Re: I broke my Battlestick [Re: David Ingram] #246963
04/13/12 09:23 AM
04/13/12 09:23 AM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
If you want a nice finish with less sanding, and are willing to spend a few more bucks, Soller Composites also sells treated shrink-tube you can use instead of tape or peel-ply. You wet down the cloth (or sleeve), slip the shrink-tube over the joint, and shrink it down from the middle out to each end. That squeezes out the excess resin. Once cured, you cut and peel it off, leaving a nice, smooth surface.
Be prepared for sticker shock though. The treated shrink-tube costs more per-foot than the carbon fiber sleeving.
If you want to make a plug out of carbon fiber, the sleeving would work pretty well for that too.
Eric
Re: I broke my Battlestick [Re: Jake] #246964
04/13/12 09:28 AM
04/13/12 09:28 AM
Houston
carlbohannon Offline
Houston
Originally Posted by Jake
My method makes the sleeve external around the fracture.
Do not ask me to explain, I have documented proof that my Structural Design skills should not be trusted so I can just parrot words "unless your external repair is stiffer than the original tube, you get some bending at the repair, once that happens you are concentrating loads at the original break on a repair that is weaker than the original tube. After that, you get cracking and finally the repair fails. That is one reason you want to use a piece of the original tube as an inner sleeve, properly done, this bends like the original tube so you are not concentrating the stress...... If you use a repair that is much stiffer that the original, the tube will bend at the edges of the repair causing cracking and failure"
Don't take this as any gospel, the standard methods are probably way overkill.
My method is to try a tapered joint with a external sleeve. If it breaks at same point again, redo it with an internal sleeve. The exception to this are masts. With masts I use everything I know and try not to dream up stuff that will make things worse.
Re: I broke my Battlestick [Re: samc99us] #246967
04/13/12 09:31 AM
04/13/12 09:31 AM
Originally Posted by samc99us
Where are ya'll ordering your supplies from? Fiber Glast is one of the most expensive sources for fiberglass or carbon cloth. CST may be the only supplier to top them.
Solar Composites generally has the best pricing on carbon cloth stateside. ACP has good pricing on sleeves: http://www.acpsales.com/Tapes-and-Sleeves-c-4957.html
Tape can be made from sheets of 5.7oz carbon, I do it all the time. Sleeves are much better for tube type repairs, simply because they are easier to work with. I've repaired 3 hockey sticks and a myriad of broken carbon tubes in the past few weeks and most all were a 30 minute job with the sleeve, and all came out stronger than the original tube.
On this, I will suggest you use super glue (thin CA) to bond the stick back into shape. Epoxy would do OK but CA dries instantly so if you can get a second person to apply the glue while you hold the joint in place it will work perfectly (CA is near as strong as epoxy but more brittle in this application). Then scuff the surface with 150 grit paper and apply the sleeve or tape wrap with epoxy. Use Jake's and/or Bille's suggestions above for wrapping with peel ply to get a good finish. Clear tape can be substituted for peel ply in a pinch but is likely to stick to the mess when you are done.
www.USComposites.com in Florida or www.fiberglasssupply.com.
Re: I broke my Battlestick [Re: carlbohannon] #246969
04/13/12 09:32 AM
04/13/12 09:32 AM
Hey, Hey...I'm usually the guy for overkill...but....Errrrr...it's a tiller. Making the finish on the external sleeve pretty is a bonus. I've repaired several on my a-cat and haven't had a problem (I keep dropping the tiller in the water when rounding A-mark and it gets caught under my rudder arm and breaks). The only stresses a tiller sees that might cause the kind of cracking you are talking about would simply see it break somewhere else when the repair is bulletproof.
A mast? now that would be a different story.
Re: I broke my Battlestick [Re: Team_Cat_Fever] #246971
04/13/12 09:46 AM
04/13/12 09:46 AM
Clermont, FL, USA
David Ingram Offline OP
Clermont, FL, USA
Saved by the Carbon wonder boy?
bingo
F18 USA 242
http://www.solarwind.solar
Re: I broke my Battlestick [Re: David Ingram] #246975
04/13/12 11:48 AM
04/13/12 11:48 AM
Originally Posted by David Ingram
it will be good to learn how to work with the black nasty.
Does he know you're calling him that?
Re: I broke my Battlestick [Re: waterbug_wpb] #246991
04/13/12 04:20 PM
04/13/12 04:20 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
He does now.
Isak Dinesen
E. B. White
0 registered members (), 5,776 guests, and 514 spiders.
