| F18 spinnaker cleat? #250369 07/01/12 12:43 PM 07/01/12 12:43 PM | DuncanO
| DuncanO
Unregistered | Hello all,
So I'm a fairly raw beginner when it comes to cats. I have had some experience sailing on cats, 420's and keelboats but these all belonged to someone else. Last summer I bought a 2001 Nacra F18 and it's been great fun. Sailed it a few times last season under the main and jib only, just to get a feel for the boat. I had to replaced what I believe was the original spinnaker this year and have had the boat out several times with the spin up. It all seems to be working correctly, and I am blown away by the power.
When I have had the spin up it seems awfully hard to hand hold the spin sheet. I believe I have the sheet routed correctly. The two blocks that it goes through (per side) are ratcheting units and I think I've got them oriented correctly. I have only used it under relatively light winds, under 10 knots. In stronger winds I'm having trouble imagining hand holding it for long. My crew usually does this and his hands are suffering. Is this how it's usually done? Does anyone cleat this line?
There is a MKII infusion at my club and the dealer told him not to cleat this line under any circumstances. I'm guessing this is for safety, so you can drop it at the first sign of trouble.
All input appreciated.
Thanks, Duncan
| | | Re: F18 spinnaker cleat?
[Re: ]
#250383 07/01/12 04:04 PM 07/01/12 04:04 PM | DuncanO
| DuncanO
Unregistered | Thanks Rich, I will check this again before I go out again. I must have something wrong in my setup. it's good to know that it's not supposed to be that hard.
Duncan | | | Re: F18 spinnaker cleat?
[Re: Don_Atchley]
#250418 07/02/12 07:49 AM 07/02/12 07:49 AM | DuncanO
| DuncanO
Unregistered | Don, I have done this!! It never really holds very well though, which may be another clue that my setup is wrong. It's gotta be the setup, because there's plenty of mass there for holding power. 8^)
I'm gonna check it again, but I also have another question: Does everyone run a cleat on the spin halyard to lock it in the sock/snuffer? The fellow I bought my boat from did say that every now and then the wind had unexpectedly grabbed the head of the sail and pulled it out. My boat doesn't have this, but the newer infusion at my club does. Is this a worthwhile addition, or does it just make it a PITA to raise the sail? I always pull the head of the sail completely inside the sock so I'm not sure it matters. | | | Re: F18 spinnaker cleat?
[Re: ]
#250449 07/02/12 10:37 AM 07/02/12 10:37 AM |
Posts: 3,906 Clermont, FL, USA | I also have another question: Does everyone run a cleat on the spin halyard to lock it in the sock/snuffer? The fellow I bought my boat from did say that every now and then the wind had unexpectedly grabbed the head of the sail and pulled it out. My boat doesn't have this, but the newer infusion at my club does. Is this a worthwhile addition, or does it just make it a PITA to raise the sail? I always pull the head of the sail completely inside the sock so I'm not sure it matters. I don't and I think most don't for the reason that you stated. The last thing you want is the snuffer line getting accidently cleated on the raise. Sometimes the head of the spin will start to sneak out on a long choppy upwind distance race but we just put a slip knot in the snuffer line at the snuffer block on the tramp.
[Re: ]
#250552 07/03/12 08:01 PM 07/03/12 08:01 PM | DuncanO
| DuncanO
Unregistered | Hi Everyone,
Thanks Dave, I won't bother cleating this line. Today I went out and took a look at the orientation of the spin sheet blocks - I think they are correct. However I did notice that the side blocks (which are the first ones the sheet runs through from the sail) don't seem to ratchet or lock at all. These are the ones on the hulls and they are supposed to be hexaratchets. The slightly larger blocks on the front beam are ratcheting perfectly. Are these hexaratchets working correctly? It seems unlikely that they would both be broken . . . but they do freewheel in both directions regardless of load.
As always, all input is appreciated.
Cheers, Duncan | | | Re: F18 spinnaker cleat?
[Re: bobcat]
#250559 07/04/12 08:19 PM 07/04/12 08:19 PM | DuncanO
| DuncanO
Unregistered | Thanks Bobcat,
I just checked this and those blocks (on the hulls) don't seem to have a switch, although the main sheet block does. Maybe only the ones on the beam are meant to be fully ratcheting?
Thanks again, Duncan | | | Re: F18 spinnaker cleat?
[Re: ]
#250560 07/04/12 11:08 PM 07/04/12 11:08 PM | Scarecrow
| Scarecrow
Unregistered | that might be part of the issue, if you only have one ratchet you want it to be on the hulls. Early F18s only had the one turning block (a ratchet on the hull) but because the rope only turned 60-80 degrees through the ratchet and as such didn't help much. The fwd block is to make the sheet wrap right around the block and maximise the grip. If you have the ratchet on the front beam it has the same potential issue so swap them over and all your issues might be solved. | | | Re: F18 spinnaker cleat?
[Re: ]
#250568 07/05/12 11:01 AM 07/05/12 11:01 AM | DuncanO
| DuncanO
Unregistered | Thanks Scarecrow,
I'm a bit hesitant to start re-rigging - I believe my setup is correct. However I am curious whether these blocks are meant to fully ratchet. What does everyone else have? Are the hull mounted blocks meant to be fully ratcheting like the ones on the beam? The beam mounted blocks actually lock in one direction under load.
[Re: ]
#250583 07/05/12 07:41 PM 07/05/12 07:41 PM |
Posts: 9 | | | | Re: F18 spinnaker cleat?
[Re: ]
#250596 07/05/12 10:41 PM 07/05/12 10:41 PM | DuncanO
| DuncanO
Unregistered | Thanks Goose,
I do have that manual. Unfortunately, my boat has hexaratchets in both positions - it's just that the ones on the hulls don't really seem to ratchet. As soon as the wind cooperates I'll try sailing it again with the existing setup. If it's still monstrously difficult to hold I'll switch the ratcheting units to the hulls.
Cheers, Dunc | | | Re: F18 spinnaker cleat?
[Re: ]
#250598 07/06/12 02:23 AM 07/06/12 02:23 AM |
Posts: 2,584 +31NL | Some ratches have a small adjustment screw which can be used to set the resistance level, older ratching blocks have a small sliding switch to turn ratching on or off. Maybe yours is set to only ratchet under a lot of load? Do yours make that distinct ticking sound when you sheet in? Normally the ones on the hull are ratches and the ones on the are "normal".
[Re: ]
#250617 07/06/12 09:06 PM 07/06/12 09:06 PM | DuncanO
| DuncanO
Unregistered | Wow this is all great advice. I've examined these blocks pretty carefully and can't find any adjustment, but I'll definitely take another look. I've leaned on them very hard and not gotten any locking in either direction but they do seem to click in both directions. They are six 'sided' harken pulleys with a small red plastic insert on each side. And they do have a directional arrow. I am assuming they are meant to ratchet. I'll do my best to give them a good cleaning.
Thanks everyone for all the help, Duncan | | | Re: F18 spinnaker cleat?
[Re: ]
#250949 07/20/12 08:40 AM 07/20/12 08:40 AM |
Posts: 932 Solomon's Island, MD | In breeze up to 10 knots you should be fine if the outside blocks have the ratcheting enabled and the beam mounted blocks are disabled. Over 10 kts and you want both on, for most crews. When distance racing we run doublers to get 2:1 purchase for long spin runs-put a block on the sail and a hook on the shroud attachment point, run the sheet through the block and to the hook. Makes jibing a pain, again it is a setup for distance racing only.
Cleating a spin sheet is asking to go swimming.
Scorpion F18
[Re: samc99us]
#250962 07/20/12 02:54 PM 07/20/12 02:54 PM |
Posts: 1,304 Gulf Coast relocated from Cali... | Cleating a spin sheet is asking to go swimming. Not totaly accurate. You just need to drive a little more conservatively. I've sailed SOLO all the way from Catalina Island to San Pedro Ca (Long Beach area) with my spin sheet wrapped around my windward daggerboard flying a hull the whole way. A cleat on the deck helps when the crew has to clear rudders and boards or anything else.
Lee
2,694
guests, and 623
