| Re: Tacking in the Zone
[Re: daniel_t]
#254167 10/31/12 06:38 AM 10/31/12 06:38 AM |
Joined: Nov 2005 Posts: 807 Hillsborough, NC USA Isotope235 OP
Posts: 807 Hillsborough, NC USA | Yes. S obtained overlap with P2 from clear astern within two boatlengths, so S may not sail above her proper course (RRS 17). In this case, her proper course at the windward mark would be to bear away or gybe.
I improved the text and added rules 15, 16, and 17 to the applicable rules.
Thanks, Eric
[Re: Isotope235]
#254193 10/31/12 07:58 PM 10/31/12 07:58 PM |
Posts: 61 Albenarle NC | Is S required to hold course after hailing starboard?
[Re: jackbr549]
#254196 10/31/12 09:18 PM 10/31/12 09:18 PM |
Posts: 217 Palm Harbor, FL | Is S required to hold course after halting starboard ? My guess is no. 16.1 says that if S changes course she must give P1 room to keep clear. That implies that S can change course. This is different than the "rules of the road" where rule 17 explicitly requires the stand-on vessel to keep her course and speed (unless actively maneuvering to avoid collision.)
Daniel T. Taipan F16 - USA 213 | | | Re: Tacking in the Zone
[Re: jackbr549]
#254200 11/01/12 07:24 AM 11/01/12 07:24 AM |
Posts: 807 Hillsborough, NC USA | Is S required to hold course after hailing starboard? No, but if the right-of-way boat changes course, she must give the other boat room to keep clear. See rule 16.1. Also, if a starboard-tack boat bears away toward a port-tack boat after the starting signal, she must not force the port-tack boat to immediately change course in order to keep clear. See rule 16.2. The hail "hold your course" really just means "I'm aware of you". | | | Re: Tacking in the Zone
[Re: Isotope235]
#254215 11/01/12 01:26 PM 11/01/12 01:26 PM |
Joined: Dec 2005 Posts: 443 Edmonton, Alberta, Canada bobcat
Posts: 443 Edmonton, Alberta, Canada | I often feel challenged when bearing away/setting the spin after rounding the windward mark and am looking at a variety of boats on/near the port layline. There is no offset mark, so their layline tends to run fairly close to my intended course. These boats aren't taking my stern. They are trying go by within inches of my sides in a potential head on scenario. As I steer lower, they tend to steer lower which doesn't help alot. Because of mark fixation, they don't want to tack away. I fear the puff that causes me to bear down hard when they are several boat lengths ahead and only a foot to leeward. I talk to people about it, but haven't been able to convert the world.
[Re: bobcat]
#254221 11/01/12 03:29 PM 11/01/12 03:29 PM |
Posts: 3,906 Clermont, FL, USA | I often feel challenged when bearing away/setting the spin after rounding the windward mark and am looking at a variety of boats on/near the port layline. There is no offset mark, so their layline tends to run fairly close to my intended course. These boats aren't taking my stern. They are trying go by within inches of my sides in a potential head on scenario. As I steer lower, they tend to steer lower which doesn't help alot. Because of mark fixation, they don't want to tack away. I fear the puff that causes me to bear down hard when they are several boat lengths ahead and only a foot to leeward. I talk to people about it, but haven't been able to convert the world. And you never will. Suicide port is just too much of a tatical advantage. What you never want to hear from someone on suicide port is "I'm close hauled I have the right of way". Those are the people we need to find and correct. When an offset isn't used as starndard operating procedure it just leaves me scatching my head and to quit using it because people keep skipping it is just dumb. Ah that was refreshing.
2,492
guests, and 585
