| Derlin screw #24697 10/01/03 12:05 AM 10/01/03 12:05 AM |
Joined: Aug 2003 Posts: 7 Guadalajara, Mexico AlfonsoVega OP
Posts: 7 Guadalajara, Mexico | How the hell do I untighten the derlin screw under the rudder's spring and plunger. I tried a wide screw diver, WD40, I guess I allready ruined the groove in it since it's plastic.
Appreciate the tips
Pilatos
| | | Re: Derlin screw
[Re: AlfonsoVega]
#24698 10/01/03 12:42 AM 10/01/03 12:42 AM |
Posts: 283 | You may ultimately have to drill it out.
Another thing I've done to get a better grip on the screw, is to take that wide screwdriver you've got, heat it up (not cherry red, just hot) with a propane torch, then quickly and firmly stab it into the screw. You'll then perhaps be able to get better leverage on the screw.
Drilling it out is no big deal, as it's obviously needing to be replaced anyway if you're having that kind of trouble.
The old On the Wire web site had a good article on cleaning up the threads after you get the old delrin screws out. All of their articles are now on thebeachcats.com, so you may want to look for that as well.
Cheers!
Tim
Tim D. Johnson
Hobie 20 #690
Bald Eagle Yacht Club, Fleet 52
www.beyc.org | | | Re: Derlin screw
[Re: AlfonsoVega]
#24699 10/01/03 02:00 PM 10/01/03 02:00 PM |
Posts: 805 Gainesville, FL 32607 USA | I have heated and drilled out several Delrin screws. Most of the plastic can be drilled and screwdrivered out or heated to get it out of the casting. But take it easy with a propane torch- as it kills the anodized color. Then you can buy or borrow a coarse thread pipe tap that fits the threads exactly to clean the corrosion off. (3/4 inch? -I can't remember). Take your almost clean casting to the hardware store and get the right size by screwing a iron pipe nipple part way into it. (Note- a threaded pipe is conical, not cylindrical, so don't put it in very far.
| | | Re: Derlin screw
[Re: dacarls]
#24700 10/01/03 02:11 PM 10/01/03 02:11 PM |
Posts: 12,310 South Carolina | Dave,
Doesn't a pipe tap also have a tapered shape to it?
Jake
Jake Kohl | | |
588
guests, and 22
