| Re: she went soft on me(the hulls that is)
[Re: prindlesnark]
#25193 11/08/03 10:15 AM 11/08/03 10:15 AM |
Posts: 284 S. Florida | Hi Jason, What has happened to your hulls is called "low cycle fatigue". The deck of a catamaran hull is in compression bow to stern. The forestay is pulling up on the bows, the mainsheet is pulling up on the sterns and the mast is pushing down in the middle. This tries to bend the hull and make the deck get shorter which puts it in axial compression. Also punching through waves tries to bend the bows up which adds to the hull bending and deck compression problem. The maximum load, high stress area, is just in front of the trampoline, 1 to 2 feet, in the deck. After this has happened millions of times/cycles the bond between the foam core and the fiberglass skins gives up. The foam sandwich in the soft areas of the deck in your boat has delaminated, not glued together anymore; it is old and tired and just worn out. This is hard to fix. You have to rebond the inner skin to the foam and it is major sergury to get to it. Here's a way to do it. In the soft area of the deck, grind away the outer skin and foam down to the inner skin. Bevel the perimeter of the ground away area back on a shallow slope. Replace the removed/ground away foam with a mixture of resin and microbaloons. Leave the microbaloon core about 1/32 inch low relative to the original deck around it. You can use the original deck around the repair to guide your squeegee. After this has cured, restore the top fiberglass skin coat and add a couple of extra layers this time tapered on the forward and trailing edges at least 1 inch per layer. The hull should have been built with additional fiberglass layers in this high load area in the first place but it wasn't, hence your problem. Paint the repaired area and you are ready to go sailing again and ready for another several million low cycle fatigue cycles. Good luck, Bill | | | Re: she went soft on me(the hulls that is)
[Re: BRoberts]
#25196 11/09/03 06:47 PM 11/09/03 06:47 PM |
Joined: Dec 2002 Posts: 312 Memphis, Tennessee Damon Linkous
Posts: 312 Memphis, Tennessee | Bill, You know a lot more about boat construction than I do, so I'll bow to your expertise on this. All I know is that I've seen many old cats revived using the injection method and they seemed to be solid. Maybe it's an illusion. I have a hard time picturing how your method works exactly. It seems like you'd need a lot more skill with glass and it would really need a professional. The injection system is meant to be a "do-it-yourself" solution, so it makes sense that it wouldn't be as good. I wonder if it would be possible, using your method, to cut the deck off, fill with the micro balloon mixture and stick the deck back down? Also, Hobie Cat Company endorses the injection method for the old boats, they actually have instructions for it at http://www.hobiecat.com/support/tech/delam.html | | | Re: she went soft on me(the hulls that is)
[Re: Damon Linkous]
#25197 11/09/03 08:37 PM 11/09/03 08:37 PM |
Posts: 5,558 Key Largo, FL & Put-in-Bay, OH... | Damon, Just to back you up, our son Dave is a professional fiberglass guy, and he uses the injection method that you showed in that article on your website. He repaired a soft Laser deck for us, and I watched him drill all those little holes all over it and then use the syringe to pump epoxy into the holes. Worked fine -- when he was done, the deck was solid as a rock. Just looked like it had chicken pox from all those little holes.
Usually people who have an old boat with soft decks are not planning to use it for racing and don't care about adding a little weight. If you can use the injection method to economically restore an old boat and extend its life without grinding fiberglass and shortening your own life, why not? | | | Re: she went soft on me(the hulls that is)
[Re: BRoberts]
#25199 11/09/03 10:47 PM 11/09/03 10:47 PM |
Posts: 3,114 BANNED | From Hobie's own site: http://www.hobiecat.com/support/tech/delam.htmlThis method has been tried and true. The only thing I would actually do differently, is once you've filled the layer with epoxy, then dips some drywall screws in veggie oil, and sink two or three of them completely through both layers. This will pull the bottom fiberglass layer back to the top. Once the epoxy has kicked, remove the screws gently, and plug the holes. The repair that Bill mentions, is the kind that I did on my boat, except I actually laid some marine grade laminated hardwood up under the deck and then used a buttload of low density filler and some layers of glass to fix the deck. Its rock solid, but I wouldn't want to undertake that project without epoxy/fiberglass experience when the epoxy injection will do the same thing for you. | | |
256
guests, and 42
