Re: Advice on Cat design [Re: phill] #24813
10/13/05 08:27 AM
10/13/05 08:27 AM
Houston
carlbohannon Offline
Houston
That is cool. I have designed and built my own boat so I know how much fun it is just to sail it.
While I was finishing the rig for my boat, I ran it with a laser rig. The mast step is very high torque. My first 2 maststeps failed. My 3rd was based on brute strenght and survived for a month. At winds above 15 kts it made very bad noises.
We looked at using a 10.5 meter sq wind surfing rig. My sailmaker thought the way to do it was to sew the shrouds and forstays to the sail sleeve. A simple test showed it would probably work. Then I was offered a broken A-Class mast and ....
Carl
Re: Advice on Cat design [Re: Andy_Lyne] #24814
08/02/06 05:09 AM
08/02/06 05:09 AM
Sydney Australia
Berny Offline
Berny  Offline
Sydney Australia
I built a cat like that some years back. It lives in my back yard in bits, the windsurfer mast substituting for a an early spinnaker pole for my F14.
I used 50mm (2") dia scaffolding tube for my tramp frame and hiking rails and employed the end fittings to connect it all together. I put surfboard fin boxes in the decks and bolted fabricated channel brackets to those to support the tramp frame.
I intended to have the hulls articulate to accommodate the angle of heel. Steering came from the mast raking back against a big bungy as the sheet was tightened [no rudders].
The articulation concept was flawed but it sailed well in light breezes.
I probably should have continued with it's development but something else distracted me at the time.
As best I can remember there are no pics.
Re: Launch of my car toppable cat [Re: Andy_Lyne] #24815
08/02/06 05:21 AM
08/02/06 05:21 AM
Atlanta
bvining Offline
bvining  Offline
Atlanta
I have just received the go ahead from the missus to start my next project... . I have this obsession with easy to rig car toppable quick boats, so this is going to be a mono hull with racks and stabilizing foils.
Sounds like you need to build a Moth next.
Bill
Re: Advice on Cat design [Re: Andy_Lyne] #24816
08/02/06 07:52 PM
08/02/06 07:52 PM
Bay of Islands, NZ
warbird Offline
warbird  Offline
Bay of Islands, NZ
Looking at your image I would considder the PT box section but would also bolt the section flat across each hull. If you want the rise for a dryer ride I would come up off that and move the risers closer to inside of hulls to create less drag when healing and wet. Good luck
0 registered members (), 2,694 guests, and 623 spiders.
Yesterday at 10:10 AM
