| Re: Texel Number for P19 MX?????
[Re: brobru]
#24533 09/24/03 01:09 PM 09/24/03 01:09 PM |
Posts: 3,116 Annapolis, MD | Well that is a can of worms reminiscent of the Nacra 6.0 NA rating used for the Tybee 500 race.
Basically, the sails have to be measured and then numbers put into their calculator. The rating system was not kind to the Nacra 6.0NA I don't think many could have sailed the boat close to its calculated rating.
Good luck.
crac.sailregattas.com
[Re: Mark Schneider]
#24534 09/24/03 05:55 PM 09/24/03 05:55 PM |
Posts: 552 | Ok, someone figure this out ( Wouter, are you out there?) Performance site has a main of 247 s.f or 22.95 m square ,. Actually,..this is a TOTAL sail area,.....they do not give a main sail area and then a jib area (.....makes you wonder a little,....all the inter's on the same site give a respective main and then a jib sail area....  ) Make no mistake,......the boat likes the new sail configuration........it is truely turbo mode! Bruce St. Croix | | | Re: Texel Number for P19 MX?????
[Re: brobru]
#24537 09/25/03 02:55 AM 09/25/03 02:55 AM |
Brobu,
PLease gether the following info :
Overall weight ex spi (if you have only overallweight inc spi than I can use that too) Mainsail area Mainsail luff length Jib area Jib projection on mast (often this is equal to the leech length) Length hulls are of P19 I guess
When you have these sorted out than I'm willing to calculate the P19 MX number for you. PLease provide the sources you used too.
WOuter
[Re: brobru]
#24541 09/25/03 12:23 PM 09/25/03 12:23 PM |
Posts: 3,116 Annapolis, MD | Hi Bruce,
One question: What are your reasons for choosing Texel over the USPN system.
One comment: The performance data has the P19MX rated slighly faster then a Hobie 20 and almost as fast an old Tornado (100). Since Texel rounds to whole numbers, my guess is the rating will be about 101 when all is said and done. (not much different then the 102 currently used)
One opinion: As always, the relative performance (and rating) differs between the comparable boats as the wind picks up. (Taken into account by USPN) the current texel system strives for simplicity and uses a single rating number. Are most of your races 45 minute windward leeward or Olympic courses OR are they several hour distance races? IMO, Boat handling issues dominate the differences in elapsed time on short courses and the rating system and its precision is not that important. However, distance races really depend on ratings with a bit higher precision as true boat speed starts to dominate the results.
Good luck Mark
| | | Guys, sail area 's ?
[Re: brobru]
#24543 09/26/03 04:14 AM 09/26/03 04:14 AM |
Posts: 9,582 North-West Europe | Are you in agrrement of sail area's and what is the Spi size ?
I need those .
| | | The P19 MX rating
[Re: brobru]
#24548 09/29/03 06:31 AM 09/29/03 06:31 AM |
I took the hull measurements and overweight of the Texel website. I'm sure about the hull measurements and I don't trust the PC weight quotes.
I've estimated the luff lengths of the various sail on the size of the sails and what is specified on the Texel website for a normal rig. I'm confident that I'm close enough.
No spi as requested.
Weight 185 rated length 5,79 Main area 17,67 Main luff 8,7 Jib are 6,98 jib projection on mast 5,9 Boards yes no spi doublehanded.
TR = 100 (no spi) and 96 with texel style spi od no more than 21 sq.mtr.
With weight 175 the ratings drop to TR = 99 (no spi) and TR = 95 with spi.
I hope this helps
466
guests, and 46
