| Re: Soft Shackles.
[Re: JJ_]
#244317 02/19/12 09:39 AM 02/19/12 09:39 AM |
Posts: 807 Hillsborough, NC USA | That's an interesting modification. Under load it should be secure, but I'm not sure it would hold while shaking (such as at the clew of a jib). I can certainly make something similar if desired, and may try it out myself. Of coures, there's really no purpose (other than neatness) to the bury anymore. One might just as well make an offset brummel eye, brummel again at the other end, and tie the terminal knot. Also note that these instrucitons only put in half of the locking brummel. I prefer the fully locked version. Regards, Eric
| | | Re: Soft Shackles.
[Re: Isotope235]
#244408 02/21/12 11:25 AM 02/21/12 11:25 AM |
Posts: 91 Dunedin, FL | That's an interesting modification. Under load it should be secure, but I'm not sure it would hold while shaking (such as at the clew of a jib). I can certainly make something similar if desired, and may try it out myself. Of coures, there's really no purpose (other than neatness) to the bury anymore. One might just as well make an offset brummel eye, brummel again at the other end, and tie the terminal knot. Also note that these instrucitons only put in half of the locking brummel. I prefer the fully locked version. Regards, Eric I've had this as my jib clew for 2 years, no problems whatsoever. | | | Re: Soft Shackles.
[Re: Headhunter]
#244422 02/21/12 12:50 PM 02/21/12 12:50 PM | MN3
| MN3
Unregistered | didnt we have to pull over on caladisi one time (pauly was with you) to re-attach the soft shackle on your jib (head) that came apart? I've had this as my jib clew for 2 years, no problems whatsoever.
| | | Re: Soft Shackles.
[Re: ]
#244480 02/22/12 08:48 AM 02/22/12 08:48 AM |
Posts: 91 Dunedin, FL | didnt we have to pull over on caladisi one time (pauly was with you) to re-attach the soft shackle on your jib (head) that came apart? I've had this as my jib clew for 2 years, no problems whatsoever. No doucherocket, that was a halyard and of a different design. | | |
542
guests, and 44
