Re: I think I've asked this before. [Re: Karl_Brogger] #246633
04/02/12 08:55 AM
04/02/12 08:55 AM
Houston
carlbohannon Offline
Houston
Wood CNC's..
If you are going to go to the trouble, why not machine a foil out of a block of laminated wood/composite. I don't remember anyone trying that.
Build your block out of wood or foam laminated with fiberglass, carbon, Kevlar, foam, aluminum... You could leave appropriate volumes hollow and except for your reference points, the finish could be sloppy.
Machine out the foil then machine out the skin(wood, carbon prepreg...) and glue them together
Or use a reinforced paper for the skin. Print it out on a large printer with little cutouts to make it lay flat. You could print whatever graphics you like. You could have a foil with your face on
I don't think this has been tried with a foil. I have heard of similar methods used for architectural pieces or high price furniture. You could be the first and lead the way if it shows promise.
Re: I think I've asked this before. [Re: carlbohannon] #246636
04/02/12 10:18 AM
04/02/12 10:18 AM
Originally Posted by carlbohannon
Wood CNC's..
Phil's foils...he's been machining wood core foils for some time. I think he's since merged operations with CCI.
http://fastcomposites.ca/publications/TankTalkPhilsFoils.pdf
http://www.fastcomposites.ca/site/marine/design-tips-fabrication-overview/care-of-wood-cored-foil/
Re: I think I've asked this before. [Re: Jake] #246650
04/02/12 03:33 PM
04/02/12 03:33 PM
catandahalf Offline
catandahalf  Offline
Hey Jake >
I was just gonna say Phil's Foils or maybe mention Jim Bauman, from Recreational Composites. JB has done a few cat and tri foils as you know. He is about finished with restoring the C 24 and is willing to work for food smile
Re: I think I've asked this before. [Re: catandahalf] #246651
04/02/12 03:49 PM
04/02/12 03:49 PM
Originally Posted by catandahalf
Hey Jake >
Bauman is great - I had him clean up a pair of Nacra 20 foils for me once and he became standard to clean up our foils from then on. There's nothing worse than 500 miles on a boat that speed warbles a song through the water all day and night. A little touch up from Jim and they are silent!
Re: I think I've asked this before. [Re: Jake] #246653
04/02/12 07:00 PM
04/02/12 07:00 PM
Thunder Bay ON CAN
M
mmadge Offline
mmadge  Offline
M
Thunder Bay ON CAN
Karl with all this time you have spend the Weekend and Build yourself a DN.With all your carpentry skills you would have it built in no timeI am coming down this summer to Build some Planks with A few guys.
Re: I think I've asked this before. [Re: Karl_Brogger] #246654
04/02/12 07:31 PM
04/02/12 07:31 PM
Karl_Brogger Offline OP
DN is on the short list.
Re: I think I've asked this before. [Re: Jake] #246658
04/02/12 09:27 PM
04/02/12 09:27 PM
Ocean Springs, MS
Capt_Cardiac Offline
Ocean Springs, MS
Jim's retired from epoxy work. Too much exposure. Sad to see a master retire.
Capt Cardiac
Ocean Springs Yacht Club
Sailor
Nacra20 - Flight of Ideas #5
Re: I think I've asked this before. [Re: Jake] #246673
04/03/12 09:17 AM
04/03/12 09:17 AM
Houston
Houston
What I was thinking about is a little different from machining a wood core and then vacuum bagging or molding a skin over it.
The idea started years ago when I saw an exotic piece of furniture built like this. With this method the structure was built into the "block". First the skeleton was bonded to gather in a jig. Long, short, and little blocks of wood, composite and even steel was joined to form the structure. Then the outer wood that will be seen was bonded to the structure so that it formed a rough blocky equivilent to the final shape. Then the furniture was carved out and finished. The advantage was you could build "solid" wood in shapes that are not structurally possible with plain wood.
When I saw this, my first thought was you could build a hollow wood rudder by laminating strips of wood and composite for strength. You would not need the jigs and molds normally needed. Just build the rough shape around a hollow core and cut the outside to the final shape.
While this might not be as light as say a hollow core carbon, as long as you have access to a way of cutting out the final shape, the tools needed are simpler. Also since molds are not needed, it would be easier to build rudders with different foil profiles or even shapes.
I don't think this will revolutinize the world, but if you want to CNC a set of foils, its probably better and cheaper than starting with a block of aluminum.
Re: I think I've asked this before. [Re: Karl_Brogger] #246674
04/03/12 10:10 AM
04/03/12 10:10 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
For straight foils, you can get by with CNC cut foam cores (high density foam) and laminating carbon over them (lots of carbon). If people are interesting, I can cut 100 PSI foam on my CNC for reasonable prices.
The issue is when you go longer or curved; in these cases you need a CNC router machined core and a PVC based foam or wood core. Finding someone that will machine cores or molds for reasonable prices is not a trivial task, I have a few sources and may evaluate designing and building some curved A-Cat foils if the business case is justifiable.
As far as aluminum is concerned, built properly you can approach composites in weight and strength, but time wise it would take longer than the methods proposed above (unless you are THE metal guy). The corrosion issues posted above have never really been solved, take a look at any aluminum vessels (boats or seaplanes come to mind) after 10 years. Foils would not hold up very well to this abuse!
Scorpion F18
Re: I think I've asked this before. [Re: Jake] #246677
04/03/12 01:03 PM
04/03/12 01:03 PM
I believe you could have used him on your 18 at Tradewinds. According to the Vid, those things were pretty dang loud! smile
Re: I think I've asked this before. [Re: Capt_Cardiac] #246682
04/03/12 07:54 PM
04/03/12 07:54 PM
catandahalf Offline
catandahalf  Offline
Jim is still in the foil business. He is finishing the C 24 as his final tribute to boatwork. He is hoping to mount the ama this week and begin installing the nets.
Once this boat project is complete he will be devoted to his windsurfing fin business, sailcraft foil design, fabrication, and repair.
Re: I think I've asked this before. [Re: Karl_Brogger] #246693
04/04/12 07:41 AM
04/04/12 07:41 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Would a billet aluminium blades and boards work?
Would they be stronger?
Would they be lighter?
I'm gonna go out on a limb and say they'd be definitely cheaper. Once you've got the file, load up a blank in a 4 axis cnc mill and basically walk away. Plus polished boards would be frickin' cool. Or even anodized. Might want to make the top removable, a bent board could be trouble if you couldn't pull it out the top......
There are many alloys available, some are very strong, some not some have excellent corrosion behaviour, some not, and so on. But fact is that the right alloy is resistent to salt water and strong (as proven by thounds of masts). It has similar strength to hand layed up glasfibre, but less than carbon. Best production process would be extruding (if you can live with a straight board), not machining. Topcats use extrude alu rudders since ever. They have decent quality and are unkaputtbar (undestructable). At all the whole rudder system is a nice one on the Topcats.
Not cheaper than some glass boards though. http://www.topcat.de/shop/index_e.htm . The rest of the boat is fairly outdated...
Alu rudders wouldn't be particular heavy, about the same or a bit more than glass fibre boards of the same strength and size and maintenance free by the way.
Cheers,
Klaus
