| Re: Viper lifting foils
[Re: taipanfc]
#244928 02/29/12 03:21 AM 02/29/12 03:21 AM |
Posts: 242 Brisveagas | My standard Viper gets 10 sec averages over 20 kts so maybe it can.
I heard a rumour that these things will fit the old boats as well. You dont need to lift outof the water like a moth when you have as much power as an F16.
I wonder if there will be any more surprises before the trials.
Aido Viper 288
[Re: taipanfc]
#244940 02/29/12 09:17 AM 02/29/12 09:17 AM |
Posts: 6,049 Sebring, Florida. | OK...so how did they get the L boards down into the hulls? Can they be slid up from underneath? Hobie figured out how to 'foil' a long time ago, yet it never really caught on as a racing class. Can any of you older guys who were active 'back in the day' of the Hobie Tri Foiler shed some light on some of the issues? I remember seeing a fleet of them, once, at the Wildcat regatta, but they looked like a real pita to put in the water, and weeds on the foils were always a problem. http://www.youtube.com/watch?v=zXSgZCDVWOM Stick with it, at about 2:37 it shows some of the design concept and the L foils, and how the ski at the front adjusts the up/down lift. It also shows Russel Long going 43 knots in his "Long Shot" during a speed run in France, in the ditch and a two up regular version going 35knots at the end. But I notice all the video speed shots are done with good wind...on FLAT WATER. Great for a lake. I'd love to have one here on my lake, but I'm not convinced a 'lifting' foil, if C boards or L boards, is going to be fast on lumpy water, in the kind of racing we do in the ocean or lage bay. All that porpoising up and down can't be fast. You may get a small burst of speed when you come up, but when you nose dive back down, it could get ugly. They'd have to come up with a device to controld the AOA to yeild a steady ride over rough seas. Anyone know where Gregg Ketterman is today? I wonder what he's up to, design wise.
Blade F16 #777
[Re: taipanfc]
#244942 02/29/12 09:35 AM 02/29/12 09:35 AM |
Posts: 439 Memphis, TN | I'm sure you will see these at the Olympic trials.
Timbo, Thats probably want they did, guessing here, but that isn't allowed in the F16 rules either. You have to be able to lift the board up out of the well. Again, F16 rule.
Viper USA 132
1984 Hobie 18
[Re: orphan]
#244949 02/29/12 12:21 PM 02/29/12 12:21 PM |
Posts: 217 Palm Harbor, FL | Would a board with a hinged tip be illegal? Yes, that is illegal. According to F16 rules: "End fences/horizontal appendages below the waterline will not be allowed."
Daniel T. Taipan F16 - USA 213 | | | Re: Viper lifting foils
[Re: taipanfc]
#244954 02/29/12 01:09 PM 02/29/12 01:09 PM |
Posts: 4,451 West coast of Norway | In my opinion not allowed under current F16 rules: Definitions 7.13 Daggerboards and Centerboards
All lift producing elements that have as the pre-dominant purpose to resist sideways movement of the craft while sailing and that aren't canted at a greater angle than 6 degrees of the vertical when the boat is level on the waterline.
A centerboard is only different from a daggerboard in the sense that it is folded or rotated away rather than slid away when in danger of hitting submerged objects. Rules: 1.6 Daggerboards and rudders
1.6.1 The platform shall be equipped with a pair of rudders. 1.6.2 In addition to the rudders, the platform may also be equipped with a pair of daggerboards or centerboards. 1.6.3 All performance calculations, such as handicap ratings, shall be performed as if a platform has daggerboards or centerboards, even though a particular design may have neither of them.
1.6.4 (Added by vote, August 2007) For the avoidance of doubt, daggerboards/centerboards will conform to the following : a) Curved/’Banana’ boards will not be allowed. b) Assymetrical cross-section profile boards will be allowed. c) Fore/aft movement of the boards when in the down position will not be allowed. d) End fences/horizontal appendages below the waterline will not be allowed. The board shall be capable of removal, without tools, via the upper opening of the case. e) There will be no limitation on the daggerboard/centerboard length I dont see any interpretation that will allow for this on daggerboards. On rudders I read this in such a way that fences are allowed (like used on the Stealth). Will be interesting to see if they send a boat with these daggers to the olympic trials. I dont know about any substantial two boat testing with this technology where the results are public. | | | Re: Viper lifting foils
[Re: taipanfc]
#244982 02/29/12 07:59 PM 02/29/12 07:59 PM |
Posts: 6,049 Sebring, Florida. | WHAT IF....
Put the dagger slot in the hull at a 45 degree angle, so you'd have a long, straight dagger board, but on a 45 degree angle, which would provide some amount of lift, perhaps even more than a C board...yes? And you'd be within the rules, yes?
Has that been tried yet?
Blade F16 #777
[Re: taipanfc]
#244988 02/29/12 09:52 PM 02/29/12 09:52 PM |
Posts: 6,049 Sebring, Florida. | Ahh...well, we could change the rules. I think I'd rather have straight boards at a 45, than have to deal with C, or L boards, and I think that would provide more lift too.
Blade F16 #777
[Re: Timbo]
#245017 03/01/12 12:45 PM 03/01/12 12:45 PM |
Posts: 5,590 Naples, FL | except if you pull the board out and clip the boat next to you...
[Re: Timbo]
#245018 03/01/12 12:59 PM 03/01/12 12:59 PM |
Joined: Jan 2011 Posts: 14 Lincoln, Nebraska FRENZIED
Posts: 14 Lincoln, Nebraska | I think I'd rather have straight boards at a 45, than have to deal with C, or L boards, and I think that would provide more lift too. Agreed. Whatever the angle, I can't imagine that moving curved boards back and forth is as easy as straight boards (not to mention the obstruction when they are up). I'm very curious to see how well the AC crew handles curved dagger boards on the AC72s.
LANDLOCKED
[Re: sail7seas]
#245036 03/01/12 04:30 PM 03/01/12 04:30 PM |
Posts: 9,582 North-West Europe | That would be absolutely doable and thanks for that idea. I might steal it from you.
20,023
guests, and 1,305
