| Halyard release on i20 #248510 05/17/12 09:19 AM 05/17/12 09:19 AM |
Joined: May 2006 Posts: 19 Chesapeake va catsailor2032 OP
Posts: 19 Chesapeake va | I've had a i20 for 13 years never had a problem releasing the main, now that I am using another main I can't get it to release in the normal way, pulling the halyard and over rotating the mast. Any ideas. Thanks
Sailing catana411. i20
| | | Re: Halyard release on i20
[Re: catsailor2032]
#248511 05/17/12 09:24 AM 05/17/12 09:24 AM |
Posts: 5,590 Naples, FL | is it just re-hooking each time you try to pull the main down?
Any trouble getting the main up (like the bolt rope is snug) and hooked?
there might be a magic way to tie the knot on the halyard ring. Or the headboard might be twisted a bit...
[Re: catsailor2032]
#248564 05/18/12 11:34 AM 05/18/12 11:34 AM |
Posts: 833 St. Louis, MO, | Common problem. The tops of the mains are often made just a bit different with the bolt rope closer or farther from the Grommot. I use to tie a bowlon at the top. When I got my new main I had to run the line through the ring and put a stopper knot in the back to that it pulls the ring off the hook.
Good Luck.
Mike Hill N20 #1005
1,076
guests, and 50
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
