Halyard release on i20 #248510
05/17/12 09:19 AM
05/17/12 09:19 AM
Chesapeake va
C
catsailor2032 Offline OP
C
Chesapeake va
I've had a i20 for 13 years never had a problem releasing the main, now that I am using another main I can't get it to release in the normal way, pulling the halyard and over rotating the mast. Any ideas. Thanks
Sailing catana411. i20
Re: Halyard release on i20 [Re: catsailor2032] #248511
05/17/12 09:24 AM
05/17/12 09:24 AM
is it just re-hooking each time you try to pull the main down?
Any trouble getting the main up (like the bolt rope is snug) and hooked?
there might be a magic way to tie the knot on the halyard ring. Or the headboard might be twisted a bit...
Re: Halyard release on i20 [Re: waterbug_wpb] #248512
05/17/12 09:27 AM
05/17/12 09:27 AM
Chesapeake va
C
C
Chesapeake va
Sail goes up great , it's like it's not going up enough to release
Re: Halyard release on i20 [Re: catsailor2032] #248513
05/17/12 09:29 AM
05/17/12 09:29 AM
Chesapeake va
C
C
Chesapeake va
I have a twist shackle that goes to the halyard ring
Re: Halyard release on i20 [Re: catsailor2032] #248516
05/17/12 09:41 AM
05/17/12 09:41 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
You might have to cut the luff rope to let the sail go up higher. Check the sail against the top of the mast with it laying on the ground .
Re: Halyard release on i20 [Re: catsailor2032] #248522
05/17/12 11:09 AM
05/17/12 11:09 AM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
What Dave said. Sometimes the top of the luff rope bumps against the bottom of the mast hook.
Hot knife can fix it.
Re: Halyard release on i20 [Re: catsailor2032] #248532
05/17/12 01:20 PM
05/17/12 01:20 PM
Daytona Beach Florida
O
orphan Offline
orphan  Offline
O
Check the position of the grommet at the top of the sail. If it is positioned to close to the bolt rope it is hard to unhook.
Re: Halyard release on i20 [Re: catsailor2032] #248540
05/17/12 07:10 PM
05/17/12 07:10 PM
Chesapeake va
C
C
Chesapeake va
Thanks alot
Re: Halyard release on i20 [Re: catsailor2032] #248541
05/17/12 07:10 PM
05/17/12 07:10 PM
Chesapeake va
C
C
Chesapeake va
I appreciate all the info
Re: Halyard release on i20 [Re: catsailor2032] #248564
05/18/12 11:34 AM
05/18/12 11:34 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Common problem. The tops of the mains are often made just a bit different with the bolt rope closer or farther from the Grommot. I use to tie a bowlon at the top. When I got my new main I had to run the line through the ring and put a stopper knot in the back to that it pulls the ring off the hook.
Good Luck.
Mike Hill
N20 #1005
0 registered members (), 199 guests, and 47 spiders.
