| aluminium rivets?rotatirotatio #251153 08/01/12 08:05 AM 08/01/12 08:05 AM |
Joined: Feb 2005 Posts: 4,119 Northfield Mn Karl_Brogger OP
Posts: 4,119 Northfield Mn | Is there any reason not to use them on lightly loaded things? I need to mount a couple of cheek blocks on my front beam for positive mast rotation. I have SS, but I'm cheap and I'd think corrosion would be less of an issue with using like metals. I always coat rivets in duralac, but that's no guarantee.
| | | Re: aluminium rivets?rotatirotatio
[Re: Karl_Brogger]
#251154 08/01/12 09:45 AM 08/01/12 09:45 AM |
Posts: 12,310 South Carolina | no reason at all...I use aluminum rivets where ever possible to avoid the dissimilar metal corrosion issue....unfortunately, there aren't many areas they will hold up on the boat. I suppose they're adequate for the rotation controls (and if not, you've only lost $1 and a little time).
Jake Kohl | | | Re: aluminium rivets?rotatirotatio
[Re: Karl_Brogger]
#251157 08/01/12 10:38 AM 08/01/12 10:38 AM | MN3
| MN3
Unregistered | couple related questions: 1. I know there are many different types of alum. I think most cat spars are built with 6061. Are alum rivits the same grade? and if not, would they have corrosion due to dissimilar metals?
2. I have seen how amazingly well Tef-gel works.. is duralac the same type of product (PTFE) and is it any better than tef-gel? | | | Re: aluminum rivets?rotatirotatio
[Re: Karl_Brogger]
#251158 08/01/12 11:16 AM 08/01/12 11:16 AM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | When the mast flops over will the cheek blocks ever be shock loaded? If so the aluminum will fail and if they rip out you'll probably wind up with a elongated hole in your beam and then you'll be using 1/4' rivets or screws/w nuts. I would first try drilling and tapping for a #10 fine and if that wears out go to the SS rivets.
Sometimes it's costly being cheap.
[Re: catman]
#251159 08/01/12 11:23 AM 08/01/12 11:23 AM |
Posts: 330 | When the mast flops over will the cheek blocks ever be shock loaded? If so the aluminum will fail and if they rip out you'll probably wind up with a elongated hole in your beam and then you'll be using 1/4' rivets or screws/w nuts. I would first try drilling and tapping for a #10 fine and if that wears out go to the SS rivets.
Sometimes it's costly being cheap. The intent of the OP was not only to save cost but also minimize galvanic corrosion. If the rivet were to fail, it would be the rivet that broke (head sheared off) not elongating the hole in the beam as you describe. I think there' very little risk to damaging the beam with this approach and there is likely to be a significant reduction in galvanic corrosion. A failure of the rivet could potentially ruin a race however. A better option may be to use a stainless rivet and simply rinse the boat really well after sailing in salt water as this will also greatly reduce galvanic corrosion but provide a much stronger overall connection. sm
[Re: Karl_Brogger]
#251160 08/01/12 11:50 AM 08/01/12 11:50 AM |
Posts: 4,119 Northfield Mn | I didn't factor in getting quality rivets, not something I had honestly considered, but makes perfect sense. I think I'll just toss some SS ones in there. Hasn't failed me yet.
I don't know how you saltwater guys do it. I can see the effects right away. I don't see much saltwater fortunately, just slimy alge filled acidic lakes.
[Re: catman]
#251161 08/01/12 11:54 AM 08/01/12 11:54 AM |
Posts: 778 Houston | When the mast flops over will the cheek blocks ever be shock loaded? That why you attach the blocks to the rotation arm with wimpy line that breaks first. The line acts like a fuse, in an electrical line. I bought one of Goran Marstrom's personal boats. I noticed there were about 10 pieces of 1 ft long ~1.5 mm line tied to the front crossbeam. I discovered all the blocks in the rotation system were attached with that kind of line. If I screw up, the line breaks. I have spares on the boast and you can replace them on the water. | | | Re: aluminum rivets?rotatirotatio
[Re: Karl_Brogger]
#251162 08/01/12 11:57 AM 08/01/12 11:57 AM |
Posts: 1,152 tampa, fl | Tieing the blocks to the jib track works just as well as putting cheek blocks on the beam. The fewer holes you have to drill in the beam, the better.
If your havin girl problems i feel bad for you son I got 99 problems but my beautiful wife ain't one | | | Re: aluminum rivets?rotatirotatio
[Re: Karl_Brogger]
#251163 08/01/12 12:12 PM 08/01/12 12:12 PM |
Posts: 4,119 Northfield Mn | True. And I've got a butt load of Viadana H404 copies laying around.
I still have to screw two Harken micro cleats on.
I'll F with it on Friday.
[Re: Karl_Brogger]
#251168 08/01/12 03:03 PM 08/01/12 03:03 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | I didn't factor in getting quality rivets, not something I had honestly considered, but makes perfect sense. I think I'll just toss some SS ones in there. Hasn't failed me yet.
I don't know how you saltwater guys do it. I can see the effects right away. I don't see much saltwater fortunately, just slimy alge filled acidic lakes. I use Tefgel. The metal soaks it up and insulates the dissimilar metals. It really does work and it stays where you put it. I would never use an aluminum rivet on any load bearing part.
368
guests, and 45
