01/12 06:38 PM
Originally Posted by rehmbo
A bottle of red wine always worked well for me!
-sorry - couldn't resist-
Mix up a Roofycollada.
Re: best way to bed your beams ? [Re: downsouth] #243394
02/02/12 12:43 AM
02/02/12 12:43 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
What is PVA, and where can it be obtained? Thanks!
Dave
Re: best way to bed your beams ? [Re: davefarmer] #243397
02/02/12 07:56 AM
02/02/12 07:56 AM
Poly vinyl alcohol. It's a spray on mold release (spray with paint sprayer). You build up several layers to form a film that is almost like saran wrap and can be peeled off when cured or washed away - it's very water soluble and easy to remove. It makes a pretty bullet-proof mold release or an air barrier for gelcoat that you need to cure in the open air.
When spraying on a waxed surface, you have to mist on the first coat or two and let each coat dry for about 15 minutes. Then you can lay down two or three nice glossy coats. It dries pretty smooth and glossy but it's about impossible to get a completely glassy smooth finish on it so it's probably not the best thing out there to use as a release for a very high end mold. It is waterbased so it works very well with ester based resins. You have to be sure to get a thick enough barrier when using epoxy...but it doesn't seem to affect the finish of the epoxy at all.
I buy mine at www.uscomposites.com but I'm sure www.fiberglasssupply.com or www.aircraftspruce.com has it as well.
Re: best way to bed your beams ? [Re: downsouth] #274554
08/09/14 04:23 PM
08/09/14 04:23 PM
RParentsail Offline
RParentsail  Offline
What's the best epoxy (with what characteristics) to use for this? I've decided to use epoxy and a pigment to color it in order to avoid that yellowing. Also, can you use cabosil with all epoxies to thicken it?
"Nothing that is worth knowing can be taught." ~Oscar Wilde
RPSailing.blogspot.com
Re: best way to bed your beams ? [Re: downsouth] #274560
08/09/14 10:13 PM
08/09/14 10:13 PM
Bille Offline
Bille  Offline
ANY decent epoxy , mixed with :
West-Systems 404 High-density adhesive filler ; will do
the job.
Do NOT use just any filler,(like micro-balloons) because
they are hollow spears that will break down with time.Some
fillers were designed as a sanding/fairing compound, and won't
work for a structural application !!
The splice i made for my Hobie-21se, i actually installed grease-nipples, and pumped in the filler with a grease-gun
from Harbor freight; then removed the nipples after the epoxy
gelled-off, but before it cured.
It worked Great !!
Bille
Re: best way to bed your beams ? [Re: downsouth] #274571
08/10/14 08:27 PM
08/10/14 08:27 PM
mikekrantz Offline
mikekrantz  Offline
I've had good success using teflon tape on the beams and West Six-10 as the bedding compound.
-Mike
Re: best way to bed your beams ? [Re: downsouth] #274572
08/10/14 09:18 PM
08/10/14 09:18 PM
Scarecrow
Scarecrow
Packing tape.
Re: best way to bed your beams ? [Re: RParentsail] #274583
08/11/14 06:57 AM
08/11/14 06:57 AM
No matter what pigment you add (unless it's black and use also use aluminum powder), epoxy will yellow.
The boat I have now had the beams previously bedded (by POs) with gelcoat. It's holding up just fine and where it oozed out it matches the boat perfectly.
I also just wax the beams with four or five coats of a good carnuba wax. I've never had a problem with them releasing (you have to go to some advanced etching to get epoxy or polyester resins to adhere to aluminum).
Re: best way to bed your beams ? [Re: Jake] #274682
08/13/14 02:49 PM
08/13/14 02:49 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
Originally Posted by Jake
Originally Posted by Mike Hill
I don't understand why you don't just spray PVA on the beams. It would take about 10 seconds to spray with PVA. Some people just like to work harder I guess.
Because PVA adds thickness which results in a not-as-tight fit as possible after it dissolves away. The wax works just fine. A semi-firm tap with a rubber mallet and the beams will release perfectly with a coat or two of wax.
Mike (the other Mike), I'm not sure I see the point of leveling the beams or even loosening the dolphin striker. I will take an "X" measurement on the boat to check squareness and try to do a little to square it up if it's out much...but you're not moving it much at all since the beam bolts are threaded into the hull. You have only the minimal amount of slop available in the beam through holes for the long bolt anyway..so most correction you put on it is just going to spring back after you release it anyway. Canted hulls introduce another level of difficulty (not the case with this F18 in question).
PVA is 2-4 mils thick in a heavy application (0.002"- 0.004"). It can be applied thinner to aluminum (0.001-0.002"): http://www.rexco-usa.com/documents/TDS_Partall%20Film%2010.pdf
If 0.002" is a concern to you, go ahead and not use the PVA. PVA guarantees a release every time.
I use 2-3 coats of wax (Rexco Partall Paste #2), followed by a light brush coat of PVA, tape off beam sockets with drop cloth and add thickened (with cabosil) gelcoat to the sockets. Plug the holes in the beams with the Partall Paste wax and avoid putting gelcoat near the bolt holes.
Scorpion F18
Re: best way to bed your beams ? [Re: samc99us] #274684
08/13/14 02:58 PM
08/13/14 02:58 PM
So does waxing the bare aluminum beam and not going through the extra step with PVA. I've seated more than my share of beams and they all released with a slight tap with a rubber mallet.
1 registered members (vasil), 289 guests, and 39 spiders.
