Boat lift for Hobie 16 #243876
02/10/12 08:30 PM
02/10/12 08:30 PM
C
catso Offline OP
catso  Offline OP
C
does anybody have pictures or ideas of boatlifts for Hobie 16 (on a lake). We have a bulkhead to deal with and very little beach. We hope to keep it on a lift when not in use.
Re: Boat lift for Hobie 16 [Re: catso] #243893
02/11/12 01:01 PM
02/11/12 01:01 PM
Albenarle NC
jackbr549 Offline
jackbr549  Offline
Albenarle NC
Don't have any pictures but have seen some. A friend used a jet ski lift and extended the platform to hold a 16, it has to be wider and longer. I have a lift in the back yard I got used I hope to use for a wave this spring.
Re: Boat lift for Hobie 16 [Re: catso] #243894
02/11/12 01:24 PM
02/11/12 01:24 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
If the water is reasonably shallow (<4'), the simplest and perhaps least expensive option would probably be a perch.
You'd need four 6' augers, two ~9-10' cross bars, 4 t-brackets, and perhaps some bunks or carpet-covered wood if you plan to get on the boat while on the perch. For my 18 I use some PVC pipe over the rear crossbar as a type of roller and then trailer bunks on the front that take ~75% of the load.
I use tie-down straps on all 4 corners when not in use. My setup easily survived a 70+mph windstorm last Memorial day. A small boat lift would have tumbled (along with the boat) for sure.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Boat lift for Hobie 16 [Re: rehmbo] #244092
02/16/12 03:31 AM
02/16/12 03:31 AM
C
ChristyShores Offline
C
Thank you very much for the tips. I really appreciate your generosity! smile
0 registered members (), 2,616 guests, and 726 spiders.
