Leaving your boat in the water #24626
09/28/03 10:52 AM
09/28/03 10:52 AM
yankyfan2000 Offline OP
I have to leave the boat in the water becuase i have no other choice. I have it anchored about 30 feet out in the lake. I herd something about putting a bungee on the shrouds to keep them from slapping around?? Can someone explain this and give me some other tips of if your leave your boat in the water.
Anthony-----H14
Re: Leaving your boat in the water [Re: yankyfan2000] #24627
09/29/03 03:27 AM
09/29/03 03:27 AM
Australia
Jules_topcat Offline
Australia
I will admit i dont like seeing boats left in the water because we have had so many of those boats left in the water and he just died. The reason why they say to bungee the sidestays is because normally when people leave they're boats with their mast up the mast is really sloppy and slips every where. The dungee is just to stop the loose stays and to setle the mast down in windy conditions. Make sure you sail your boat alot and give a good pollish/scrub on the boat when left or it will die.
Jules_topcat
Re: Leaving your boat in the water [Re: Jules_topcat] #24628
09/29/03 06:17 PM
09/29/03 06:17 PM
yes, everyyear i scrub the boat down real good, and when your bungee the shrouds do you bungee them to each other or to the frame?
Anthony-----H14
Re: Leaving your boat in the water [Re: yankyfan2000] #24629
09/30/03 09:19 AM
09/30/03 09:19 AM
Australia
Australia
it doesn't matter really but think about it because if you place them wrong they'll move up or down and wont work with out tention. What i would do is tie the side stays together and pull them down with as much force as possible and then tie a normall peice of rope to the centre to hold it in place. You would just have to think about how hight you want the bungee.
Jules_topcat
Re: Leaving your boat in the water [Re: yankyfan2000] #24630
10/19/03 11:05 AM
10/19/03 11:05 AM
swampy Offline
swampy  Offline
If you leave your boat in the water, any waves will cause the mast to move back and forth which causes the shrouds to slacken and become taught over and over, which causes a lot of stress and strain to the wires. Anything you can do to limit this stress on the shrouds is good, bungee cords is a good place to start.
I would also highly recomend that you secure both halyards off of the mast. The main halyard in particular will slap the mast in time with the movement of the water, and remove its' protective anodizing if left secured to the mast cleat. You can elliminate this by running it to any point off the mast(like to the tramp lacing, or one of your side stays)
Lastly it is a good idea to make sure that you remove any water that makes its way inside the hulls. In the past I have used a sponge through the ports I installed in the bows of the boat. If you don't have ports, you should periodically beach the cat and remove the plugs to make sure there is no water, and or drain and dry if there is.
Hope this helps a little, andrew
Re: Leaving your boat in the water [Re: swampy] #24631
10/19/03 08:05 PM
10/19/03 08:05 PM
Y
yankyfan2O00 Offline
Y
Where would you attach your bungee cords?
Re: Leaving your boat in the water [Re: yankyfan2O00] #24632
10/20/03 11:10 AM
10/20/03 11:10 AM
Australia
Australia
you can attach the bungee cords practly any where. You could tie it from your dolphin striker to your bridles or even side stay to side stay. or even tie them all down. The idea of this is not to strech your wires and mess the boat up.
Jules_topcat
Re: Leaving your boat in the water [Re: yankyfan2000] #24633
10/23/03 12:11 AM
10/23/03 12:11 AM
C
char Offline
char  Offline
C
Bungee cords are an interesting idea. You could also take your jib sheets, attach them to the jib tack and use the jib cleat to pull the forestay in and pull the shrouds tight.
Re: Leaving your boat in the water [Re: char] #24634
10/24/03 10:07 AM
10/24/03 10:07 AM
Australia
Australia
you so could but it doesn't matter how tight you get them your always going to have some movement and then your ropes will wear away. The whole idea of this is not to reck your boat but stoping the wearing away of materials. Bungee works in a way where it will allow movement but only enough to things dont strech and it relieves the stress on the wires and mast and all other parts.
Jules_topcat
0 registered members (), 3,028 guests, and 384 spiders.
